[Solved] Citroen Xsara Picasso 1.8 2002 Pb / Lpg - Orange engine light is on.
keseszel 19398 9
Why is the engine warning light on in my Citroën Xsara Picasso 1.8 and can I clear it by disconnecting the battery, or do I need Lexia to read and reset the fault?
The fault was most likely the post-catalyst lambda probe, because the stored code was P0141, and after replacing that sensor the warning light could be cleared with an Android app and ELM327 adapter [#17224962][#17949774] You do not need Lexia specifically to read the errors; tools like WOW, Delphi, KTS, or even ELM327 can work [#17176578] Disconnecting the battery or starting the car a few times did not clear the light after the repair, so the fault memory had to be erased with a diagnostic tool [#17949774] The P0440 code is not “impossible” on a petrol car; it refers to an evaporative-emissions fault, so it can appear with gasoline vapors [#17438523]
  • #1 17174550
    keseszel
    Help: 54
    Rate: 558
    The orange engine light is on. She appeared after some time when the car was fired in the parking lot. I had problems with power steering back then.
    After starting it, I smell gasoline in the car, but I'm not sure, I'll check it :idea: ... The engine seems to be running normally.
    According to the instructions :arrow: injection, ignition or exhaust aftertreatment system. Direction :arrow: ASO.
    Does the indicator go out by itself after the fault has been resolved? :?: Is it enough to disconnect the clamps :?: Is Lexia indispensable :?:
    Today I will check all possible plugs in the engine compartment :idea: I will disassemble and look at the EGR (when I find it :idea: ). Then I have the Lambda probe :idea: , spark plugs :idea: (they were exchanged 1000km ago), possibly a coil. But I do :idea: that when my coil fell in 2013, there was no control.
    Did anyone have a similar problem and how did they deal with it?
    szymitsu21
    Help: 343
    Rate: 1297
    P0126 P007E Insufficient coolant temperature for stable operation
    P0130 P0082 O2 Sensor (Bank 1, Sensor 1) - Malfunction
    P0131 P0083 O2 Sensor (Bank 1, Sensor 1) Voltage Low
    P0132 P0084 O2 sensor (Bank 1, Sensor 1) high voltage
    P0133 P0085 O2 Sensor (Bank 1, Sensor 1) - Slow Response / Response /
    P0134 P0086 O2 Sensor (Bank 1, Sensor 1) - not active
    P0135 P0087 O2 Sensor Heater (Bank 1 Sensor 1) - Malfunction
    P0136 P0088 O2 Sensor (Bank 1, Sensor 2) - Malfunction
    P0137 P0089 O2 Sensor (Bank 1, Sensor 2) Voltage Low
    P0138 P008A The O2 Sensor (Bank 1, Sensor 2) Voltage High
    P0139 P008B O2 Sensor (Bank 1, Sensor 2) responding slowly
    P0140 P008C The O2 Sensor (Bank 1, Sensor 2) - not active
    P0141 P008D O2 Sensor Heater (Bank 1 Sensor 2) - Malfunction
    P0142 P008E The O2 Sensor (Bank 1, Sensor 3) - Malfunction
    P0143 P008F O2 Sensor (Bank 1, Sensor 3) Voltage Low
    P0144 P0090 O2 sensor (Bank 1, Sensor 3) high voltage
    P0145 P0091 O2 Sensor (Bank 1, Sensor 3) Slow Response
    P0146 P0092 O2 sensor (Bank 1, Sensor 3) - no activity
    P0147 P0093 O2 Sensor Heater (Bank 1 Sensor 3) - Malfunction
    P0150 P0096 O2 Sensor (Bank 2, Sensor 1) - Malfunction
    P0151 P0097 O2 Sensor (Bank 2, Sensor 1) Voltage Low
    P0152 P0098 O2 Sensor (Bank 2, Sensor 1) Voltage High
    P0153 P0099 O2 Sensor (Bank 2, Sensor 1) responding slowly
    P0154 P009A O2 Sensor (Bank 2, Sensor 1) - not active
    P0155 P009B O2 Sensor Heater (Bank 2 Sensor 1) - Malfunction
    P0156 P009C The O2 Sensor (Bank 2, Sensor 2) - Malfunction
    P0157 P009D O2 Sensor (Bank 2, Sensor 2) Voltage Low
    P0158 P009E The O2 Sensor (Bank 2, Sensor 2) Voltage High
    P0159 P009F The O2 Sensor (Bank 2, Sensor 2) responds slowly
    P0160 P00A0 The O2 sensor (Bank 2, Sensor 2) - no activity
    P0161 P00A1 O2 Sensor Heater (Bank 2 Sensor 2) - Malfunction
    P0162 P00A2 O2 Sensor (Bank 2, Sensor 3) - Malfunction
