whirpool something has fallen into the drum and is struggling to get out
don vito19 28856 6
  • #1 4893837
    don vito19
    Rate: 15
    There is an unusual situation wirpol washing machine works without any problems but I think (so says the owner) something long and thin fell through the hole between the drum and its housing stuck and now it rubs I do not know what type of washing machine how to do this repair need to remove the drum and how to do it maybe someone has a general diagram of the construction of the washing machine
    I know a bit about disassembling and assembling but would like some advice
    kind regards
  • #2 4894057
    Asteroid
    Help: 18
    Rate: 188
    Tell us which model ! Top-loaded or side-loaded ?
  • #4 4894071
    don vito19
    Rate: 15
    On a side note, I don't know the model
    What letter do we start a sentence with?
    Do not delete moderation posts!
    18:43 10.3.2008
    Please correct!
    [_P_]
  • #5 4895238
    mirofalcon
    Help: 72
    Rate: 360
    Probably some bra wire or something else has fallen in, remove the heater and try to locate through the heater hole to see if there is any foreign object in the tank
  • #6 4895266
    MakroSerwis
    Help: 248
    Rate: 343
    It depends where the wire is stuck - it's probably caught on the heater, and the easiest way is to disconnect the drain wire from the drum and try to get 'that thing' out.
  • #7 12113737
    diablica529
    Rate: 8
    Hi. I had the same problem. Something was knocking on the drum during spinning. It turned out to be a file that fell behind the drum. just open the drum. There are plastic transverse plastics in the drum. You just have to take them off and take out whatever is under the drum. Open the washing machine, close the drum, twist to the mounts of these plastics, pull to the side and through the hole you can take it out. It is not necessary to disassemble the entire washing machine. Best regards and I hope that I have helped you
    Mod. ROBSON33
    Regulation 3.1.13. (10.9, 15)
    It is forbidden to publish posts that violate the spelling rules of the Polish language, are careless and unintelligible.
    Please correct the post without deleting the above entry .
A user reports an issue with a Whirlpool washing machine where a long, thin object has fallen into the drum and is causing a rubbing noise. The user is unsure of the model and seeks advice on how to remove the drum for repair. Responses suggest that the object may be a bra wire or similar item, likely caught on the heater. Recommendations include removing the heater to inspect for foreign objects and disconnecting the drain wire from the drum. One user shares their experience of a similar problem, indicating that the object was a file that fell behind the drum, and advises on accessing the drum without fully disassembling the machine.
