[Solved] Volvo FH12 - Identifying Mystery Light Indicator: Brands, Models, Parameters & Hints
dzikusek1 10278 5
  • #1 16982142
    dzikusek1
    Rate: 35
    Hello, please give me a hint what the light is.
    • Volvo FH12 - Identifying Mystery Light Indicator: Brands, Models, Parameters & Hints 20180123_121734.jpg (1.11 MB) You must be logged in to download this attachment.
  • #2 16982467
    citromaniak
    Help: 53
    Rate: 394
    Appetizer?
  • #3 16982770
    Dagomir
    Help: 42
    Rate: 191
    It could be a transmission limited function indicator, in case of insufficient air pressure, or when there are problems with the braking system and the transmission has no information about the speed from the ABS sensors. See in the vehicle diagnostics if any errors are active in the transmission module, if so enter the code.
  • #4 16985376
    dzikusek1
    Rate: 35
    Hello, there are problems with the pneumatic system, after a few hours the air leaves the cushions and there were errors MID 144 PPID 312 FMI 10, MID 144 PID 46 FMI 1, the compressor was in emergency mode and I restarted the dryer and is looking for a pressure sensor that is somewhere in cabin?
    Dagomir
    Help: 42
    Rate: 191
    The second error describes the low pressure in the inlet tank and may become inactive when you inflate the system. The dryer can be calibrated when it is new and then the compressor is restarted. I think you should compare the pressure that the car sees in the individual circuits, with the pressure gauge that needs to be connected to them. You should also locate the source of the air loss, since the car falls on the cushions, they may be leaking or the power supply system.
  • #6 17053697
    dzikusek1
    Rate: 35
    Hello, there was actually a loss of air and two that have been removed and now it's ok. Thank you for your interest and best regards.