    P0163 P00A3 O2 Sensor (Bank 2, Sensor 3) Voltage Low
    P0164 P00A4 The O2 Sensor (Bank 2, Sensor 3) Voltage High
    P0165 P00A5 O2 Sensor (Bank 2, Sensor 3) Slow Response
    P0166 P00A6 O2 Sensor (Bank 2, Sensor 3) - no activity
    P0167 P00A7 O2 Sensor Heater (Bank 2 Sensor 3) - Malfunction
    P0170 P00AA O2 Sensor (Bank 1) - Fuel Trim Malfunction
    P0171 P00AB O2 Sensor (Bank 1) - Mixture too lean
    P0172 P00AC O2 Sensor (Bank 1) too rich mixture
    P0173 P00AD O2 Sensor (Bank 2) - Fuel Trim Malfunction
    P0174 P00AE O2 Sensor (Bank 2) - mixture too lean
    P0175 P00AF O2 Sensor (Bank 2) - mixture too rich
    P0176 P00B0 Fuel Composition Sensor - Malfunction
    P0177 P00B1 Fuel Composition Sensor - Signal Out of Range / Performance
    P0178 P00B2 Fuel Composition Sensor - Low input
    P0179 P00B3 Fuel Composition Sensor - High Input
    P0180 P00B4 Fuel temperature sensor A malfunction
    P0181 P00B5 Fuel temperature sensor A - signal out of range / performance
    P0182 P00B6 Fuel temperature sensor A - low input
    P0183 P00B7 Fuel temperature sensor A - high input
    P0184 P00B8 Fuel temperature sensor A - interruption
    P0185 P00B9 Fuel temperature sensor B - malfunction
    P0186 P00BA Fuel temperature sensor B - signal out of range / performance
    P0187 P00BB Fuel temperature sensor B - low input
    P0188 P00BC Fuel temperature sensor B - high input
    P0189 P00BD Fuel temperature sensor B - interruption
    P0190 P00BE Fuel tank pressure sensor (rail) - malfunction
    P0191 P00BF Fuel tank pressure sensor (rail) - signal out of range / performance
    P0192 P00C0 Fuel tank pressure sensor (rail) - low input
    P0193 P00C1 Fuel tank pressure sensor (rail) - high input
    P0194 P00C2 Fuel rail pressure sensor - open
    P0195 P00C3 Engine Oil Temperature Sensor - Malfunction
    P0196 P00C4 Engine oil temperature sensor - signal out of range / performance
    P0197 P00C5 Engine oil temperature sensor - low input
    P0198 P00C6 Engine oil temperature sensor - high input
    P0199 P00C7 Engine oil temperature sensor interruption
    P0200 P00C8 Injector Circuit - Malfunction
    P0201 P00C9 Injector 1 Circuit Malfunction
    P0202 P00CA Injector 2 circuit - malfunction
    P0203 P00CB Injector 3 Circuit Malfunction
    P0204 P00CC Injector 4 cylinder circuit malfunction
    P0205 P00CD Injector 5 Circuit - Malfunction
    P0206 P00CE Injector circuit 6 cylinder malfunction
    P0207 P00CF Injector 7 Circuit Malfunction
    P0208 P00D0 Injector circuit 8 cylinder malfunction
    P0209 P00D1 Injector circuit 9 cylinder malfunction
    P0210 P00D2 Injector circuit 10 cylinder malfunction
    P0211 P00D3 Injector Circuit Cylinder 11 - Malfunction
    P0212 P00D4 Injector circuit 12 cylinder malfunction
    P0213 P00D5 Injector 1 Cold Start - Malfunction
    P0214 P00D6 Injector 2 Cold Start - Malfunction
    P0215 P00D7 Engine Cutoff Solenoid / Coil malfunction
    P0216 P00D8 Injection Timing Control System Malfunction
    P0217 P00D9 Engine overtemperature condition
    P0218 P00DA Overtemp condition of the gearbox
    P0219 P00DB Engine overspeed condition
    P0220 P00DC Throttle / Pedal Position Sensor / Switch B Malfunction
    P0221 P00DD Throttle / Pedal Position Sensor / Switch B Signal Out of Range / Performance
    P0222 P00DE Throttle / Pedal Position Sensor / Switch B - Low input
    P0223 P00DF Throttle / Pedal Position Sensor / Switch B - High input
    P0224 P00E0 Throttle / Pedal Position Sensor / Switch B - Break
    P0225 P00E1 Throttle / Pedal Position Sensor / Switch C Malfunction
    P0226 P00E2 Throttle / Pedal Position Sensor / Switch C Signal Out of Range / Performance
    P0227 P00E3 Throttle / Pedal Position Sensor / Switch C - Low input
    P0228 P00E4 Throttle / Pedal Position Sensor / Switch C - High Input
    P0229 P00E5 Throttle / pedal position sensor / switch C - break
