[Solved] Configuring Universal Remote Control for Electric Skateboard: First-time Setup and Troubleshooting
wojpo7 10146 5
  • #1 16631201
    wojpo7
    Rate: 20
    Hello. In case I ask for your understanding because I am here for the first time. . a few days ago I bought an electric board for my son - the seller in the description stated that the board also has a remote control. Unfortunately, after receiving the remote control does not react with the board - I was told that it is not configured with the board. I am asking for information on how to do it. Below p [I present the photo of the pilot. Standard - 4 buttons (opening, closing, alarm and one more). Please help Configuring Universal Remote Control for Electric Skateboard: First-time Setup and Troubleshooting Configuring Universal Remote Control for Electric Skateboard: First-time Setup and Troubleshooting
    • Configuring Universal Remote Control for Electric Skateboard: First-time Setup and Troubleshooting pilot.png (124.32 KB) You must be logged in to download this attachment.
  • #2 16631207
    wojpo7
    Rate: 20
  • #3 16631338
    1 PAWEL
    Help: 674
    Rate: 1365
    Maybe you could give what model the board symbol name is.
    Mode of action HB2
    ? Step 1: to start HB2, press the switch (on the device or on the remote control).
    ? Cork 2: To prepare for riding, step on the pedal with one foot to activate the system. The indicator light will turn on and the system will activate a state of automatic balance. After starting the automatic balance system, you can put a second foot on the pedals to start the vehicle.
    ? Step 3: After the HB2 vehicle has been successfully started and the balance has been reached, the user should keep the center of gravity in balance, which will keep the vehicle stationary. Then, by properly bending the body you can control the movement of the vehicle. Bending the body forward will move the vehicle forward and tilting the body backward will cause the vehicle to reverse. However, be careful that the body movement is not too intense. .
    • 1 HB2instrukcje.pdf (3.91 MB) You must be logged in to download this attachment.
  • #4 16631795
    wojpo7
    Rate: 20
    It is just that "this something" has no name - only SMART BALANCE WHEEL is on the box
  • #6 17564033
    wojpo7
    Rate: 20
    I sold a board
