Waeco parking air conditioning d - Turns off after 2 max 5 sec
Bigiel83 10692 3
  • #1 16621717
    Bigiel83
    Rate: 49
    Hello, I have a problem, I have a waeco parking air conditioning installed instead of a sunroof, yesterday there was a problem. After a night where it works flawlessly, I turned off only the remote control to standby mode and not the power button as I always did, I started the engine and went. Standing on pause, I wanted to turn it on, unfortunately, it could not be turned on for about 2 to 5 seconds, sometimes the display shows the word LO or it goes out at all and does not turn on. Equipment as in the attached photo, please help what could happen
    • Waeco parking air conditioning d - Turns off after 2 max 5 sec 1501683714261372410313.jpg (881.74 KB) You must be logged in to download this attachment.
  • #2 16621786
    kkknc
    Help: 1915
    Rate: 6709
    Stable power supply?
    Water or gas? Because you didn't provide the model.
  • #3 16621885
    Bigiel83
    Rate: 49
    Unfortunately, I do not know the model of this equipment, but I received it with the car
  • #4 17998061
    marek124l
    Rate: 69
    hello you solved the problem with the LO error?
