Somfy 5054240C: M1 and M2 Motors Connectivity, Remote Control Programming & Wing Closure Issues
87budyn 16737 2
  • #1 16622184
    87budyn
    Rate: 29
    hello I have a problem as in the subject after connecting two M1 and M2 motors to the controller programming the remote control are the following symptoms.
    I press the button M1 starts after a moment M2 I press the button both engines stop. I press again, the M2 engine starts and the M1 end stands still when I repeat the action is exactly the same reaction the wings open but only one moves and closes where to look for the cause of help
    Somfy 5054240C: M1 and M2 Motors Connectivity, Remote Control Programming & Wing Closure Issues Somfy 5054240C: M1 and M2 Motors Connectivity, Remote Control Programming & Wing Closure Issues
  • #2 16622203
    rafcio_21
    Help: 137
    Rate: 299
    And did your colleague program the control panels in addition to programming the remote control.
  • #3 16622576
    87budyn
    Rate: 29
    As I write during programming, the M1 engine no longer starts and does not want to close (or open in total) but they move both in one direction and the other only one. Is there any way to reset the whole driver? The reset button only resets the remotes?
