Xiaomi Redmi Note 4: Does it Support Quick Charge? Snapdragon 625 & Battery Info
mati.ros 13797 6
  • #1 16641395
    mati.ros
    Rate: 8
    Good morning,
    Recently I looked at Xiaomi smartphones because I would like to buy. I am interested in Xiaomi Redmi Note 4. On the manufacturer's website (http://www.mi.com/in/note4/specs/) in the battery tab there is no information about fast loading, but on the manufacturer's website (Snapdragon 625, https: //www.qualcomm.com/products/snapdragon/processors/625) is the information that it has such technology. And now my question is whether the phone supports Quick Charge or not?
    Please help!
    Greetings!
  • #3 16641445
    mati.ros
    Rate: 8
    But rather the processor function will not block. And do you suggest that Qualcomm's site is an unbelievable source? Hmmm. Weird
  • #4 16641460
    badboy84
    Help: 1197
    Rate: 1485
    Without a proper layout, software and perhaps another battery, the processor itself will be powerless. The fact that it enables such a function does not mean that the device manufacturer must use it.
  • #5 16642542
    cxzcxz123
    Level 32  
    Help: 140
    Rate: 284
    Qualcomm is not lying. SoC supports QC, while Xiaomi has blocked this feature in this model.
    What you want to know is the charging time. From 0 to 100% it takes about 2.5 hours. The charger connected to the phone is two-amp. In my opinion, the tragic charging time is not taking into account the fact that the cell has 4100 mAh.
  • #6 16650457
    Atreyu Makiavel
    Help: 112
    Rate: 318
    Xiaomi budget models do not have a Quick Charge for licensing costs. Just having Qualcomm SoC is not enough.
  • #7 16669382
    mati.ros
    Rate: 8
    Thanks for the answers.
The Xiaomi Redmi Note 4 does not support Quick Charge despite the Snapdragon 625 processor being capable of it. Users noted that Xiaomi has disabled this feature in the Redmi Note 4, likely due to licensing costs associated with Quick Charge technology. Charging the device from 0 to 100% takes approximately 2.5 hours with a standard two-amp charger, which some users find unsatisfactory given the phone's 4100 mAh battery capacity.