    P0230 P00E6 Fuel pump primary circuit malfunction
    P0231 P00E7 Fuel pump secondary circuit - signal low
    P0232 P00E8 Fuel pump secondary circuit - signal high
    P0233 P00E9 Fuel pump, secondary circuit open
    P0234 P00EA Overcharge / Overcharge / Engine condition
    P0235 P00EB Turbocharger boost sensor A - malfunction
    P0236 P00EC Turbocharger Boost Sensor A - Signal Out of Range / Performance
    P0237 P00ED Turbocharger boost sensor A - low input
    P0238 P00EE Turbocharger boost sensor A - high input
    P0239 P00EF Turbocharger boost sensor B malfunction
    P0240 P00F0 Turbocharger boost sensor B - signal out of range / performance
    P0241 P00F1 Turbocharger boost sensor B - low input
    P0242 P00F2 Turbocharger boost sensor B - high input
    P0243 P00F3 Turbocharger Wastegate Solenoid A - Malfunction
    P0244 P00F4 Turbocharger Wastegate Solenoid A - Signal Out of Range / Performance
    P0245 P00F5 Turbocharger exhaust solenoid A - low signal
    P0246 P00F6 Turbocharger exhaust solenoid A - signal high
    P0247 P00F7 Turbocharger Throttle Solenoid B - Malfunction
    P0248 P00F8 Turbocharger Wastegate Solenoid B - Signal Out of Range / Performance
    P0249 P00F9 Turbocharger Wastegate Solenoid B - Low signal
    P0250 P00FA Turbocharger exhaust solenoid B - signal high
    P0251 P00FB A fuel pump rotor / cam - malfunction
    P0252 P00FC A fuel pump rotor / cam - signal out of range / performance
    P0253 P00FD A fuel pump rotor / cam - low signal
    P0254 P00FE A fuel pump rotor / cam - signal high
    P0255 P00FF A injection pump rotor / cam - open
    P0256 P0100 B injection pump rotor / cam - malfunction
    P0257 P0101 B injection pump rotor / cam - signal out of range / performance
    P0258 P0102 B injection pump rotor / cam - low signal
    P0259 P0103 B injection pump rotor / cam - signal high
    P0260 P0104 B injection pump rotor / cam - open
    P0261 P0105 Cylinder 1 injector low signal
    P0262 P0106 Cylinder 1 injector signal high
    P0263 P0107 Cylinder 1 - Share / Balance Error
    P0264 P0108 Cylinder 2 injector low signal
    P0265 P0109 Cylinder 2 injector signal high
    P0266 P010A Cylinder 2 - Share / Balance Error
    P0267 P010B Cylinder 3 injector - low signal
    P0268 P010C Cylinder 3 injector signal high
    P0269 P010D Cylinder 3 - Contribution / balance error
    P0270 P010E Cylinder 4 injector - signal low
    P0271 P010F Cylinder 4 injector signal high
    P0272 P0110 Cylinder 4 - Share / Balance Error
    P0273 P0111 Cylinder 5 injector - low signal
    P0274 P0112 Cylinder 5 injector signal high
    P0275 P0113 Cylinder 5 - Contribution / Balance Error
    P0276 P0114 Cylinder 6 injector - low signal
    P0277 P0115 Cylinder 6 injector signal high
    P0278 P0116 Cylinder 6 - Contribution / Balance Error
    P0279 P0117 Cylinder 7 injector - low signal
    P0280 P0118 Cylinder 7 injector signal high
    P0281 P0119 Cylinder 7 - Contribution / balance error
    P0282 P011A Cylinder 8 injector - low signal
    P0283 P011B Cylinder 8 injector signal high
    P0284 P011C Cylinder 8 - Contribution / balance error
    P0285 P011D Cylinder 9 injector - low signal
    P0286 P011E Cylinder 9 injector - signal high
    P0287 P011F Cylinder 9 - Contribution / balance error
    P0288 P0120 Cylinder 10 injector - signal low
    P0289 P0121 Cylinder 10 injector signal high
    P0290 P0122 Cylinder 10 - Contribution / Balance Error
    P0291 P0123 Cylinder 11 injector low signal
    P0292 P0124 Cylinder 11 injector signal high
    P0293 P0125 Cylinder 11 - Share / Balance Error
    P0294 P0126 Cylinder 12 injector low signal
    P0295 P0127 Cylinder 12 injector signal high
    P0296 P0128 Cylinder 12 - Contribution / Balance Error
    P0300 P012C Random / multiple misfire detected in cylinders
    P0301 P012D Cylinder 1 - Misfire detected
