Fuel Pump Relay Ford Focus MP1: Cost Comparison, InterCars Quote, Affordable E-shops
Karolina6991 12450 10
How much should a fuel pump relay for a 1999 Ford Focus cost, and where can I find a cheaper one?
You should be able to buy a generic relay much cheaper than the PLN 150–200 quoted by InterCars; one reply says an ordinary one costs about PLN 15 and does not need a Ford logo [#16621897] Cheaper options were also suggested as used parts from auction and advertising sites or scrapyards [#16621843] Before buying, check the exact relay type or post a photo of the symbol, because the exact part matters [#16621853] Also make sure the relay is actually the fault, since a similar case turned out to be the fuel pump itself hanging up rather than the relay [#16621884]
  • #1 16621818
    Karolina6991
    In intercars they told me PLN 150/200 for a cube the size of a matchbox (relay). Does it cost so much ?! There are various prices on the internet. It seemed to me that it would cost 10 or 20 PLN max.
    Maybe I can find an e-shop where I can buy it cheaper.
    Please help
    (I'm a girl :) )
  • #2 16621843
    rafik$
    Help: 13
    Rate: 52
    The new one will cost so much, the cheaper one will be used, which is abundant on auction and advertising sites, as well as on szrotach. What region do you live in and what exactly is the focus? Regards
  • #3 16621853
    barteksmrek
    Help: 89
    Rate: 224
    Enter the type of relay, photo.
  • #4 16621854
    Karolina6991
    Łódź voivodeship
    Ford Focus 1999 hatchback
  • #5 16621863
    rafik$
    Help: 13
    Rate: 52
    enter the relay symbol I should have
  • #6 16621884
    rozales
    Help: 43
    Rate: 160
    I have a car from the same year and with a similar fault the mechanic tells me that the fuel pump relay.
    I took measurements and bypass the relay and it turned out that the fuel pump was hanging up.
    Are you sure the relay is broken?
  • #7 16621891
    Karolina6991
    Where I marked in red this relay should be and in intercars they told me that it is from the fuel pump.
    In general, the air conditioning didn't work and the one marked in green was where it is now red. The neighbor put it down for me and the climate is ok, but he told me to buy another one and plug it in as it was.
    So it could be the same, because it worked here and here.
  • #8 16621897
    barteksmrek
    Help: 89
    Rate: 224
    https://www.google.pl/search?q=focus+przeka%C...25252F%25252Fwww.auto-truck3.pl%25252Fproduct. php% 25253Fid_product% 2525253D5914 & source = and at & pf = m & fir = bW3h_MJayLqHcM% 253A% 252CJBh5R9fiDjaFiM% 252C_ & uSG = __ 7njXNPhF9cX5ORhQIXcTqTVnN64% 3D & b and = 1776 & bih = 793 & ved = 0ahUKEwj_8-ra_LjVAhWBjxQKHe_YDT0QyjcIPg & ei = Wv6BWf_eB4GfUu-xt-gD # imgrc = bW3h_MJayLqHcM:
    If this is the most ordinary for PLN 15 you do not have to have it with a ford stamp for PLN 150
  • #9 16621899
    rafik$
    Help: 13
    Rate: 52
    I will check and let you know tomorrow.
  • #10 16621992
    ociz
    Help: 1379
    Rate: 3486
    Will you buy a ring or earrings for PLN 10-20? In such relays there are also precious metals, of course only those of brand name.
  • #11 16622920
    rafik$
    Help: 13
    Rate: 52
    Unfortunately, I do not have, but at pw gives the address in Lodz, where it will be.
The discussion revolves around the high cost of a fuel pump relay for a Ford Focus MP1, with quotes ranging from PLN 150 to 200 from InterCars, which the user finds excessive. Participants suggest that used relays are available at much lower prices on auction and advertising sites. The user provides additional context by specifying the vehicle's model and year (1999 hatchback) and shares a photo indicating the relay's location. Some responses question whether the relay is indeed faulty, suggesting that the fuel pump itself might be the issue. Links to cheaper alternatives are shared, emphasizing that non-branded relays can be found for as low as PLN 15.
