Fiat Seicento - Seicento, where is the speedometer sensor pulse?
piwos 27429 16
Where is the speedometer pulse sensor mounted on a 2005 Fiat Seicento 1.1 petrol gearbox?
The speedometer pulse sensor is screwed into the top of the gearbox, in the same place where the old mechanical speedometer cable drive would have been mounted [#16617053] It is on the gearbox side near the engine bulkhead, not by the radiator, and can be hard to see because hoses, cables and the air filter block access from above [#16617439] The mounting location does not change between the gearbox versions mentioned in the thread [#16617053] One reply also notes that if the odometer works but the speed needle does not, the fault may be in the meter/instrument cluster rather than the gearbox sensor [#16617498]
  • #1 16616936
    piwos
    Help: 50
    Rate: 210
    Seicento 2005 / 1.1 gasoline, where is the speedometer sensor impedance motor screwed in?
    In which place?
  • #2 16616953
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    You must look for the impulser on the top cover / surface of the gearbox. In the place where in the boxes with the mechanical drive of the meter / speedometer was mounted the speedometer cable drive.
  • #3 16616963
    piwos
    Help: 50
    Rate: 210
    The problem is that I look, look and do not see :)
    I found the reversing sensor and I thought it was him (the speedometer pulse) but unfortunately it is not him :(
    Where is the impulse, does anyone know?
  • #4 16616987
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    I'm not exactly sure, but this is probably the place on the main transmission.
  • #5 16616995
  • #6 16617007
    piwos
    Help: 50
    Rate: 210
    Can you be more precise, more clearly? I do not have the practice until such an imagination as this gear is mounted?
  • #7 16617011
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    Instead of a cable drive, an impulser is mounted, the mounting location does not change. The best way is to get on the cables from the meter.
    Added after 7 [minutes]:
    piwos wrote:
    how is the transmission mounted?
    Almost the same as the links drive.
    Instead of a cable, it is screwed to the pictures.
  • #8 16617027
    piwos
    Help: 50
    Rate: 210
    The point is that I lack imagination, I do not know how this gear is mounted?
    (which party to which)
    This chest from Seicento 1,1 / petrol?
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    Have you seen these two pictures?
    It is simply screwed in where the red arrow points.
    In Seicento 1.1, two types of gearboxes were probably used. One so-called with "wet goblets" and the second with "dry goblets" (it comes to half-axle joints at the gearbox), one of them probably had a symbol, if I remember correctly, 516 and something else, and the other 514 and other numbers, but otherwise there were no major differences, maybe except the gear ratios in individual gears, but only that the half-axle joints at the gearbox worked in oil and the other worked "dry". The place of the line / pulse attachment did not change
  • Need transmission-mounted speed sensor location
    #10 16617054
    piwos
    Help: 50
    Rate: 210
    I know this :)
    Where is the impulse, does anyone know? Any drawing, photo or description?
  • #11 16617069
  • Speedometer pulse sensor location shown in photos
    #12 16617090
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    piwos wrote:
    I know this :)
    Well, you have shown the red arrow twice in the picture where it is screwed, but it's hard to three times the art:
    And the impulse is just this:
    Speed sensor pulse location behind engine bulkhead
    #13 16617439
    g107r
    Help: 811
    Rate: 993
    I understand a little friend :)
    This photo is from the side of the page as if it would stand and open the mask, it is a photo of the back of the engine with the chest
    Right in front of the engine bulkhead, not behind the radiator, it is possible that you have to dive deeply into the engine compartment and bend the cables, pipes and other such, because they block the view.
    This is more or less where the green circle, only half a meter deeper , obscured by the air filter and other such "hiding".
  • Speedometer pulse sensor located deep behind air filter
    #14 16617481
    piwos
    Help: 50
    Rate: 210
    Oh, I understand, it's already clarifying! Thanks, mate G107r! Today I will check and let you know if I found :)
    ps. I wonder just why the km counter on the clock is fanning but the speed arrow does not indicate?
    Instrument cluster fault likely causing speedometer failure
    #15 16617498
    g107r
    Help: 811
    Rate: 993
    In my meter there are two "motors", one drives the pointer, the other drives miles. The fact that one will have a problem with the operation is not surprising. Start by watching if there are no cold solder in the counter unit, no capacitor has swelled up, that is, the speedometer does not get a signal, but the system from km is still like this.
    And it will not matter if the meter with the display, the system splits into two measurements, speed, and mileage. The electronic course can charge, but the motor can be floated from the speed, hang or not work. After all, there are 2 systems in one housing, using one wire from the sensor / motor controller - because it's different here, and in seicento I do not know.
    For my taste something on the meter, and the sensor on the chest is OK.
  • #16 16619852
    piwos
    Help: 50
    Rate: 210
    I found a grandfather. Eh, they could not place it any worse? ;)
    I leave for those interested. If someone long and passionately searched, and could not find, I warn you! Access from the top for someone who has a thin, small hand and of course on a completely cold engine :)
    Thanks to all kind and constructive! :)
    It turned out that the fault was, however, the sensor
  • #17 19441268
    Samotniś
    s 1.1 99 years. Would that be here? How to check? Just like a friend. ?
    Fiat Seicento - Seicento, where is the speedometer sensor pulse? Fiat Seicento - Seicento, where is the speedometer sensor pulse? Fiat Seicento - Seicento, where is the speedometer sensor pulse?
The discussion centers around locating the speedometer sensor pulse in a 2005 Fiat Seicento 1.1 gasoline model. Participants suggest that the sensor is mounted on the top cover of the gearbox, where the speedometer cable would typically connect. Several users express difficulty in finding the exact location, prompting requests for clearer guidance and images. Helpful responses include links to images showing the sensor's location, which is described as being obscured by other engine components. The conversation also touches on issues with the speedometer not functioning, indicating potential problems with the sensor or the meter itself.
