Renault Scenic I - Rear Wiper Intermittent Functionality: Diagnosing Pin Voltage & Wiring Issues
misiek_89 13947 9
Why does the rear wiper on a Renault Scenic I work intermittently, and how can the missing control pulse be fixed?
The fault is most likely the relay in the UCH under the steering wheel, not the stalk or the motor itself [#17167868][#17663386] One user fixed the same intermittent rear wiper by removing the relay in the middle/left-side UCH area, identifying it as the third relay from the row with marking "p1cno10n," and replacing it with an external 8 A relay wired to the remaining pads [#17663386] Another reply also suggested the motor’s zero-position/contact signal may be involved, but the only confirmed repair in the thread was replacing/reworking that UCH relay [#17168372][#17663386] If the motor runs when pins are bridged and the relay clicks but no pulse appears on the output, the relay contact/soldering is the first thing to inspect [#17167868][#17663386]
  • #1 17167838
    misiek_89
    Rate: 118
    There has recently been a problem with the rear window wiper not always working. After switching on, the wiper can work e.g. 5x and then stops, it suddenly works again, etc. It just works as it pleases. My observations and initial diagnostics:
    - after switching on the ignition on the pin 1 (in the photo) appears + 12V not dependent on the position of the wiper handle,
    - on pin 4 there is a transition to the body weight,
    - when the wiper is working properly, pin 3 appears by + 12V pulse and pin 2 is constant voltage + 12V until the wiper makes a full movement, then again impulse appears on pin 3 and the cycle repeats (i.e. at that moment everything OK),
    - when the wiper does not work (and should) on pin 1 is +12, but on pins 3 and 2 there is no voltage,
    - after shorting pins 1-2 or 1-3, the wiper works every time, i.e. the engine is rather fine,
    - when the wiper does not walk, even switching on the front wipers + reverse does not help, so the handle is rather good,
    - each time you turn the rear wiper switch, you hear a relay under the steering wheel (even when the wiper is not working).
    To sum up, the problem is the lack of impulse on pin 3 which allows the wiper to work. I tried to move the plugs in the tailgate, I moved the bundles, but it has no effect. What else can I check? Can it be fixed somehow?
  • #2 17167868
    olo114
    Help: 14
    Rate: 95
    Probably the relay, the one that can be heard.
  • #3 17168122
    misiek_89
    Rate: 118
    Is this a replaceable part? Is it built into some module? I read somewhere about bypassing this relay and giving a plus by another 12V relay. It's a bit of a joke, but a new car is no longer an annoying problem.
  • #4 17168372
    Kostek221300
    I've already had 2 such cases and 90% of the motor zero point will be damaged and the relay will switch on because it gets a signal from the motor
  • #5 17169081
    misiek_89
    Rate: 118
    Dude, can you suggest something more? Zero point, i.e. some contactor / limit switch? How did you deal with it?
    I noticed that if I hit the fuse box several times with my hand, the wiper can start suddenly but it doesn't work with breaks, it only does 10 full ranges and only pauses. I disassembled the UCH module and there are several relays on it, I tried to assess by touch which one is responsible for the wipers but it's hard to feel. Can anyone suggest which element is the rear window wiper relay?
  • #6 17169609
    olo114
    Help: 14
    Rate: 95
    PP1 connector (8-track connector) pin 2 goes to the rear wiper motor, the beige wire goes into the green cube at the engine in position 2.
  • #7 17170494
    misiek_89
    Rate: 118
    Yes I know about it. It's not always the engine that gets the boost The relay itself is "ticking" and the impulse is missing. When I give an impulse from outside, the engine starts immediately. I was so intrigued by the answer about the zero position of the engine, maybe in the middle of the mechanism there is an element that gives the signal that the wiper has made the full range of motion?
  • #9 17663386
    jacek2505
    Rate: 8
    Hello all. I had the same problem as the others with the rear wiper in the scenic 1 ph2, once it worked once, sometimes it stopped as I saw it, until I finally decided to do it. I will describe how the repair looked for me, maybe it would help someone. I removed the ear on the left side of the steering wheel in the middle there is a relay the third in turn and the last with the description p1cno10n I decided to remove it so as not to desolder it from the board I only broke it on the board and soldered the cables to the plates that remained and I made an external finder relay 8a on the stand, because I didn't have the original one and now if it gets damaged, I replace it within a minute. the wipers returned to normal operation after the entire procedure. For those interested I can insert photos from the procedure. I did not desolder the relay but I broke it and soldered the cables to the contacts that were not to interfere with the original February because probably some of these solders were double-sided and I did not want to kick something. best regards.
  • #10 18092562
    kevinsalem
    Good day.
    Quite a lot of time has passed, but maybe it will succeed. I can ask you for this pattern. I have the same problem. The relay cannot be heard, Motor, cables checked. Shifter also. I am asking you for this diagram and catalog number of this relay.
The discussion revolves around diagnosing intermittent functionality issues with the rear wiper of the Renault Scenic I. The user reports that the wiper operates erratically, sometimes working and then stopping. Initial diagnostics indicate voltage readings at various pins, suggesting potential relay or wiring issues. Responses suggest that the problem may stem from a faulty relay or the motor's zero point, which could affect the wiper's operation. Some users recommend checking the relay, with one sharing a repair method involving bypassing the faulty relay. Others inquire about wiring diagrams and relay specifications for further troubleshooting.
