Automapa v6.24 map en 1802 - How do I update the map from PL 1802 to 1806?
Steve4 6876 2
  • #1 17386227
    Steve4
    Rate: 9
    Old NAVIA 2008 navigation with Win CE 5.0 on board and pre-loaded Automapa supported by a built-in SD card reader. I always make updates by fully reinstalling the new version of Automapa on an SD card inserted into the reader in a laptop with windows (without navigation). I know that there is also a way to update only the map itself without fully reinstalling the program and the map and entering all settings. I currently have the Automapa version of windows ver. 6.24 with the map Polish ver. 1802 and I would like to update from my full latest installation also in program version 6.24 with map of Poland 1806 only the map itself. Apparently, only a directory with map files is replaced and everything works without installation from the beginning and entering all settings. Does anyone know how to do this? The version of the program in navigation as well as in the installed installation - the update is the same - 6.24 only the Polish map version changes from owned 1802 to 1806.
  • #2 17386261
    ta_tar
    Help: 700
    Rate: 2053
    I don't know how you would like to do it. As I download the current map (currently 1806), I download the .exe file.
    Once I wanted to install an old map from an exe file on my computer, during installation the program stated that this license is for my navigation (I have NavRoad) and did not allow installation.
  • #3 17386400
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    Just do as you did it before, just do not do a "clean" installation, just upgrade the AutoMapa installed on the card, i.e. the SD card with AM installed, to a reader on your computer. Then run the AutoMapa installation file on your computer, update the previous installation and it's ready. Everything will be arranged as you had it. The program has remained the same for several versions of the map (6.24) and during the update nothing changes in the program (it simply does not update it, what remains because there are no changes in the program). Only maps are updated. Well, unless you want to "add" something that you have not previously installed (eg additional voices, languages), then you select only the appropriate options and the installer will do its job, but the settings of the program you have installed on the SD card will be as they were. One rule, do not install "clean" after the card format, only update the already installed program and maps.
