[Solved] DeLonghi Magnifica S ECAM 22.1 - FAILURE indicator and blinking green indicators
p_iwaniuk 20457 9
How can I reset or fix a DeLonghi Magnifica S ECAM 22.110 B when the exclamation mark lights up and the espresso and double-coffee buttons blink after the brew unit stops in the upper position?
The problem is most likely the upper brew-unit microswitch being installed or adjusted incorrectly, not a burned-out protection or a simple reset issue [#17093092][#17096104] The switch was closing the circuit too early, so the machine thought the brew unit had reached the end position immediately [#17093146] It needs to be moved so the contact point falls into the hole on the upper piston [#17093146] After that, the self-test should let the brewing unit move up, reach the brewing position, and stop correctly [#17096104] One reply also mentions a reset procedure: switch off the top two buttons, POWER and PARA, then turn the machine on with the main switch [#17093146]
  • #1 17092954
    p_iwaniuk
    Rate: 9
    Hi, I have a problem with DeLonghi Magnifica S ECAM 22.110 B.
    I lubricated the brewing unit, cleaned it from coffee deposits and put it in the recess of the block. The machine started the AUTOTEST and stopped the brewing unit in the upper position. My fault because I didn't tighten the upper microswitch too much and the device showed an error. I corrected this switch and checked the top and bottom. All OK.
    The red exclamation mark in the triangle lights up and the light at the espresso button and double coffee are blinking, when the machine is turned off the machine does not perform any self-test as it should.
    The question is, is there any reset of the coffee machine that could be used, or maybe at the moment when this upper end did not catch at the right moment something could have overheated or burned out?
    I also thought the brewing unit was wrong, but I checked it by turning the entire range of movement of the brewing block by the engine pulley and it is also ok.
    Do you have any ideas?
  • #2 17092996
    Krzysztof Druś
    Help: 35
    Rate: 85
    Have you looked at YouTube?
  • #3 17093031
    p_iwaniuk
    Rate: 9
    I would like :) . Unfortunately, I have a triangle with an exclamation mark and two lights on immediately after starting the machine. When the machine is started, it does not position the brewing unit.
    • DeLonghi Magnifica S ECAM 22.1 - FAILURE indicator and blinking green indicators 2.jpg (80.71 KB) You must be logged in to download this attachment.
  • #4 17093040
    Krzysztof Druś
    Help: 35
    Rate: 85
    There was no crackling, maybe something cracked or changed.
  • #5 17093054
    p_iwaniuk
    Rate: 9
    Well, you could just hear the brewer's work after lubrication, but I immediately turned it off. I undressed, once again nothing broke. Everything is all right. Then I manually turned the whole brewer's working range by hand, nothing happened. I wonder if there is any protection against drive overload. And whether it is one-time or you can somehow do a reset.
  • #6 17093074
    Krzysztof Druś
    Help: 35
    Rate: 85
    I've never reached that far so I can't really say anything about it.
    Maybe the limit switch was switched off too shortly?
  • #7 17093089
    p_iwaniuk
    Rate: 9
    So yeah I fiddled with the buttons and I was able to start the brewing unit with the button. It started, but with the selftest again it did not close the brewing unit in the work position. So I got something somewhere, but there is actually a combination of buttons that you use to test the device.
    Krzysztof Druś
    Help: 35
    Rate: 85
    I gave you a hint :D
    I would go back to what the seals were lubricated with.
    Because the piston was pulled out.
  • #9 17093146
    p_iwaniuk
    Rate: 9
    Krzysztof,
    With espresso machines, you are sure of everything but it doesn't work. I sat by this machine until 2am. I have my first DeLonghi workshop. The matter looks like I put it all together, that I set up a new upper limit switch. So when I tightened the screw of this end switch, it immediately closed the circuit. I have to move it so that the contact point falls into such a hole from the upper piston.
    For the future, if you need a reset, you have to turn off the top two buttons, POWER and PARA, and turn on the machine with the switch. pote, turn it on and it will play.
    Thanks, sometimes you need someone to drop off and motivate ;)
    Regards
  • #10 17096104
    p_iwaniuk
    Rate: 9
    During the SELFTEST, the brewing unit went up fully, but after reaching the brewing position, did not stop pressing.
    The upper brewing microswitch is installed incorrectly.
The discussion revolves around issues faced with the DeLonghi Magnifica S ECAM 22.110 B coffee machine, specifically concerning a failure indicator and blinking lights after a brewing unit lubrication and cleaning. The user initially encountered an error due to a loose upper microswitch, which was subsequently corrected. However, the machine continued to show a red exclamation mark and blinking lights, indicating a malfunction during the self-test. Various suggestions were made, including checking the lubrication of seals, ensuring the correct installation of the upper brewing microswitch, and the possibility of a reset procedure involving specific button combinations. Ultimately, the user found that the upper microswitch needed proper adjustment to function correctly.
