Eavesdropping on Police Channels, Guard Frequencies: Old Radio in Basement, Obstacles & Tips
death15331 33222 17
Can an old radio receive police or guard channels, and what obstacles might prevent me from listening to them?
An old radio may let you hear some police or guard traffic only if it covers the right band and modulation, but many services now use digital systems or encrypted calls, so in many places you will hear little or nothing [#17160857][#17161076][#17161153] Frequencies alone are not enough: you also need the correct modulation (AM/FM/phase, etc.) and the right receiver for the system in use [#17160857] Several replies say that in some regions police, fire, railways, or ambulance traffic is still heard in analogue narrowband FM, while other areas have moved to DMR/TETRA or use phones/terminals for sensitive dispatching [#17161076][#17161153][#17161595][#17161864] If you want to experiment, people recommend a frequency scanner or an RTL2832U-based SDR dongle, which can receive roughly 22 MHz to 1.7 GHz; one reply also mentions using the receiver’s discriminator output with PC software such as DSD for digital signals [#17161630][#17161076][#17161864] Listening itself was described as legal, but transmitting on those frequencies and sharing what you heard were both warned against [#17161210][#17161272][#17161595]
  • #1 17160817
    death15331
    I found an old radio in the basement with such frequencies that theoretically should give advice and overhearing police channels, etc. and I wonder if you could overheat the police channels or guard for it if it supports such frequencies or there are some obstacles I do not know, because in All in all I do not know electronics very much :D
    Moderated By c2h5oh:
    Regulations point 3.1.16. Do not send questions that can be easily found on the Internet or in the electrode forum.
  • #2 17160857
    750kV
    Help: 240
    Rate: 712
    Frequencies are not everything. The type of signal modulation (amplitude, frequency, phase) is also important.
    You must also know that any use of information obtained through such a watch is punishable.
    I must also worry you. These services are provided by mobile phones and provide important information in this way. :-)
  • #3 17160982
  • #4 17161072
    locos1
    Rate: 34
    Pong.Chu wrote:
    The police use communication equipment that encrypts the calls you will not hear anything.
    In Bialystok, apparently, the encryption broke down ;-)
  • #5 17161076
  • #6 17161153
    dj_volt
    Help: 77
    Rate: 171
    Interesting things, Waćpan, you write ...
    Except for the exceptions (Tetra, Ericcson, Hytera, etc.) in our country in the "blue bands" FM modulation reigns supreme. The same in Health Service, PSP, PKP. Apparently there are plans for switching to the Tetra system, but how many years have you heard about it ...
  • #7 17161158
    E8600
    Help: 529
    Rate: 2518
    A few years ago, I heard such a conversation in a regular FM radio, of course, in the radio band they had to set something wrong because they were stifling the reception of the radio. As for legality, it is rather legal that it is not like the air band.
  • #8 17161210
  • #9 17161272
    penpen
    Rate: 35
    zbyrek wrote:
    The listening is completely legal, you can not transmit in these frequencies.
    That's right, the listening is legal. In addition to the fact that you can not transmit it, you can not share the information heard on this band.
  • #10 17161595
    xray81
    Help: 37
    Rate: 73
    You will not hear anything interesting, as you mentioned from the Police, you will only hear messages of the type that the patrol will go to an address without details, the investigators use their cells. You will not hear much from the Fire Brigade, I only heard messages that the unit, eg number 1, goes to the action and how many people in the car and that they arrived at the action, maybe because I had a weak antenna and I did not hear the messages from the base. You can listen but you can not share the information you have gained from listening, so you can not use the radio in public so that the outsider can not hear it because the relevant services can include confidential information :) .
  • #11 17161626
  • #12 17161630
    Szyszkownik Kilkujadek
    Level 37  
    Help: 211
    Rate: 1011
    The topic seems to have been exhausted and all important information has already been heard.
    @ death15331 If you want to play, buy a frequency scanner.
