Xiaomi Redmi Note4x Quickly discharging the battery and turning off the phone at
Qsam 15819 8
  • #1 17361950
    Qsam
    Hello, I have a problem with the Xiaomi Redmi Note 4x phone. The battery very quickly discharges, on the wifi when using the Internet or watching Youtube endure 1-1.5 h, and without using a phone and turned off the wifi around 12h. Another problem is switching off the phone with about 20% of the battery. I do not know what can be a problem and if the battery is still working, additionally the phone stops charging when it is not on something :) Thank you in advance for your help.
  • #2 17361986
    matej1410
    Help: 115
    Rate: 219
    Do you have a guarantee yet?
  • #3 17362000
    Qsam
    I bought the phone in March 2017 on the Allegro and was imported from China :) so I do not have a guarantee.
  • #5 17363032
    tplewa
    Help: 222
    Rate: 1007
    matej1410 wrote:
    In addition, many users complain about the same ailment as you. Probably it is some factory defect. Take a look here:
    https://xiaomi.eu/community/threads/shutdown-at-20.32826/
    This link applies in total to Xiaomi.eu roms ... Let's say this in both MIUIPolska / Xiaomi.eu and official roms (eg Global) sometimes there were some wtopi that caused some problems of this type. For example, after the last update of MIUI 9 Global I have also a lot of battery consumption through the system (and from what I read on the internet I'm not alone in this ;) ).
    Although your friend's charging problems may indicate some damage. Here it is also worth asking if it did not happen, for example, after updating the rom and what the friend rom has (imported from China could be in the global or Chinese version and then it was uploaded eg. MIUIPolska rom)
    As for the aforementioned factory defect in Redmi Note 4x, I have not heard of such ...
  • #6 17363873
    Qsam
    Should replacing the battery help?
  • #7 17364961
    tplewa
    Help: 222
    Rate: 1007
    He may have a colleague, luckily, that some fake has hit, because after such a time there should not be such a significant loss of capacity. I have an older Redmi Note 3 Pro at home and it lasts longer (even on the mentioned new MIUI 9 where after the last update there is a problem with the energy-saving system) ...
    Matters like I mentioned can be a lot from some hardware failure after software problems. Is not this the last problem you can check in the android, peeking what percentage "eats" the most energy. It may be the fault of the rom, it may be the fault of some application, and something could have been damaged in the phone ...
    I will say just like a colleague is not able to diagnose it himself, it is better to talk to a person who can deal with it and possibly fix it. Unfortunately, the action "on the peds" is not the best way out - maybe more harm than good to bring ...
  • #8 17930285
    hipeck
    Rate: 18
    It may come in handy. I have Redmi 4a. Zrootowany. Until now, the battery lasted about 4 days as the handset itself. I installed the Root Esential application, where the tools are battery calibration. At the moment, it's 11 days from charging. 36% left. Only as a handset, because I use WiFi and transfer occasionally. pozdr
  • #9 17940640
    c-y-r-u-s
    Help: 12
    Rate: 35
    The battery to be replaced by a replacement, will work 2 days later, half of it. As you change it yourself, remember that it is glued on two straps, which often break as they pull them out :)
    I would still have to replace the usb connector on the board, it costs 7 zlotys on ali and I would start with that.
The user reports rapid battery discharge and unexpected shutdowns on their Xiaomi Redmi Note 4x, experiencing only 1-1.5 hours of usage on Wi-Fi and 12 hours in standby. Responses suggest that the battery's performance may be due to age, potential factory defects, or software issues following updates. Recommendations include checking battery health, considering a battery replacement, and examining the phone's software for energy consumption issues. Users also mention experiences with other models, indicating that battery life can vary significantly based on usage and software versions.
