Siemens espresso machine TK76K573 - no steam production for frothing milk
Pe.te 15639 16
How can I fix a Siemens TK76K573 espresso machine that starts milk frothing or milk-system cleaning but stops after 1–2 seconds?
The milk circuit was clogged with limescale/contamination between the valve and the steam outlet nozzles behind the frother, and intensive cleaning restored full operation [#16647615] Use about 800 ml water plus 200 ml descaler, run hot water for several seconds, remove the milk frother, press the frother presence switch with a long thin screwdriver, protect the display from steam, then start milk frothing and scrub the rear nozzles gently with a small toothbrush while steam and descaler come out [#16647615] If the machine completes the frothing cycle without interrupting after 1–2 seconds, the cleaning worked; if not, repeat it [#16647615] Finish with the normal Calc’n’Clean program to flush the descaler out of the system [#16647615] Be careful with the frother cover/logo and the nearby diode module, because steam and condensation can damage them [#16647615]
  • #1 16624858
    Pe.te
    Rate: 44
    I have a problem with the Siemens TK76K573 coffee machine.
    Coffee is brewed normally, but there is a problem with steam production ...
    It started a few months ago with the "short milk system cleaning" function not working. It was heard that the machine was "preparing steam", the cleaning process began, but the machine finished after about 1-2 seconds. (normally the process should take about 10 seconds)
    Now the cappuccino frothing milk has stopped working.
    The symptom is exactly as above - the machine "prepares steam", begins to froth milk, but after about 1-2 seconds. interrupts the process. Normally followed by coffee brewing, but here the interruption of the milk frothing process interrupts the entire capuccino preparation procedure - previously ground and prepared coffee is thrown into the container by the machine, brewing does not even start ...
    However, if I choose non-dairy coffee, then the machine makes it without a problem ...
    It looks as if there is a problem with the "steam circuit" - because all processes that use the milk suction tube (i.e. frothing milk, heating milk, cleaning the milk system) do not work properly. The operation of all these processes is identical to the one described above.
    I will add that the milk frother, suction tube circumference, etc. are cleaned regularly.
    The machine itself is also regularly descaled (liquid) and cleaned (tablets).
    I am asking for help, because my wife without capuccino / late is unable to function :)
  • #3 16624889
    Pe.te
    Rate: 44
    Is it a foamer module?
    For the foamer - it is currently a screw version with a seal (O-ring).
    Originally it was a push-in version, but a few years ago the foamer was replaced with a screwed version (tighter).
    The frother is such, this upper part (in the photo on the right) is unscrewed.
    The suction tube is connected to this connection from the side (pictured above).
  • #4 16624939
    nioop
    Home appliances specialist
    Help: 503
    Rate: 3337
    This is exactly what I meant ...
    Has the vent valve inside the espresso machine of a new construction been replaced with the foamer?
    Is the fulfillment process too short in the device or does it just take too little milk?
    Kawa i Naprawa - Serwis AGD
  • #5 16624964
    Pe.te
    Rate: 44
    No, only the foamer was replaced, nothing was exchanged inside the machine.
    After replacing the foamer, the machine worked perfectly for several years.
    The thing is that the very process of collecting (foaming) milk is too short - as I wrote about 1-2 seconds.
    During this time, the milk collects and foam properly, only instead of a few seconds (as before) now it lasts less than 2 seconds ...
  • #7 16625432
    Pe.te
    Rate: 44
    No...
    Besides, it's not just about cappuccino. It behaves in the same way (i.e. for 1-2 seconds) any other function taking the frother hose - even the milk system cleaning function, which simply draws water from the cup out to rinse the frother, or the "warm milk" function, which should suck milk and heat it without foaming ... Each of these functions starts for 1-2 sec. and ends ...
    On the foamer before replacement (those with a push-in rather than a screw-on lid) the symptoms were different. The machine then carried out the entire foaming procedure, only that the milk did not foam, because the foamer was leaking and sucked it poorly. In any case, the procedure itself lasted as long as it should, i.e. several seconds.
    Now just after 1-2 sec. the suction procedure is interrupted. It is as if the machine was detecting some error and stopping it.
    Therefore, he doesn't stop making cappuccino, he just throws away the prepared and un-brewed coffee. So in turn:
    - they had coffee
    - beat in the brew unit
    - prepares a pair
    - begins to suck the milk
    - after 1-2 sec interrupts milk suction
    - doesn't stop making coffee, just throws away dry, pre-ground coffee into the waste
  • #8 16625463
    nioop
    Help: 503
    Rate: 3337
    I'm sorry, apparently the temperature was a bit distracting me ...
    Naturally purely hypothetical - slight leakage from the steam nozzle clutch.
    Centrally below it is a small electronic board (I suspect its placement is deliberate) and small water leaks cause anomalies.
    The second hypothesis - with the pump's impulse operation, the flow meter incorrectly counts the impulses interrupting the brewing process.
