Citroen C5 2006 1.8 Fuel Pump Relay Replacement: YH 119012-1h11-1S Relay Inquiry & Alternatives
piotrmags1 8391 11
How can I obtain or replace the YH 119012-1H11-1S fuel pump relay in a 2006 Citroën C5 1.8?
The relay is inside the BSM, and if you cannot find the original YH 119012-1H11-1S, the practical option is to replace it with another relay or salvage one from another module [#16371682][#16371812] One member linked an eBay listing for a similar YH11 relay as a possible source [#16372223] Another said he removed the relay by carefully slitting the plastic cover, so the part can be accessed and replaced that way [#16372581] Overall, the original relay seems hard to source as a standalone part, so buying a complete module may be the fallback if a matching relay cannot be found [#16371812][#16376144]
  • #1 16371597
    piotrmags1
    The problem concerns the replacement of the fuel pump relay on the 2006 Citroen C5 1.8, which has the designation YH 119012-1h11-1S. Has anyone tried to get it or replace it? Maybe someone has such a relay?
  • #2 16371682
    autoas
    Help: 571
    Rate: 3924
    You mean the one inside at BSM ....
  • #3 16371698
    piotrmags1
    Yes. Exactly...
  • #4 16371812
    autoas
    Help: 571
    Rate: 3924
    You can replace anything but how to get the original I do not know
  • #5 16371872
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    autoas wrote:
    I don't know how to get the original one
    I have an effective concept for this, just from another module.
    As well as other parts of automotive electronics.
  • #6 16371981
    piotrmags1
    I do not hide that I am considering such a possibility. However, I would prefer to insert a new one. Buying a module (if I can find it with such relays) costs about PLN 100-200 (used - it is not known how much). However, this type of relays, I think, are much cheaper.
  • #8 16372581
    Frost160
    Help: 9
    Rate: 183
    I am such a relay, in fact, probably two, because I sold each side from the directions in 206 from 2002. I got to him by slitting the plastic cover slowly :) Let me know how you succeed in this operation.
  • #9 16375895
    piotrmags1
    I close the topic
  • #10 16375972
  • #11 16375989
    Help: 1405
    Rate: 6430
    The rudder, the sailor, the ship himself, neither the wave nor the wave clings to him.
    Then it burst like a bubble on a rag of boulder.
    Nobody knew his life, nobody knew his undoing.
    This..........
  • #12 16376144
    piotrmags1
    I will specify. I did not get the relay. I have not replaced. It remains to buy a new module.
The discussion revolves around the replacement of the fuel pump relay in a 2006 Citroen C5 1.8, specifically the YH 119012-1h11-1S model. Users express uncertainty about sourcing the original relay, with suggestions to consider alternatives or used modules. One participant mentions having similar relays from a Citroen 206, indicating a potential workaround. The cost of acquiring a new module is noted to be around PLN 100-200, while the relays themselves are believed to be cheaper. The conversation concludes with the author stating they have not yet replaced the relay and are considering purchasing a new module instead.
