Opel Corsa C 2001: Daytime Running Lights Installation - Wiring Guide (Black, White, Red Wires)
henio 123 7638 5
  • #1 16615345
    henio 123
    Rate: 144
    Hello. I have recently bought an Opel Corse C. I am going to install daytime running lights. The harness has three wires: black ground connected white connected to the position lights red to be connected to receive voltage from the first position of the ignition switch. I do not have an electrical diagram. Please where to connect this red wire.
  • #2 16615361
    rob4028
    Help: 66
    Rate: 472
    there should be an ignition signal. In the fuse box under the hood you will find the ignition voltage on the fuse.
    Added after 7 [minutes]:
    For example, F23
  • #3 16615434
    henio 123
    Rate: 144
    Thanks for the response. Where can I look for this fuse on the cover there is no lettering. I attach photos. Opel Corsa C 2001: Daytime Running Lights Installation - Wiring Guide (Black, White, Red Wires) Opel Corsa C 2001: Daytime Running Lights Installation - Wiring Guide (Black, White, Red Wires)
  • #4 16615487
    rob4028
    Help: 66
    Rate: 472
    The numbers are next to the fuses.
  • #6 16643758
    henio 123
    Rate: 144
    Power supply of the red cable to the fuse F23 white cable to the position lights. Black to the ground. Lights work. I consider the topic closed.