  • #9 16625627
    Pe.te
    Rate: 44
    It's great that there are some hypotheses. Thanks!
    But one thing puzzles me ... As I mentioned at the beginning, the failure occurred in two stages.
    - a few months ago milk system cleaning (i.e. taking water from a cup to rinse foamer) and milk heating stopped working; at that time cappuccino and latte were completely normal (i.e. foaming milk worked)
    - milk frothing has stopped working now
    What connects and divides these two processes?
    I mean the process of taking liquid without foaming (rinsing water and milk to be heated) and collecting milk with foaming.
    Maybe it will help to track the source of the problem?
    Because these two hypotheses ... wouldn't it be that if it was moisture condensing on the plate or flow meter - then everything would not stop working. And for several months foaming worked, while downloading without foaming - at all ...
  • #10 16625779
    nioop
    Help: 503
    Rate: 3337
    Everything he writes is purely hypothetical .. I can only direct but not seeing the device, please be aware of my mistake all the time ..
    The device has a so-called multifunctional valve ...
    It switches the valves by an electric motor, directing the water to the brewing unit to the nozzle .. - from what I remember on the nozzles this valve has three settings and two completely different channels supplying it water, a few plus additionally its third setting is to attach the aeration.
    Earlier, the leak could be caused by one of the settings .. Over time, a second leak occurred on the second setting of the multifunction valve ..
    Naturally, as I mentioned - purely hypothetical ;)
  • #11 16637593
    kesy1
    Rate: 58
    I have a problem with the Bosch CTES32 espresso machine, namely the espresso machine does not heat up, otherwise everything works correctly. When making coffee, the coffee was made with coffee beans, then it only releases cold water, when you try to release hot water, the message Water heating appears on the display and after a while the coffee returns to its initial state. Maybe someone will advise what the problem is or how to check if the heater is damaged. I have my coffee machine ready, if anyone needs it, I can make photos.
    Regards
  • #12 16647485
    bosman116
    Level 19  
    Help: 24
    Rate: 155
    kesy1 provide the exact model from the nameplate.
  • #13 16647536
    kesy1
    Rate: 58
    I have two such espresso machines in the office, they look almost identical. The damaged one is Bosch No. TES50321RW / 12 Type CTES32, and the other functional one and the one bought in the store is TES50129RW / 06
  • #15 16647557
    kesy1
    Rate: 58
    and how to check these fuses and where they are
    Regards
  • #16 16647560
    bosman116
    Level 19  
    Help: 24
    Rate: 155
    We pass each other in posts, Pe.te describe the solution and let's close this topic.
  • #17 16647615
    Pe.te
    Rate: 44
    Thanks to the advice of my colleague bosman116 I was able to solve the problem with the lack of foaming milk, described at the beginning of the thread.
    The problem was the stony / contaminated water path between the valve and the steam outlet nozzles (nozzles at the back behind the foamer).
    I used the intensive cleaning procedure of this episode proposed by my colleague bosman116 - it helped 100%.
    Steps to follow in order:
    1. Start the machine
    2. Pour 800ml water and 200ml descaler (remove filter, if present)
    3. Run hot water for several seconds
    4. Remove the milk frother
    5. Use a long, thin screwdriver to press the frother presence switch (top, left near the nozzles)
    6. Secure the display (with a cloth, towel) so that escaping steam does not get wet on the module
    7. Start frothing milk
    8. Worn out a toothbrush (preferably small, for children) while escaping steam with water, clean the nozzles (those at the back, behind the frother) thoroughly but gently
    9. CAUTION - do not drink milk because it will be with a descaler
    10. If the machine does not interrupt the foaming process, it means that it worked; if not, repeat the process
    11. Finally, perform the standard Calc'n'Clean procedure to flush the descaler from the system.
    Additional remarks:
    a) Be careful of the frother lid (the one with the inscription "Siemens"); concentrated descaler escaping with steam, condensation can damage the metal surface and destroy the logo (it happened to me - I had to replace the cover with a new one)
    b) Due to the large amount of steam, the diode module may light up, illuminating the area near the nozzles during coffee brewing (this happened to me - this module is not well protected against moisture), as a result of which the diode will flash instead of a constant light; if this happens - you have to remove the foamer casing (as described in another thread) and dry the diode module (this is an ordinary, small printed circuit board)
The Siemens TK76K573 espresso machine is experiencing issues with steam production for frothing milk, which began with the malfunction of the "short milk system cleaning" function. Initially, the machine would prepare steam but complete the cleaning process in 1-2 seconds instead of the expected 10 seconds. This issue escalated to the cappuccino frothing function, which now also stops after 1-2 seconds, interrupting the entire preparation process. Various hypotheses were discussed, including potential leaks in the steam nozzle or issues with the multifunctional valve. Ultimately, the problem was resolved by cleaning the water path between the valve and steam outlet nozzles, which had become contaminated. A detailed cleaning procedure was provided, involving descaling and thorough cleaning of the nozzles.