    P0302 P012E Cylinder 2 - Misfire detected
    P0303 P012F Cylinder 3 - Misfire detected
    P0304 P0130 Cylinder 4 Misfire Detected
    P0305 P0131 Cylinder 5 - Misfire detected
    P0306 P0132 Cylinder 6 - Misfire detected
    P0307 P0133 Cylinder 7 - Misfire detected
    P0308 P0134 Cylinder 8 - Misfire detected
    P0309 P0135 Cylinder 9 - Misfire detected
    P0310 P0136 Cylinder 10 - Misfire detected
    P0311 P0137 Cylinder 11 - Misfire detected
    P0312 P0138 Cylinder 12 - Misfire detected
    P0320 P0140 Engine Speed Input Circuit for Distribution / Ignition - Malfunction
    P0321 P0141 Engine Speed Input Circuit for Distributor / Ignition Signal Out of Range / Performance
    P0322 P0142 Engine Speed Input Circuit for Distributor / Ignition - No Signal
    P0323 P0143 Engine Speed Input Circuit for Distribution / Ignition - Open
    P0325 P0145 Knock Sensor 1 (Bank 1 or Single Sensor) - malfunction
    P0326 P0146 Knock Sensor 1 (Bank 1 or Single Sensor) - Signal Out of Range / Performance
    P0327 P0147 Knock Sensor 1 (Bank 1 or Single Sensor) low input
    P0328 P0148 Knock Sensor 1 (Bank 1 or Single Sensor) - High Input
    P0329 P0149 Knock Sensor 1 (Bank 1 or Single Sensor) - interruption
    P0330 P014A Knock Sensor 2 (Bank 2) - Malfunction
    P0331 P014B Knock Sensor 2 (Bank 2) - Signal Out of Range / Performance
    P0332 P014C Knock Sensor 2 (Bank 2) - Low input
    P0333 P014D Knock Sensor 2 (Bank 2) - high input
    P0334 P014E Knock Sensor 2 (Bank 2) - Interruption
    P0335 P014F Crankshaft Position Sensor A - Malfunction
    P0336 P0150 Crankshaft Position Sensor A - Signal out of range
    P0337 P0151 Crankshaft Position Sensor A - Low input
    P0338 P0152 Crankshaft Position Sensor A - A high input
    P0339 P0153 A crankshaft position sensor - open
    P0340 P0154 Camshaft Position Sensor - Malfunction
    P0341 P0155 Camshaft Position Sensor - Signal Out of Range / Performance
    P0342 P0156 Camshaft Position Sensor - Low input
    P0343 P0157 Camshaft Position Sensor - A high input
    P0344 P0158 Camshaft Position Sensor - Interruption
    P0350 P015E Ignition coil primary / secondary circuit malfunction
    P0351 P015F Ignition Coil A Primary / Secondary Circuit Malfunction
    P0352 P0160 Ignition Coil B Primary / Secondary Circuit Malfunction
    P0353 P0161 Ignition Coil C Primary / Secondary Circuit Malfunction
    P0354 P0162 Ignition Coil D Primary / Secondary Circuit Malfunction
    P0355 P0163 E Ignition Coil Primary / Secondary Circuit Malfunction
    P0356 P0164 F Ignition Coil Primary / Secondary Circuit Malfunction
    P0357 P0165 G ignition coil primary / secondary circuit malfunction
    P0358 P0166 H ignition coil primary / secondary circuit malfunction
    P0359 P0167 Ignition Coil I Primary / Secondary Circuit Malfunction
    P0360 P0168 Ignition Coil J Primary / Secondary Circuit Malfunction
    P0361 P0169 K Ignition Coil Primary / Secondary Circuit Malfunction
    P0362 P016A Ignition Coil Primary / Secondary Circuit Malfunction
    P0370 P0172 Timing Reference A High Resolution Malfunction
    P0371 P0173 Timed Reference A High Resolution - Too Many Pulses
    P0372 P0174 Time Reference A High Resolution - Too Few Pulses
    P0373 P0175 Timed Reference A High Resolution Pulse Faulty / Pause
    P0374 P0176 Timed Reference A High Resolution - No Pulses
    P0375 P0177 Timing Reference B High Resolution Malfunction
    P0376 P0178 Time Reference B High Resolution - Too Many Pulses
    P0377 P0179 Time reference signal B high resolution - too few pulses
    P0378 P017A Timed reference signal B high resolution - pulses faulty / break
    P0379 P017B High Resolution Timed Reference B - No Pulses
    P0380 P017C Heater / Glow Plug Circuit - Malfunction
    P0381 P017D Heater / Glow Plug Indicator Circuit - Malfunction
    P0382 P017E B Heater / Glow Plug Circuit Malfunction
