Navroad NR470 Enovo - How to update windows CE 6.0 in navigation.
YUREK1st 6885 12
How can I update the Windows CE 6.0 system on a Navroad NR470 Enovo navigation unit?
You can only update it with the firmware/software package provided by Navroad for that exact device; the manufacturer’s website includes the detailed update instructions and the latest available software [#16615027] If Navroad has not released a newer system for the NR470 Enovo, there is no simple generic upgrade path, because the operating system must be designed for that specific navigation hardware [#16615271][#16686093] The thread says there are practically no alternative solutions, and at most you could try software from another device on the same disc as yours, though that may not give you anything useful [#16685524]
  • #1 16614927
    YUREK1st
    Rate: 23
    How to update windows CE 6.0 in Navroad NR470 Enovo.
  • #3 16615091
    YUREK1st
    Rate: 23
    japycz321 wrote:
    On the manufacturer's website you have ... the latest available software.
    I know, there are files with the 2011 modification date, so you don't want to believe that there were no newer updates.
  • #4 16615109
    japycz321
    Help: 92
    Rate: 141
    But it's just software, it doesn't matter. The maps themselves can be uploaded newer, only usually different than those of the device manufacturer.
  • #5 16615238
    YUREK1st
    Rate: 23
    Well, of course, so I wasn't asking about maps, but about an alternative way to update windows, e.g. this one Link
  • #6 16615271
    Freddy
    Help: 1394
    Rate: 2822
    If the hardware manufacturer has not made the update available, it will be very hard to get something - unless you write the WIN CE xx system itself :) .
  • #7 16685477
    YUREK1st
    Rate: 23
    Well, Windows CE 7.0 versions appeared
    System released in 2010 and Embedded Compact 2013
    System released in 2013.
    Link
  • #8 16685524
    japycz321
    Help: 92
    Rate: 141
    Well, what if they showed up? Do you think none of us know about the existence of ce7? Navigation is not a computer in which you can change the system at will. What the manufacturer released is what you can use. There are practically no alternative solutions, and I don't think you'll be able to find and apply one. But nobody prevents you from blazing the trail :-)
    The only thing you can try is to choose the software from another device on the same disc as yours, but if everything works, you still won't get anything. So the question is why.
  • #9 16685928
    YUREK1st
    Rate: 23
    For example, for:
    Windows CE 7.0
    System released in 2010. New features:
    Support for processors with two cores (e.g. ARMv6),
    Positioning based on WIFI,
    Bluetooth 3.0 support
    DRM technology support,
    NDIS 6.1 support,
    Advanced touch and gesture support,
    Synchronization of data and media with MTP,
    Updated graphics based on Open GL ES 2.0,
    Improved Internet Explorer 8 with backward compatibility,
    Support for tabs,
    DLNA.
    wi-fi support
    System released in 2013:
    DHCPv6 support
    IPv6 support over VPN
    Snapshot boot
    Improved XAML support
    Improved memory management compared to version 7
    HTML Help viewer has been added
    And someone has already paved the way https://www.youtube.com/watch?v=w0sVsRUgvhc
  • #10 16686016
    japycz321
    Help: 92
    Rate: 141
    and so:
    ARM11 600 MHz
    you don't have wifi, you have gps
    you don't even have 1.0
    I wonder what ...
    and you can go on and on ....
    Have you tried to browse the web on a device with a single core processor and 64MB of RAM? Look at the parameters of your smartphone and ask yourself again why.
    no. What does this have to do with navigation? The video shows an unknown device that does not have much relevance to your navigation system.
    As further discussion becomes futile, please write to me when you manage to update your device and what profits you made from it.
  • #11 16686065
    YUREK1st
    Rate: 23
    I see that you cannot or will not help me and you are trying to discourage me. I am just an ordinary user of navigation, not the latest anymore, so this desire to update, without technical details and without the need to argue why, for example, I prefer to have "Improved Internet Explorer 8 with backward compatibility"
  • #12 16686093
    Freddy
    Help: 1394
    Rate: 2822
    @ YUREK1st Can't you understand that it is not enough to load just any system?
    The system must be designed for a specific type of navigation.
  • #13 16829857
    YUREK1st
    Rate: 23
    Of course I understand, that's why I ask on the forum and not try to do it myself:
The discussion revolves around updating Windows CE 6.0 on the Navroad NR470 Enovo navigation device. Users are directed to the manufacturer's website for available updates, but concerns arise regarding the lack of recent software updates, with some files dating back to 2011. While alternative software options exist, the consensus is that the device's hardware limits the feasibility of such updates. Users express frustration over the inability to upgrade to newer versions like Windows CE 7.0 or Embedded Compact 2013, which offer enhanced features. The conversation highlights the challenges of updating proprietary navigation systems and the importance of using software specifically designed for the device.