TL;DR: A 100% fix came from an “intensive cleaning” because the “stony/contaminated water path” blocked steam; milk steps ended after 1–2 seconds. [Elektroda, Pe.te, post #16647615]
Why it matters: This FAQ helps Siemens TK76K573 owners restore steam/milk functions quickly, safely, and cheaply.
What causes the TK76K573 to stop milk frothing after 1–2 seconds?
A clogged steam path between the valve and rear steam nozzles halts suction early. The machine starts, senses abnormal flow, and aborts. Coffee-only drinks finish because they bypass the steam path. Cleaning that path restored full operation. “It helped 100%.” [Elektroda, Pe.te, post #16647615]
How do I perform the intensive steam‑path cleaning that fixed it?
  1. Fill tank with 800 ml water + 200 ml descaler; remove filter.
  2. Remove foamer; press the frother‑presence switch; start milk frothing.
  3. While steam/water escapes, gently brush the rear nozzles; repeat if it interrupts, then run Calc’n’Clean. “Intensive cleaning” restored steam output. [Elektroda, Pe.te, post #16647615]
Where exactly should I clean on the TK76K573?
Target the short section from the valve to the two rear steam outlet nozzles, hidden behind the foamer. Use a small toothbrush to scrub mineral and milk residue while steam flows. Keep the display area protected from moisture during this step. [Elektroda, Pe.te, post #16647615]
How do I trigger frothing without the foamer attached?
Remove the foamer, then press the small frother‑presence switch near the top-left of the nozzle area. Start milk frothing to route steam through the exposed nozzles for cleaning. Shield electronics with a towel before you begin. [Elektroda, Pe.te, post #16647615]
Can cleaning damage parts? What should I protect?
Yes. Concentrated descaler steam can stain the front lid with the Siemens logo, and condensed moisture can cause the LED board to flicker. Cover the area, and dry the small LED PCB if it blinks afterward. Replace the lid only if already marred. [Elektroda, Pe.te, post #16647615]
Why did warm‑milk/cleaning fail months before frothing failed?
Non‑foaming draw and foaming draw share the steam path but use different flow conditions. Early partial blockage can disrupt non‑foaming draws first, then worsen until foaming also stops. The later clean restored both behaviors. [Elektroda, Pe.te, post #16625627]
What is the multifunction valve on these machines?
It is a motor‑driven diverter that routes water to the brew unit, nozzles, and aeration. It has multiple positions and channels, including an aeration setting. Mispositioning or leaks can affect steam routing and frothing. “The device has a so‑called multifunctional valve.” [Elektroda, nioop, post #16625779]
What is the flow meter and how can it stop a cycle?
The flow meter counts pulses from pump flow. If pulses miscount due to moisture or sticking, the control aborts brewing or steaming. This can mimic a short milk draw and stop a cappuccino mid‑cycle. Inspect for leaks affecting it. [Elektroda, nioop, post #16625463]
Will the machine waste coffee if the milk step fails?
Yes. An edge case occurs: the machine grinds and tamps, begins steam, aborts milk after about 1–2 seconds, then discards the dry puck without brewing. You lose the dose and must start again. [Elektroda, Pe.te, post #16625432]
How much descaler and water should I use for the fix?
Use 800 ml water and 200 ml descaler in the tank. Run hot water briefly, then run the frothing cycle while brushing the nozzles. Finish with Calc’n’Clean to flush chemistry from the system. [Elektroda, Pe.te, post #16647615]
Do I need to replace the foamer module if it already was upgraded?
Not necessarily. A previously upgraded screw‑type foamer worked for years. The failure came from a blocked steam path, not the foamer. Clean first before buying parts. Replacement was unnecessary after cleaning. [Elektroda, Pe.te, post #16624889]
How can I tell if leaks or electronics are causing issues instead?
Check for moisture below the steam nozzle clutch and the small board located beneath it. Even slight leaks can cause anomalies, including bad flow readings. Dry components and re‑test after cleaning the steam path. [Elektroda, nioop, post #16625463]
My LED near the nozzles now flickers after cleaning—what should I do?
Remove the foamer cover and let the small LED PCB dry thoroughly. Flicker indicates moisture ingress from steam. After drying, the light returns to steady operation without replacement. Protect it during future cleanings. [Elektroda, Pe.te, post #16647615]
Do these troubleshooting ideas help Bosch CTES32/TES50321RW units?
Yes, some concepts apply. For TES50321RW/CTES32, also check the flow meter for a stuck rotor and verify heater fuses if there’s no heat. These checks complement descaling and cleaning. [Elektroda, bosman116, post #16647546]
What should I try if intensive cleaning doesn’t restore steam?
Inspect for leaks at the nozzle clutch, dry the nearby PCB, and verify accurate flow‑meter pulsing. If symptoms persist, the multifunction valve may need service due to internal leakage or misposition. Escalate to professional service after checks. [Elektroda, nioop, post #16625779]