    P0385 P0181 Crankshaft Position Sensor B - Malfunction
    P0386 P0182 Crankshaft position sensor B - signal out of range / performance
    P0387 P0183 Crankshaft Position Sensor B - Low input
    P0388 P0184 Crankshaft Position Sensor B - high input
    P0389 P0185 Crankshaft Position Sensor B - Open
    P0400 P0190 Exhaust Gas Recirculation - Wrong flow
    P0401 P0191 Exhaust Gas Recirculation - Insufficient Flow Detected
    P0402 P0192 Exhaust gas recirculation - excessive flow detected
    P0403 P0193 Exhaust Gas Recirculation - Malfunction
    P0404 P0194 Exhaust gas recirculation - signal out of range / performance
    P0405 P0195 Exhaust gas recirculation sensor A - low input
    P0406 P0196 Exhaust gas recirculation sensor A - high input
    P0407 P0197 Exhaust gas recirculation sensor B - low input
    P0408 P0198 Exhaust gas recirculation sensor B - high input
    P0410 P019A Secondary Air Injection System Malfunction
    P0411 P019B Secondary Air Injection System - Incorrect flow detected
    P0412 P019C Secondary Air Injection System A Shift Valve Malfunction
    P0413 P019D Secondary Air Injection System A Change-Over Valve Open
    P0414 P019E Secondary air injection system changeover valve A short circuit
    P0415 P019F Secondary Air Injection System B Shift Valve Malfunction
    P0416 P01A0 Secondary Air Injection System Switching Valve B Interrupt
    P0417 P01A1 Secondary Air Injection System Switching Valve B Short Circuit
    P0418 P01A2 Secondary Air Injection System Relay A Malfunction
    P0419 P01A3 Secondary Air Injection System Relay B Malfunction
    P0420 P01A4 Catalyst System (Bank 1) Performance Below Threshold
    P0421 P01A5 Catalyst hot (Bank 1) - performance below threshold
    P0422 P01A6 Main Catalyst (Bank 1) - Performance Below Threshold
    P0423 P01A7 Heated catalyst (Bank 1) - performance below threshold
    P0424 P01A8 Heated catalyst (Bank 1) - temperature below threshold
    P0430 P01AE Catalyst System (Bank 2) - Performance Below Threshold
    P0431 P01AF Catalyst hot (bank 2) - performance below threshold
    P0432 P01B0 Main Catalyst (Bank 2) - Performance Below Threshold
    P0433 P01B1 Heated catalyst (bank 2) - performance below threshold
    P0434 P01B2 Heated catalyst (Bank 2) - temperature below threshold
    P0440 P01B8 Vapor Evaporation System Malfunction
    P0441 P01B9 Fuel vapor discharge system - wrong purge flow
    P0442 P01BA Vapor removal system - leak detected (small)
    P0443 P01BB Fuel vapor exhaust system, purge valve control circuit - malfunction
    P0444 P01BC Vapor exhaust system, purge valve control circuit - break
    P0445 P01BD Fuel vapor exhaust system, purge valve control circuit - short circuit
    P0446 P01BE Vapor removal system, fan circuit - malfunction
    P0447 P01BF Vapor removal system, fan circuit - break
    P0448 P01C0 Vapor removal system, fan circuit - short circuit
    P0449 P01C1 Vapor Evaporation System - Faulty Servo Motor / Winding for Vent Valve
    P0450 P01C2 Evaporative emission system, pressure sensor malfunction
    P0451 P01C3 Evaporative emission system, pressure sensor signal out of range / performance
    P0452 P01C4 Evaporative emission system, pressure sensor - low input
    P0453 P01C5 Evaporative emission system, pressure sensor - high input
    P0454 P01C6 Evaporative emission system, pressure sensor interruption
    P0455 P01C7 Vapor Evaporation System - Leak Detected (Major)
    P0456 P01C8 Vapor removal system - leak detected (very small)
    P0460 P01CC Fuel Level Sensor - Malfunction
    P0461 P01CD Fuel Level Sensor - Signal Out of Range / Performance
    P0462 P01CE Fuel Level Sensor - Low input
    P0463 P01CF Fuel Level Sensor - High Input
    P0464 P01D0 Fuel Level Sensor - Interruption
    P0465 P01D1 Wastewater flow sensor. - malfunction
    P0466 P01D2 Wastewater flow sensor - signal out of range / performance
