[Solved] PEUGEOT 307 2.0 HDI: Radiator Fan Not Activating at 110°C Despite AC Functioning & Replacements
szo21 12615 5
  • Engine temperature trigger still not starting fan
    #1 16539159
    szo21
    Hello. The radiator fan is not working. . Automatic car with air conditioning. After switching on the air conditioner, the fan works nicely, but the engine temperature will not start. The temperature reaches 110 and here I can't hear the spirit. Replacement maxi fuse, relays on the radiator, temperature sensor. The thermostat opens well because the hoses are equally warm. I was checking my computer and the fan error crashes. I also checked the spirals and there is a transition. New Fluid. Deaerated with 2 vents. Help
  • #2 16539228
    pepe150
    Level 36  
    Help: 288
    Rate: 943
    Hand diagram and cables to check.
    Have you checked whether the relays have voltage?
  • #3 16539361
    szo21
    Will the voltage be there all the time or only when the slinikt is hot when the windmill should work? Has anyone maybe a certain pattern?
    piotrekwoj1
    Help: 947
    Rate: 3433
    It will be on relays all the time.
  • Temperature gauge reads 15–20°C high after sensor test
    #5 16547766
    szo21
    I took apart .. it turned out that the fuse was oxidized .. repairs and 1 and 2 hula gear with nice. But I have 2 problem. Temperature indicator. He's lying about 15-20 degrees. I did the test by immersing the sensor in a liquid with a thermometer in it. The temperature of the liquid is 80 a and the watches 95. Czunikaj is new because I exchanged I thought that the fan is his doing. The old man indicates the same, so he was good. Clock?
  • #6 17183157
    szo21
