Peugeot 206 1.1 Error P0300: Ignition Failures Despite Various Checks & Changes
kubas10 23181 13
Why does a Peugeot 206 1.1 still show intermittent P0300 misfires after replacing the ignition coil, spark plugs, injector rail, and checking compression, valve clearance, fuel pressure, and intake leaks?
The most likely cause is incorrect engine timing/locking or another mechanical issue, not the ignition or fuel parts you already replaced. Check the cam/crank locking order and the timing holes carefully, because the engine may be set two teeth off and this engine family is sensitive to exact timing [#16590373][#16606882] The manifold readings you gave are probably absolute pressure values from a gauge, not true vacuum; a high reading here points to too little air being drawn in or an intake leak [#16590344][#16590260] After correcting the timing, reset the adaptation and measure compression again, because one suggestion was a bad flywheel hole or even a head issue if compression is not right [#16606372][#16608030]
  • #1 16589320
    kubas10
    Help: 42
    Rate: 1547
    Hello, Gentlemen, I have been struggling with the P0300 error in this peugeot for a long time. Checked / changed: coil, candles, injection molding bar, compression, valve clearance, fuel pressure, leak tightness.
    On a cold engine:
    the vacuum in the suction manifold is 0.55 bar and the pointer pulsates quite rhythmically;
    KWZ jumps from 0 to 12 degrees;
    the injection time is 8ms;
    On a hot engine:
    the vacuum in the suction manifold is almost 0.6 bar and the pointer pulsates quite rhythmically;
    injection time is 5ms;
    After the engine is warmed up, the probe works properly.
    Conclusions:
    I have a low vacuum in the collector by which the controller gives too much injection time on a hot engine. As the customer gets in the car and goes under the overpass it so tugs that the car has no strength to drive uphill.
    When I add gas, the vacuum increases to about 0.7 bar or 2500 rpm. What is he running about?
    Come, this jerking appears ok, once a week.
  • #2 16589842
    jurekk55
    Level 36  
    Help: 182
    Rate: 1580
    Did you regulate the valves?
  • #3 16590172
    Ireneo
    Help: 747
    Rate: 2472
    He wrote that he checked
    Kat is not clogged?
    jurekk55
    Level 36  
    Help: 182
    Rate: 1580
    What clearance measurement results?
    Tap the surface of the valve-lever? No seat and seat tightness? Relocated timing?
    Negative pressure too high, so the cylinder is sucked in too little air, or has a leaky intake.
  • #5 16590270
    kubas10
    Help: 42
    Rate: 1547
    Ireneo wrote:
    Kat is not clogged?
    If I have 0.5 bar and I add gas and it grows up to 0.7 bar, then I have a positive exhale.
    Luzy ok, I smoke on the touch so that the timing is ok but I did not check its setting, compression on cold after 10 bar so that the valves keep tight, intake with samostart, disconnected from the collector all connections (servo, odma, fuel pairs).
    ociz
    Help: 1379
    Rate: 3486
    Too low. Gentlemen, learn to distinguish between negative pressure and absolute pressure.
    kubas10 wrote:
    If I have 0.5 bar I will add gas and increase to 0.7 bar
    What are these values, where are they read?
    andrzej20001
    Help: 1578
    Rate: 6669
    The order of the locks check.
  • #8 16590387
    kubas10
    Help: 42
    Rate: 1547
    The value read from the vacuum gauge.
    Added after 3 [hours] 6 [minutes]:
    Tomorrow morning I check this timing, the shaft is somewhere blocked in the front between the engine and the transmission?
    Added after 19 [hours] 22 [minutes]:
    With the shaft locked, the shaft 2 teeth back. After correct setting, the engine is much worse, but the negative pressure has increased to about 0.6 bar.
  • #9 16606250
    kubas10
    Help: 42
    Rate: 1547
    The week the customer rode and today again P0300 ...
  • #10 16606372
    domex32
    Help: 585
    Rate: 2451
    Have you found a bad hole on the flywheel?
    Make it the original settings or delete the adaptation.
    Measure the compression again.
    These engines are specific.
  • #11 16606882
    pepe150
    Level 36  
    Help: 288
    Rate: 943
    The "visually" post is almost no different. The engine family is the same, so locks are everywhere the same.
    Under the exhaust manifold, next to the chest you have a small hole, so that you put a finger. Under it you have a small hole for the screw 6. There has to be a blockade.
  • #12 16607086
    kubas10
    Help: 42
    Rate: 1547
    The shaft fits in one place, more holes were not there, then the shaft was 2 teeth back. After correct setting of the timing I did reset the adaptation, the required engine temperature below 30oC. Negative pressure increased to about 0.65 bar on cold, and earlier it was 0.5 bar.
  • #13 16608030
    domex32
    Help: 585
    Rate: 2451
    Measure the compression. It may turn out that the head will need to be raised.
  • #14 16608060
    kubas10
    Help: 42
    Rate: 1547
    This is a good idea, I will check and let you know.
The discussion revolves around a Peugeot 206 1.1 experiencing a persistent P0300 error, indicating random misfires despite extensive checks and replacements of components such as the ignition coil, spark plugs, and fuel injection system. The user reports low vacuum readings in the intake manifold, which fluctuate with engine RPM, suggesting potential issues with air intake or valve timing. Responses from other users include suggestions to check valve clearances, timing settings, and possible leaks in the intake system. The user confirms adjustments to the timing have improved vacuum readings but the P0300 error persists. Further recommendations include measuring compression and ensuring proper adaptation settings.