    P0467 P01D3 Wastewater flow sensor. - low input signal
    P0468 P01D4 Wastewater flow sensor. - high input signal
    P0469 P01D5 Wastewater flow sensor - break
    P0470 P01D6 Discharge Pressure Sensor - Malfunction
    P0471 P01D7 Discharge pressure sensor - signal out of range / performance
    P0472 P01D8 Discharge pressure sensor - low input
    P0473 P01D9 Discharge pressure sensor - high input
    P0474 P01DA Discharge Pressure Sensor - Interruption
    P0475 P01DB Discharge Pressure Control Valve - Malfunction
    P0476 P01DC Outlet Pressure Control Valve - Signal Out of Range / Performance
    P0477 P01DD Discharge pressure control valve - low input
    P0478 P01DE Discharge Pressure Control Valve - high input
    P0479 P01DF Discharge Pressure Control Valve open
    P0480 P01E0 Cooling Fan 1 Control Circuit Malfunction
    P0481 P01E1 Cooling Fan 2 Control Circuit - Malfunction
    P0482 P01E2 Cooling Fan Control Circuit 3 - Malfunction
    P0483 P01E3 Cooling fan circuit - rationality check
    P0484 P01E4 Cooling Fan Circuit - Overcurrent
    P0485 P01E5 Cooling Fan Power / Ground Circuit Malfunction
    P0500 P01F4 Vehicle Speed Sensor - Malfunction
    P0501 P01F5 Vehicle Speed Sensor - Signal Out of Range / Performance
    P0502 P01F6 Vehicle Speed Sensor - Low input
    P0503 P01F7 Vehicle speed sensor - signal high / faulty / intermittent
    P0505 P01F9 Idle adjustment system - malfunction
    P0506 P01FA Idle control system - RPM lower than expected
    P0507 P01FB Idle control system - RPM higher than expected
    P0510 P01FE Closed Throttle Position Switch - Malfunction
    P0520 P0208 Engine Oil Pressure Switch - Malfunction
    P0521 P0209 Engine oil pressure switch - signal out of range / performance
    P0522 P020A Engine Oil Pressure Switch - Low input
    P0523 P020B Engine oil pressure switch - high input
    P0530 P0212 A / C Refrigerant Pressure Sensor - Malfunction
    P0531 P0213 A / C Refrigerant Pressure Sensor - Signal Out of Range / Performance
    P0532 P0214 A / C Refrigerant Pressure Sensor - Low input
    P0533 P0215 A / C Refrigerant Pressure Sensor - High input
    P0534 P0216 Loss of A / C refrigerant charge
    P0540 P021C Intake air heater control system - malfunction
    P0541 P021D Intake air heater control system low signal
    P0542 P021E Intake air heater control system - signal high
    P0550 P0226 Power steering pressure sensor malfunction
    P0551 P0227 Power steering pressure sensor - signal out of range / performance
    P0552 P0228 Power steering pressure sensor - low input
    P0553 P0229 Power steering pressure sensor - high input
    P0554 P022A Power steering pressure sensor interruption
    P0560 P0230 System Supply Voltage - Malfunction
    P0561 P0231 System supply voltage - signal unstable
    P0562 P0232 System Supply Voltage - Signal Low
    P0563 P0233 System supply voltage - signal high
    P0565 P0235 Steering system speed, signal ON - fault
    P0566 P0236 Steering system speed, signal OFF - fault
    P0567 P0237 Steering system speed, RESUME signal malfunction
    P0568 P0238 Steering system speed, SET signal malfunction
    P0569 P0239 Steering system speed, COAST signal malfunction
    P0570 P023A Steering system speed, ACCEL signal - malfunction
    P0571 P023B Steering system speed / brake switch A - malfunction
    P0572 P023C Steering system speed / switch A brake - low input
    P0573 P023D Rudder system speed / switch A brake - high input
    P0574 P023E Steering system speed (Cruise Control)
    P0575 P023F Steering system speed (Cruise Control)
    P0576 P0240 Steering system speed (Cruise Control)
    P0577 P0241 Steering system speed (Cruise Control)
    P0578 P0242 Steering system speed (Cruise Control)
    P0579 P0243 Steering system speed (Cruise Control)
    Here I am sending some errors, then I will send the rest, just let me know when you develop all of them.
