Renault Clio3 - - no dipped beam and headlight adjustment does not work
jozefg 17769 9
How can I diagnose and repair a Renault Clio III that has lost both dipped headlights and headlight-height adjustment after the under-hood fuse box became wet?
The likely fault is a water-damaged UPC under-hood fuse/relay module; replacing it restored all functions in the thread [#16830082] First verify the 15 A F9 and F10 fuses and the dipped-beam relay, identified as the third relay from the cut-off corner [#16822570] With the relay removed, briefly bridge its power contacts: if the dipped beam and adjustment work, the wiring, lamps, and actuators are being powered and the relay/control side is suspect [#16822805][#16823012] Use a diagnostic tool to connect to the UPC and test the dipped-beam actuator; if the test fails, replace the UPC or dismantle, clean the board with spirit, brush it, and dry it thoroughly [#16823332]
  • #1 16822495
    jozefg
    Help: 197
    Rate: 746
    I have a fuse box under the hood - in Clio3 it's normal ... :(
    Then it becomes 'disco' :D
    Twice I followed the advice of users of this car, i.e. farelka and after blowing with warm air it works.
    I took it out, dried it, put it under the hood and everything works except for the short lights and the height adjustment of the lamps disappeared.
    What to pick on
  • #2 16822570
    Doktorr
    Help: 287
    Rate: 1098
    Start by checking
    F9 - 15A fuse for the right low beam
    F10 - fuse 15A left dipped headlights
    dipped beam relay (3 counting from the cut off corner or clicking when switching on the lights)
  • #3 16822616
    jozefg
    Help: 197
    Rate: 746
    The fuses in the box are all good.
    When you turn on the lights, nothing is spoken, you can only hear and see when the lights change to long.
  • #4 16822805
    Doktorr
    Help: 287
    Rate: 1098
    Pull the relay out and short the executive contacts, you will see whether the low beam lights up.
  • #5 16823012
    jozefg
    Help: 197
    Rate: 746
    Done - right dipped lit and regulation worked ... :D
  • #6 16823062
    Doktorr
    Help: 287
    Rate: 1098
    Well, probably in the left burnt bulb. Now check the relay on the table or put the passing one in place the same as you are sure it is in working order.
  • #7 16823171
    jozefg
    Help: 197
    Rate: 746
    Proven - functional!
    Doktorr
    Help: 287
    Rate: 1098
    Diagnostic tool Connect to UPC. to test the actuator (dipped beam) will probably fail. If so, either replace the UPC or try to split it, wash the plate in spirit, brush it with a toothbrush and dry, for example. Sometimes comes alive.
  • #9 16823578
    jozefg
    Help: 197
    Rate: 746
    But you comforted me .....
    In the morning I am looking for a module, maybe they have some good on the top.
    Not soaked in water as mine .... :D
  • #10 16830082
    jozefg
    Help: 197
    Rate: 746
    I ordered a second mailbox, it arrived today. :D
    I installed, checking - it's OK, all functions are working, working.
The discussion revolves around a Renault Clio3 experiencing issues with the dipped beam headlights and headlight adjustment. The user initially checked the fuses and found them intact but noted that the lights only functioned when switched to high beam. Suggestions included checking the F9 and F10 fuses, testing the dipped beam relay, and shorting the relay contacts to diagnose the problem. After performing these checks, the user confirmed that the right dipped beam worked and the adjustment function was restored. Further advice included using a diagnostic tool to test the UPC (unit controlling the headlights) and cleaning it if necessary. Ultimately, the user replaced the module, which resolved the issues, restoring all functions.
