Best Soldering Irons with Temperature Control: GJ-093B vs ZD-708 vs UYUE-301D (50-60W, PLN 50-100)
Pawix03 6927 11
What cheap soldering iron or temperature-controlled station should I buy for occasional hobby electronics work, around PLN 50–100?
Skip those three budget irons; the thread recommends a 936/937-style station or, better, a Hakko T12-based soldering iron/station. The three models you listed are criticized because the mains voltage is connected directly to the handle, the tip is not grounded, and they can be unsafe and damage electronics; one user also reports the handle getting hot and even a short-circuit/explosion [#16635918] For a cheap but more practical option, several replies suggest a 936, 937, 936a or 937d+ station, noting that these are common, have many available tips, and can be found for about PLN 68 [#16635895] Another recommendation is a T12-based setup, because the heater, temperature sensor and tip are integrated, which makes soldering much better; a Chinese T12 iron/station is said to cost about PLN 40 [#16635570][#16635918] If you only solder occasionally, a 936-type station is considered sufficient, but the consensus is to avoid the listed “invention” models and their poor temperature regulation and tip availability [#16635895]
  • #1 16635095
    Pawix03
    Hello, I would like to buy a soldering iron with temperature control up to about PLN 50-60, I wonder about:
    1. GJ-093B - 60w
    2. ZD-708 - 50w
    3. UYUE-301D - 60w
    What do you think? You can give other soldering irons or soldering stations up to PLN 100
  • #2 16635317
    Nori2
    Help: 64
    Rate: 109
    If you want to solder "on holiday", these soldering irons are OK.
    In practice, however, they are not very handy. A long and heavy stock (which houses all the electronics) is not practical for longer work.
    What is my suggestion? At the beginning, something from the 936 series. Soldering irons produced under different brands, with and without a (temperature) display, with a heater power of 50 - 75 W (if that's true). A wide selection of additional tips. They are on Allegro from PLN 68
  • #3 16635570
    noel200
    Help: 36
    Rate: 815
    I had 936. Badziewo. Get something with hakko t12 tips. They are great for soldering, and directly from China it costs PLN 40.
  • #4 16635720
    Pawix03
    I'm not looking for professional stations. I am a beginner, looking for something cheap, practical and universal. I'm gonna solder some little fuckers 1-2 times a week. And I'm interested in what you choose from among these 3. Maybe you have better ones at similar prices? :)
    maz9
    Level 19  
    Help: 16
    Rate: 67
    Go to 936, 937 or the more powerful 936a and e 937d + (75W in the peak heating element 60W) you have plenty of tips to buy later the cheapest and longest existing stations on the market. With proper soldering and using the right tip, you can desolder and solder everything, even with the 936 model. Don't get into inventions that are rare on the market. Then there are no arrowheads and how expensive they are.
    And when it comes to choosing from what you gave, all 3 oil and buy the cheapest of this type, you will pay PLN 20 because:
    -if you have to pay PLN 40, it is better to buy 936, with the least temperature regulation
    - as I mentioned about the regulation, I will add that in these types this regulation is to write that it has such
    Because I understand that it is more home, generally for everything, because the models you give are used for occasional, typical home repairs, and not for soldering twice or even once a day ... you write once or twice a week, so I go to amateur electronics here and this what you exchange is not suitable. Once a year, solder the cable, some minor repair on the knee, and your soldering irons.
    noel200
    Help: 36
    Rate: 815
    maz9 wrote:
    75W top heating element 60W
    And it is available with maybe 15W because the conductivity between the heater and the tip is negligible. In addition, after half an hour of soldering, the whole handle is hot, it is impossible to work and you have to take breaks.
    I also bought such a station following the suggestions from the forum.
    The t12 tip is full of abundance, and soldering equipment where the heater, temperature sensor and tip are one is incomparably better than the one where the tip is separate from the heater.
    No. All models have mains voltage connected directly to the handle, which is a bad solution. One that it is dangerous, two that such soldering irons kill electronics. The heater is powered from the mains and the tip is not grounded (the plug has two pins). Unfortunately, I also had one. The one with the transparent handle. When I soldered the LEDs shone, and the integrated circuits stopped working. One day the handle made a short circuit, the whole handle in my hand exploded, and from the flash I thought I was blind. No more of that shit.
