Passat B5 FL estate - Opening the tailgate from the remote control opens the rig
Piotr KLomfas 4980 2
  • #1 16669667
    Piotr KLomfas
    Rate: 21
    Central locking and factory alarm.
    After replacing the lock right / front:
    - car locked with remote control - active alarm, I open the tailgate with the remote control and at the same time opens the door front right, i.e. not correctly
    - sitting inside, I close the car with the remote control - active alarm, I can open the right front door from the inside, i.e. not correctly, and the other door not - i.e. correctly.
    My question is; is the right front lock malfunction a matter of control from the comfort module or is it the mechanical setting of the lock?
    Can the mechanical adjustment be marked in red in the photo as in the rear door, opening lock from the inside?
    Regards.
  • #2 16670121
    ociz
    Help: 1379
    Rate: 3486
    This is no regulation. Castle sell.
  • #3 16692501
    Piotr KLomfas
    Rate: 21
    After replacing the lock with a functional central one works properly.
    Thanks to a colleague.
