Can I connect a Samsung Android C7 tablet to a Samsung monitor?
You can connect it only if the tablet supports MHL; check that with an app, and use an active MHL cable rather than a passive one [#16968723][#16968810] In the thread, the tablet was later said not to support MHL, so that connection method would not work [#16968912] The monitor was also described as VGA-only, which rules out the Miracast/Mirascreen suggestion that needs an HDMI input and Android 5+ [#16968782][#16968807]
Snow covered me in a magic ball and I can't see anything, I can see something like a fog but I can't read exactly what model of monitor and tablet you have.
I think I have to call the fortune teller Maciej, so maybe he'll tell me.
There is a possibility. Read about the MHL standard. Active cables are better for its use, rather than passive ones, although they do not work properly with some TV sets.
@ Kraniec_Internetów Only for what purpose you are writing it as it is not even known if this tablet has any AUDIO-VIDEO output and what inputs the monitor has.
Well, unless you have a better magic ball range and you are not covered with snow
Connecting a Samsung monitor to an Android Samsung C7 tablet is feasible, primarily through the MHL (Mobile High-Definition Link) standard. The tablet, which has a USB port, is likely to support MHL, allowing for video output to the monitor. However, the monitor must have compatible inputs, such as HDMI, for successful connection. If the monitor only has VGA output, an adapter may be necessary. Users are advised to check the tablet's specifications and consider using applications to verify MHL support. It is noted that the tablet does not support MHL, which limits direct connection options. AI summary based on the discussion. May contain errors.