    Currently, I have two:
    https://ae01.alicdn.com/kf/HTB1slb_QVXXXXbXXV...ring-b-font-font-b-iron-b-font-for-font-b.jpg (Power supply to 24Vdc. For example power supply from some old IBM laptop.) And one DIY station with jbc tips. Currently, I have the beat: http://www.tme.eu/pl/details/jbc-c245906/groty-lutnicze/jbc-tools/c245-906/ But these tips start from PLN 100, and soldering is comparable to T12
    T12 tips: https://allegro.pl/kategoria/narzedzia-groty-...match=base-relevance-floki-5-nga-ele-1-1-0803
  • #7 16636131
    maz9
    Level 19  
    Help: 16
    Rate: 67
    There is no doubt that soldering with a tip in which there is a temperature sensor is a different story. But perhaps our colleague from the forum is not about that. It does not require quality, only soldering something there and not the price range and I do not know why you agree so with an option that does not apply to this topic.
    By the way, writing about the t12 tips that you gave from the link, they are not Hakko tips, maybe they fit Hakko but they are not Hakko tips.
  • #8 16636166
    noel200
    Help: 36
    Rate: 815
    Yes, these are not hakko arrowheads. They are substitutes. But they work, and the soldering iron I recommend costs PLN 40, so it fits the topic. The fact that he will rarely solder does not mean that he has to buy crap.
  • #9 16636401
    maz9
    Level 19  
    Help: 16
    Rate: 67
    So I straighten out what you wrote, you suggested Hakko and you are misleading.
    These are substitutes and they are of poor quality. From the descriptions of soldering irons, it is clear that they heat up a little shorter than 900m tips, total about 30 seconds. This is just something that Hakko quality feels like
    Hakko tips and the t12 that I have for sale for the Isolder 40 heat up to the operating temperature in 2 seconds.
    That is why it straightens others to see what and how.
    The thread rather says everything proposes to the author to close him before someone persuades him to use soldering irons for 5,000 for minor repairs at home :) )
  • #10 16638241
    Pawix03
    He's keeping an eye on GJ-903. The Zhaoxin soldering iron is therefore compatible with the 900m series tips. It has temperature control (not power) so it should be perfect for beginner to learn soldering
    Here is a video describing soldering irons (there are 3 parts)
    https://m.youtube.com/watch?v=rkb_URVeKzY
    What do you think? ;)
  • #11 16638341
    noel200
    Help: 36
    Rate: 815
    If you want to kill yourself and damage most of the electronics with surges, this soldering iron is for you.
  • #12 16638588
    Pawix03
    Thank you for the answers, I close the topic. :)
    One wants to kill himself xD
The discussion revolves around selecting a soldering iron with temperature control within a budget of PLN 50-100, specifically comparing the GJ-093B, ZD-708, and UYUE-301D models. Users express concerns about the practicality and quality of these models, suggesting alternatives like the 936 series, which is noted for its reliability and availability of tips. The importance of using soldering irons with integrated temperature sensors is emphasized, as well as the risks associated with models that connect mains voltage directly to the handle. Recommendations lean towards the 936 series for beginners, while cautioning against low-quality substitutes that may damage electronics. The conversation concludes with a humorous acknowledgment of the potential dangers of using subpar soldering equipment.
TL;DR: On a PLN 50–100 budget, skip mains‑powered pens and start with a 936‑type station or T12 tip handle; T12 tips "heat up to the operating temperature in 2 seconds," giving fast, stable joints. [Elektroda, maz9, post #16636401] Why it matters: This FAQ helps beginners choose a safe, effective temperature‑controlled iron without wasting money.
Which is best for a beginner: GJ-093B, ZD-708, or UYUE-301D?
Choose none of these if you’ll solder electronics weekly. They route mains voltage to the handle and often lack a grounded tip, risking parts and safety. A basic 936‑series station or a low‑voltage T12 handle offers safer isolation, steadier temperature, and better tip options for learning. “The fact that he will rarely solder does not mean that he has to buy crap.” [Elektroda, noel200, post #16636166]
Why do people recommend 936/937 stations at this price?