  • #13 17161772
    ^ToM^
    Help: 495
    Rate: 2939
    You can listen without interruption, but you can not pass on the information you hear. You have to remember about it. Whereas now the services have gone digital, so you will not hear too much. You can play because you can learn something about how the radio works.
  • #14 17161864
    internick
    Level 36  
    Help: 273
    Rate: 555
    locos1 wrote:
    ... In Bialystok apparently the encryption broke ...
    Ambulance Service or Border Guard will you listen?
    zbyrek wrote:
    ... I think that only digital radio is used in Warsaw, and in most cities it is just an analogue analogue narrowband FM, unsecured ...
    All of Kujawsko-Pomorskie, most of Podkarpackie, Podlasie, Warmian-Masurian and many other regions have long been in DMR.
    dj_volt wrote:
    ... Except for exceptions ... in our country ... FM modulation reigns supreme ... PSP, PKP ...
    In Fire Brigade and on the railways yes.
    ^ToM^ wrote:
    ... now the services have gone digital ... You can have fun ...
    He would play if he led the discriminator and the receiver connected to a computer with a special softphone, eg DSD.
    death15331 wrote:
    ... I found an old radio in the basement ...
    What kind of equipment and what frequencies does it cover?
  • #15 17161887
    _siekier
    Help: 77
    Rate: 114
    In Dolnośląskie, still a lot of "human harm" flies in analog, but for someone to listen to passionately for hours, because sensitive data does not fly in the "open" ether, only digital communication or cellular networks.
    * "Human harm" - blue, PSP, health service.
    One could listen to analogue telephone radiolinks in villages - heh, life itself, good hstorie, and even wishes for various occasions could be learned quite well.
  • #16 17161894
    internick
    Level 36  
    Help: 273
    Rate: 555
    _siekier wrote:
    ... It was possible to listen to analogue telephone radiolinks in the villages ...
    And to think that the NMT450 has long since shut down, and the bandwidth to this day is unused.
    They have been poisoning about LTE450 for several years, but nothing comes of it.
  • #17 17161953
    ptero
    Help: 68
    Rate: 179
    I once listened to several nearby hams, a few VHF repeaters, the Straż, Police, PKP, PMR, Radio Taxi, sentries at a nearby polygon, a military airport tower with nearby airplanes (in AM), ISS station, motor hangers, ships on the Oder river, several captains and ports.
    And a passing balloon. :)
  • #18 17161988
    c2h5oh
    Moderator
    Help: 502
    Rate: 753
    All information has already been provided. If the subject's author does not feel satisfied, let him look for information on the subject on the electrode. It has already been written about it many times. There is no point in duplicating this information again.
✨ The discussion revolves around the feasibility of using an old radio to eavesdrop on police and guard frequencies. Key points include the importance of signal modulation types and the legal implications of listening to such communications. Many responders noted that police communications are often encrypted, making them inaccessible to standard radios. Some users suggested alternatives like purchasing a terrestrial digital TV receiver based on RTL2832U for broader frequency access. The conversation also highlighted that while listening is generally legal, sharing the information obtained is not. The current trend shows a shift towards digital communication, limiting the effectiveness of traditional analog radios for monitoring police and emergency services.
TL;DR: “...allows you to listen” across 22–1700 MHz; RTL2832U costs about PLN 40. For hobby listeners in Poland asking how to hear police/guard channels with old radios or cheap SDR, here’s what works, what’s digital, and what’s legal. [Elektroda, Anonymous, post #17161076]
Why it matters: It helps Polish radio hobbyists choose gear and stay within the law.
Can my old basement radio pick up police or guard frequencies?
Maybe, but modulation decides success. Frequencies alone are not enough. Services use amplitude, frequency, or phase modulation. Some sensitive traffic now moves through mobile phones. Using information you hear can be punishable. “Frequencies are not everything.” [Elektroda, 750kV, post #17160857]
Is listening to police or guard channels legal in Poland?
