D-Link DWR-116 Firmware Update Issue - Router Hanging, Disconnecting, Losing Range, LEDs On
sebios1 7155 2
  • Firmware update appears to have bricked the DWR-116
    #1 16811865
    sebios1
    for some time DWR-116 began to hang, disconnect, lose range so I decided to update the router firmware to improve its performance. I followed the instructions on the manufacturer's website. before, I downloaded the current software, then step by step carried out the update, until the message that the update has appeared appears. And everything died in this place. nothing works. LEDs on the router are lit up alternately with 2/3 (lights from ethernet cable sockets). otherwise nothing works. What to do? how to start the router. In writing in the browser, the access address gives nothing
  • #2 16812176
    jimasek
    Help: 3783
    Rate: 2683
    Look for the topics "DWR-116 unbrick", "DWR-116 recovery" and you probably can't do without the UART interface.
  • #3 16814451
    KOCUREK1970
    Help: 3869
    Rate: 5505
    Well, it is probably not the fault of the wrong software, but incorrectly supported software from a different model, hardware version, branding, etc.
    sebios1 wrote:
    I downloaded the current software before
    Which and from where and what was previously in the router?
