VW Lupo 3L automat - What is this tank and what oil should be added
naruto29 11565 4
  • #1 16644084
    naruto29
    Rate: 35
    Hello, what is this tank with a green cap and what oil do you need to add (where you can buy it in Silesia, for example) and whether the lack of this oil can cause that the car often turns on the cooling
    I will add that when I open the steering door, it sounds like a compressor, but I would like to know exactly VW Lupo 3L automat - What is this tank and what oil should be added from you
    pictures in attachment
  • #3 16644240
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    The fuel pump starts :)
  • #4 16644293
    naruto29
    Rate: 35
    So I have to understand this plej hydraulic, how do they write on the site?
  • #5 16644305
    bubu1769
    Help: 1177
    Rate: 2374
    Yes, it is a reservoir of hydraulic fluid for the clutch, if you want you can add it if you think it is not enough.