Listening is legal. You must not transmit on those frequencies. You also must not share what you hear. “Listening is legal.” Keep your monitoring private and educational. [Elektroda, penpen, post #17161272]
Can I share what I hear on social media or play it in public?
Do not relay monitored content publicly. Do not play it where outsiders can hear. Services may treat traffic as confidential. Keep listening private and avoid rebroadcasting. [Elektroda, xray81, post #17161595]
What cheap gear should I buy to start scanning today?
Get an RTL2832U-based DVB‑T USB dongle (RTL‑SDR). It covers about 22 MHz to 1.7 GHz. The cost is around PLN 40. One user cites 173.115 MHz as a local police example. This dongle offers broad coverage for beginners. [Elektroda, Anonymous, post #17161076]
Which services are still analog and worth scanning?
Blue‑light bands in Poland often use FM. Health Service, State Fire Service, and rail (PKP) also use FM. Some networks run TETRA, Ericsson, or Hytera digital. Plans to migrate exist, but FM remains common today. [Elektroda, dj_volt, post #17161153]
Is Warsaw different from other cities for police radio?
A user reports digital radio in Warsaw. They also note many cities still use analog narrowband FM. Their example frequency was 173.115 MHz. Scan locally to confirm your area’s situation. [Elektroda, Anonymous, post #17161076]
Where in Poland is DMR used right now?
DMR is reported widely. It covers all of Kujawsko‑Pomorskie. It includes most of Podkarpackie, Podlasie, and Warmian‑Masurian. Other regions also appear on DMR. [Elektroda, internick, post #17161864]
Can I decode DMR or other digital modes at home?
Yes, with the right setup. Add a discriminator output or use an SDR. Connect the receiver’s audio to a computer. Run decoding software such as DSD. “receiver connected to a computer with a special softphone, eg DSD.” [Elektroda, internick, post #17161864]
Will encrypted police communications be listenable?
No, encrypted traffic will not be intelligible. A user states police use equipment with encryption. You will not hear those calls. Focus on unencrypted or analog services. [Elektroda, Anonymous, post #17160982]
Can a regular FM radio pick up service chatter by accident?
Yes, when a transmitter is misconfigured. One listener heard service traffic on a normal FM radio. The strong signal stifled the broadcast station. Treat this as interference, not a reliable method. [Elektroda, E8600, post #17161158]
What kinds of signals can I hear for fun besides police?
Plenty. Hams and VHF repeaters are active. You may hear Straż, PKP, PMR, and taxi. Military airport towers use AM, and the ISS can be heard. River ships, ports, and even passing balloons appear. [Elektroda, ptero, post #17161953]
What happens if I act on information I hear?
Do not use monitored information to act. “Any use of information obtained through such a watch is punishable.” Keep listening purely as a hobby. Never interfere with operations. [Elektroda, 750kV, post #17160857]
Should I buy a hardware scanner or go straight to RTL‑SDR?
“If you want to play, buy a frequency scanner.” A scanner simplifies tuning and modulation. It is easier than repurposing old radios. Start with a scanner for a smoother experience. [Elektroda, Szyszkownik Kilkujadek, post #17161630]
How do I get started with digital decoding (DMR) in 3 steps?
  1. Add a discriminator tap to your receiver or use an RTL‑SDR.
  2. Connect audio to your PC and install DSD.
  3. Tune to a known DMR frequency and start decoding. [Elektroda, internick, post #17161864]
Why do I only hear brief dispatches and not details?
Dispatchers send short tasking messages. Investigators handle details on cellphones. Fire Brigade traffic often reports departures and arrivals. A weak antenna may miss the base replies. Keep expectations realistic for content depth. [Elektroda, xray81, post #17161595]
Could encryption ever fail, revealing traffic?
It can happen as an exception. One user noted, “In Białystok, apparently, the encryption broke down.” Treat such moments as temporary faults. Do not rely on them. [Elektroda, locos1, post #17161072]
