Peugeot 206 1.4 8v Petrol: Engine Light, Second Injection Error, Replaced Parts & Solutions
Piotr918273645 5595 7
  • #1 16536942
    Piotr918273645
    I have a Peugeot 206 1.4 8v petrol. After starting the car on a cold engine and adding gas, the engine light turns on. After connecting to the computer, a strong signal appears on the second injection. Candles, coil, controller and injection wires changed. I do not know what may be the cause of this error. Help
    Please.
  • #2 16537003
    DoctorCar
    Level 19  
    Help: 37
    Rate: 123
    In Peugeot cars, the injectors themselves often fail. The easiest way is to swap the injections and see if there will be a mistake
  • #3 16537039
    Piotr918273645
    It was changed and still shows the second injector
  • #4 16538001
    DoctorCar
    Level 19  
    Help: 37
    Rate: 123
    Petrol alone or with LPG?
    I would do it like this: remove the injectors from the manifold so that the tips can be seen, supply the power to the pump and the common plus for the injectors, and then through the test tube and ammeter check the current consumption of the injectors by providing mass. It should be even and then you know if everything is ok with the controller. If it is good here, it looks like a falling engine controller
  • #5 16538018
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    You have KFW but I have not seen such an error yet.
    Overall, what's your problem with the car?
  • #6 16549602
    Piotr918273645
    I forgot to write that it has gas, but it was unplugged by a mechanic. I don't know what KFW means. I swapped the injections with 2z4 and it did not work, it still shows an error (short circuit on the 2nd injection). This error appears when the engine is started when it is cold. it is not the fault of the first probe.
  • #7 16550414
    Help: 1405
    Rate: 6430
    But what is wrong with the car that you write posts?
  • #8 16554204
    Piotr918273645
    After starting a cold engine, the check light comes on and the revs ripple, goes out after ten minutes, whether it is the fault of the first probe or the coil.
The discussion revolves around a Peugeot 206 1.4 8v petrol vehicle experiencing an engine light activation and a second injection error upon starting a cold engine. The owner has replaced several components, including spark plugs, coil, controller, and injection wires, but the error persists. Suggestions include swapping the injectors to check for faults, testing the injectors' current consumption, and considering a potential issue with the engine controller. The owner also mentions that the vehicle has been converted to LPG, but the gas system is currently disconnected. The error appears specifically when the engine is cold, accompanied by fluctuating revs that stabilize after about ten minutes.