  • #3 17175275
    keseszel
    Help: 54
    Rate: 558
    Buddy, thank you very much but I don't have Lexi, unfortunately ... I read the error codes in Opel with a well-known jumper method. Rather, nothing can be done without a computer connection.
    pepe150
    Level 36  
    Help: 288
    Rate: 939
    But you don't need Lexia to read the errors right away.
    Some WOW, Delphi or KTS will read the errors.
    Without it, we will not advise you anything.
  • #5 17209747
    keseszel
    Help: 54
    Rate: 558
    So far I'm driving and I'm happy with the color orange .. ?
    Today I was able to delete the orange control with Elm327 on bluetooth. I deleted it several times with different programs. I think I also read errors. I will check the records and try to throw print screens. I know that deleting the light could not do much, because this error appeared from somewhere. The most fun was connecting to the Elm327 in the parking lot, because I didn't even know that so many TV sets nearby have the Blue option turned on. ?
  • #6 17224962
    keseszel
    Help: 54
    Rate: 558
    Unfortunately, the problem returned after deleting with Elm327 and probably Torque.
    I got error messages, unfortunately I can't read them. I will try to attach screenshots from the phone.
    Again the problem appeared after a few minutes of driving. The car clearly has a mule in my opinion. The indicator light is on again. The first thing I would do is check the saved errors, then the lambda probes.
    Citroen Xsara Picasso 1.8 2002 Pb / Lpg - Orange engine light is on. Citroen Xsara Picasso 1.8 2002 Pb / Lpg - Orange engine light is on. Citroen Xsara Picasso 1.8 2002 Pb / Lpg - Orange engine light is on. Citroen Xsara Picasso 1.8 2002 Pb / Lpg - Orange engine light is on.
    Honestly, I don't remember too much where these lambdas ... They should be 4 pin, the angle has been cut for years.
  • #7 17438446
    keseszel
    Help: 54
    Rate: 558
    The errors are P0141, I suspect the lambda probe after the catalyst, the second. And a strange error P0440, I don't understand it. Rather, it should not be present with gasoline ..
  • #9 17465589
    keseszel
    Help: 54
    Rate: 558
    I left the orange light let it shine. I will have time and I would like to search the cables.
  • #10 17949774
    keseszel
    Help: 54
    Rate: 558
    Finally, I decided to take a chance and buy a lambda probe. After replacing, I canceled the orange light using the Android and ELM327 application. Disconnecting the battery or starting the car several times after replacing the lambda probe does not do anything. More detailed information in my other lambda probe topic. Finally, I have peace of mind with this control.
✨ The discussion revolves around a Citroen Xsara Picasso 1.8 (2002) experiencing an orange engine light activation, which appeared after starting the vehicle. The user noted a gasoline smell and previous power steering issues. They inquired about the potential causes, including injection, ignition, or exhaust aftertreatment system faults, and whether the light would reset automatically after resolving the issue. Various responses highlighted the importance of error code reading, suggesting tools like Lexia, WOW, Delphi, or KTS for diagnostics. The user attempted to clear the light using an ELM327 Bluetooth device but faced recurring issues, particularly with lambda probes and error codes P0141 and P0440. Ultimately, after replacing the lambda probe, the user successfully cleared the engine light and resolved the issue.
