D-Link DWR 921 Router: Non-Responsive Post-Reset Issues
eryk2010 16299 9
How can I recover a D-Link DWR-921 router that no longer responds after a reset and cannot be accessed in the browser?
Recover the router by flashing the original D-Link firmware in Emergency mode if the reset seems to have corrupted it [#17244736] Set the computer manually to 192.168.0.X with subnet mask 255.255.255.0, connect by Ethernet only, and unplug the router’s power [#17244736] Hold the reset button, plug the power back in when the power LED starts flashing orange, then release reset and open 192.168.0.1 in the browser [#17244736] The emergency upgrade page should appear, and you can upload only the correct D-Link factory image for that router model/version [#17244736] After uploading, wait a couple of minutes until the orange light stops flashing and the router reboots [#17244736]
  • #1 16779034
    eryk2010
    I have recently reset the router, but it got so bad that I can't do anything with it now.
    Please help.
    Does not respond to reset or anything else.
  • #2 16779053
    nici
    Help: 266
    Rate: 979
    Make a hard reset
  • #3 16779157
    serwisor
    Help: 96
    Rate: 164
    Did you reset how, for what purpose?
    Did he get this "push" on some particular action?
    Change of parameters? Software update?
    Disconnecting the power supply for a long time (~ 10-15min) will give you any results?
  • #4 16779167
    eryk2010
    nothing works because the internet has stopped working even a week has been lying down and I can't go to it ip
    Added after 57 [seconds]:
    and nothing reacts
  • #5 16779234
    serwisor
    Help: 96
    Rate: 164
    I understand that you want help as soon as possible, but I don't quite understand what you mean in your speech!
    Work on spelling and punctuation.
    I understand that the week was disconnected, OK.
    What operation did he hang up?
    What were you doing with him then? Update? change of parameters?
    Is the internet connected to another device working properly?
    What happens to the device?
    How do you connect to it?
    What "are" IPs that you cannot enter and what you "enter" through?
    Have you checked his online presence? can't you login via browser?
    Answer ALL questions, but syntactically, we'll slowly come to something ... I think.
  • #6 16779246
    jimasek
    Help: 3783
    Rate: 2681
    Only you don't need internet access to configure the router. All you need is a web browser and a network connection.
  • #7 16781555
    eryk2010
    During the reset
    I put it off and left him and did nothing because I can't do anything
    on others neither
    generally nothing but lights
    the lights are on the same as during the reset
    via wifi i can't via cable i can connect up but i don't have internet
    192.168.0.1 and nothing because I write no internet
    I can't login because I can't access the page
  • #8 16782357
    nici
    Help: 266
    Rate: 979
    eryk2010 wrote:
    During the reset
    on others neither
    This spelling is calling for vengeance to heaven, man Do you see it ???
    You don't need internet to log in.
  • #9 17242711
    marcinsz0
    Rate: 12
    Hello everyone
    I have the same problem as in the subject, the DWR-921 router worked properly but I wanted to reset the WIFI network settings, I pressed the reset button for a while and after this procedure it is impossible to log in to configure the router, there is no access through the browser, the network card does not detect the network. entering the address also does not help, only the power and 2G LEDs light up in the router, it does not detect connected network cables ....
    Any suggestions ?
    Thank you in advance for your help and best regards
  • #10 17244736
    krakarak
    Help: 681
    Rate: 1846
    Można spróbować wgrać firmware (zakładamy, że firmware w twoim routerze się uszkodziło) w trybie Emergency.
    Oczywiście wcześniej należy ściągnąć firmware dla właściwego modelu i wersji routera.
    Oto opis postępowania zaczerpnięty z sieci:
    1) Set your computer's ip manually to: 192.168.0.X (not 1) AND set your subnet mask to 255.255.255.0. (Auto IP will NOT work).
    2) Connect Ethernet cable between router and your computer. (Wireless won’t work)
    3) Unplug the power cable to the router
    4) Press the reset button and plug in the power cable when the power led flashes orange (about 15 seconds) release the reset. Go to 192.168.0.1. You will see the emergency mode upgrade screen in the browser
    5)You can upload only Dlink factory image. Download Dlink factory image from Dlink support
    6) Upload dlink firmware and wait at-least couple of minutes. The orange button should stop flashing and the router will reboot.
The discussion revolves around issues faced with the D-Link DWR 921 router after a reset, where users report being unable to access the router's configuration interface or establish an internet connection. Suggestions include performing a hard reset, disconnecting the power supply for an extended period, and ensuring proper network settings. One user describes a scenario where the router only shows power and 2G LEDs lit, indicating a potential firmware issue. A detailed recovery procedure is provided, which involves manually setting the computer's IP, connecting via Ethernet, and uploading the correct firmware in emergency mode to restore functionality.
