Installing & Activating Front Fog Lights on Corsa C - Fuse, Relay, & Connector Solutions
ekmir 13263 8
  • #1 16799377
    ekmir
    Help: 18
    Rate: 408
    I would like to install fog lights on the Corsa C.
    Unfortunately, there is no fuse and relay for these lights in the fuse box. There are no pins (connectors) in the place where the fuse and the relay should be.
    How would you activate and install the front fog light in this car?
  • #2 16799394
    Pedros050
    Help: 2471
    Rate: 3926
    In a very simple way, here is one of them. Installing & Activating Front Fog Lights on Corsa C - Fuse, Relay, & Connector Solutions
    Second method. Installing & Activating Front Fog Lights on Corsa C - Fuse, Relay, & Connector Solutions
  • #3 16799523
    ekmir
    Help: 18
    Rate: 408
    PITERRR
    Thank you very much.
    Can I use an original switch with a fog light button for this?
    How do I make the fog lamps turn on by the indicator in the clocks?
  • #4 16799534
    andrzej20001
    Help: 1578
    Rate: 6669
    Then the bcm controls the lights. You can power the relay from the rear fog light. Then they work together.
  • #5 16799670
    ekmir
    Help: 18
    Rate: 408
    Can BCM be used in some way, e.g. when using the first method?
  • Missing cluster bulb caused fog light indicator failure
    #6 17263365
    ekmir
    Help: 18
    Rate: 408
    I purchased a light switch with front fog lamps.
    After installing it in the vehicle and turning on these lights - no indicator light.
    It turned out that there is no light bulb in the counter - clocks.
    After refilling the bulb - the light comes on when the fog light button is pressed :)
    Is there a chance the BCM will be fog lamp compatible?
    Which relay (K39) controls these lights?
    Is it the same relay as K76L?
  • #7 18924407
    peplunio76
    Rate: 10
    Hello! And how? Did you install halogen lights for Opel? I also wanted to install front fog lamps, but after buying a light switch of the version with front fog lamps, the light does not light up when I turn on the button. And the light bulb is. You don't know why the light is off? Paweł
  • #8 18945654
    ekmir
    Help: 18
    Rate: 408
    Check if you have power there.
  • #9 18948721
    peplunio76
    Rate: 10
    I mean, where should I have the power supply? To the halogen light from the switch? When I test the lights with the op-com, the halogen light is on, but when the button is pressed it does not work ... switch diagram and theoretically the light should come on after turning on the front fog button ... I do not know what's going on ... What gives the impulse to the indicator? Counter or BCM?
The discussion revolves around the installation and activation of front fog lights on the Corsa C, focusing on the absence of a fuse and relay in the fuse box. Users explore various methods to power the fog lights, including utilizing the rear fog light relay and the BCM (Body Control Module) for control. There are inquiries about using an original switch with a fog light button and ensuring the indicator light functions correctly. Some users report issues with the fog lights not activating despite having the correct switch and bulb, leading to troubleshooting steps such as checking power supply and relay compatibility.
