Peugeot 206 1.1 Engine - Indicator Light On Despite Normal Functioning
marcinos655 4140 4
  • Suggesting an OBD scan to read engine fault codes
    #1 16617694
    marcinos655
    Hello, I have such a problem, the engine light is on, not long ago, what I bought this car and I have no idea what could be the reason, the engine is working normally, the acceleration is also unchanged. I think that you need to remove errors from your computer only need some program to remove these errors I will be grateful for the download links of the program .. Thank you and have a nice day. best regards
  • #2 16617697
    spinacz
    Help: 1204
    Rate: 2654
    Not program but hardware, do you have any diagnostic equipment, some OBD cable?
  • #3 16617724
    marcinos655
    I have this cable once I bought it with EuroScan but I can't find this disc :( I downloaded now from chomikuj but I don't know if it will be appropriate ..
  • #4 16617833
    spinacz
    Help: 1204
    Rate: 2654
    ELM327? If so, look for pcmscan.
  • #5 16617983
    tzok
    Help: 3176
    Rate: 6549
    ... if there are errors, you have to remove the defect and then delete them. It is a primitive driver and with many faults, the car will run normally (only, for example, it will smoke a lot).