They’re inexpensive, widely cloned, and accept many tips. Users report 50–75 W heater claims and availability from ~PLN 68. For beginners, the separate control box keeps the handpiece light and practical for longer sessions. This balance of price, ergonomics, and ecosystem makes 936‑type stations a common first step. [Elektroda, Nori2, post #16635317]
What are T12 tips, and why are they praised?
T12 tips integrate the heater and temperature sensor right inside the tip. This design shortens heat path, improving response and recovery. One contributor notes these are “incomparably better” than separate‑heater setups and can be sourced around PLN 40, which fits tight budgets. [Elektroda, noel200, post #16635570]
Are 230 V plug-in temperature‑controlled pens safe for PCBs?
Many budget pens drive the heater directly from mains and often have ungrounded tips. Users report LED flicker, IC failures, and even a catastrophic handle short. For electronics, choose a 24 V handle or an isolated station with a grounded tip. [Elektroda, noel200, post #16635918]
Do T12 tips really heat faster than 900M tips?
Yes, a user reports genuine T12 reaching working temperature in about 2 seconds, whereas cheaper substitutes can take about 30 seconds. Faster heat translates to shorter dwell time and less pad damage. Quote: “heat up to the operating temperature in 2 seconds.” [Elektroda, maz9, post #16636401]
Is a 936 station powerful enough for hobby work?
For general through‑hole and small SMD, yes. A contributor says with the right tip and technique, you can solder and desolder “everything” on hobby boards. The wide, low‑cost tip selection helps you match thermal mass to the job. [Elektroda, maz9, post #16635895]
What does temperature control vs power control actually mean?
Temperature control uses a sensor to hold a set tip temperature; power control only adjusts input power, so temperature drifts with load. Forum advice favors true temperature control in 936/T12 systems for consistent joints and learning proper technique. [Elektroda, Nori2, post #16635317]
Are Zhaoxin and similar pens compatible with 900M tips?
Some models accept 900M‑series tips, which are common and inexpensive. However, users still warn these mains‑powered pens can be unsafe for electronics despite the convenient tip family. Consider isolated stations first. [Elektroda, Pawix03, post #16638241]
Edge case: will a budget 936 clone overheat in my hand?
One user reported the handle getting very hot after about 30 minutes, forcing breaks. Clones vary in build quality and thermal isolation. If sessions run long, favor a T12 handle or ensure your 936 clone has a well‑insulated grip. [Elektroda, noel200, post #16635918]
How do I start safely on ~PLN 100?
  1. Pick a 936/937‑type station or a 24 V T12 handle.
  2. Add a grounded tip and a few common tips (chisel, conical).
  3. Practice on scrap boards to learn dwell and temp settings. Users emphasized isolation, tip choice, and practice over flashy specs. [Elektroda, Nori2, post #16635317]
Can I learn with a cheap temperature‑controlled pen and upgrade later?
You could, but forum voices advise against pens with mains in the handle due to safety and ESD risks. Starting with a 936 or T12 keeps your parts safer and your skills transferable when you upgrade. [Elektroda, noel200, post #16635918]
Are low-cost T12 tips genuine Hakko?
Typically no. Sellers offer substitutes that fit Hakko‑style systems. Users note these work, but quality varies. If heat‑up is slow or plating thin, expect shorter life. Choose reputable vendors if possible. [Elektroda, noel200, post #16636166]
What tip families should beginners know: 900M vs T12?
900M tips are separate from the heater and sensor, common on older/clone stations. T12 integrates heater and sensor in the tip, improving response and recovery. Beginners benefit from T12’s stability and simpler thermal behavior. [Elektroda, noel200, post #16635918]
Do I need a display on my first station?
Not required. A contributor suggests early 936‑series stations with or without a display work for learning. Stability, isolation, and tip availability matter more than a screen at this budget. [Elektroda, Nori2, post #16635317]
What’s the main takeaway for the original shortlist?
For occasional hobby work, avoid GJ‑093B, ZD‑708, and UYUE‑301D due to mains‑in‑handle designs. Pick an isolated 936/937 or a 24 V T12 setup for safer, cleaner results and easier tip sourcing. [Elektroda, noel200, post #16635918]
