Citroen C4 1.6 hdi - The radiator fan runs 10 minutes after the car is turned of
tymbark13 12807 5
  • #1 16638503
    tymbark13
    Hello ,
    Please help with the topic as above. After driving a short distance and after turning off the engine, the fan works for a long time.
    Following the hints on the forum, I replaced the relay - the fan resistor. Unfortunately, it didn't help.
    The second problem is error P 2562 Turbocharger position sensor A in the boost air circuit - Circuit malfunction.
    Are these problems related?
    I am asking for help or a mechanic from the vicinity of Krakow
    best regards
  • #2 16638565
    jareckim
    Help: 5
    Rate: 49
    How about the temperature? If the fan is working, the temperature is too high or the sensor is damaged. Temperature too high due to faulty thermostat. The problems are not related to each other.
  • #3 16639166
    tymbark13
    The temperature is fine. Even after driving into a neighboring estate, the problem persists. Which sensor do you suggest?
  • #4 16639274
    jareckim
    Help: 5
    Rate: 49
    Coolant temperature sensor with a green tip.
  • #5 16639345
    willyvmm
    Help: 164
    Rate: 364
    FAP was not an accident we cut?
  • #6 16639780
    tymbark13
    I will order the sensor on Monday. On the other hand, FAP is original. I have traveled 130,000 km and this is the whole route.
    best regards
