Considering Yihua 936 50W Soldering Station 200-480 deg. C - How's the Temperature Control?
Kubcioo 7407 12
How does the temperature control work in a Yihua 936 50W soldering station, and is it any good for occasional soldering?
The temperature is stabilized by a thermocouple inside the iron that tells the station electronics to switch the 24 V heater on and off to keep the tip near the set value [#16645936] The temperature knob is scaled in °C, but the scale is not very accurate, so you should verify the real temperature yourself [#16645936] For leaded solder, one reply suggests about 320–330 °C; for lead-free, 350–380 °C [#16645936] If you need to solder a larger mass or thick cables, you can raise it to around 450 °C [#16645936] Another reply says Yihua/WEP 936 stations are essentially the same and are fine for occasional “Sunday” soldering [#16645907]
  • #2 16645323
    grzeskk
    Help: 320
    Rate: 730
    I do not recommend, 230V heater not durable, regulation without feedback on the triac.
  • #3 16645367
    Kubcioo
    Rate: 10
    Not suitable for soldering a few times a week?
  • Yihua 936 criticized for poor temperature regulation
    #4 16645508
    398216 Usunięty
    Help: 3925
    Rate: 9447
    Is the scooter suitable for commuting to the other end of the city? Suitable. Only it is a little more tiring than bus and more dangerous.
    A colleague wrote above - it is a "station" with a poor quality soldering iron, powered from a voltage regulator (no power! It will not "hold" the set temperature like a "normal" station when soldering various elements - a large element means greater heat dissipation from the tip, and temperature Smaller element high temperature - if you set the "temperature" based on the behavior of tin when soldering small components and then you want to whiten, e.g. 2.5mm2 tin will not want to whiten it, because the temperature will drop) and in addition in case of failure (breakdown voltage from the heater to the tip) can damage - either the system or you ...
    In general, Chinese in all its glory.
    Whether you buy it or not - it's up to you. I would advise against.
    If you want reasonably good and not having the above-mentioned disadvantages, buy something like this:
    https://diolut.pl/stacja-lutownicza-yihua-936-50w-200-480-stc-esd-safe-repro-p-4509.html
    For "Sunday" soldering just in time.
  • Transformer-based irons offer better temperature control
    #5 16645529
  • Recommends a better Yihua 936 station over cheap clone
    #6 16645532
    Kubcioo
    Rate: 10
    So you say it's better to buy that? And the one you gave is also regulated by power? Or not. I prefer to buy better and make it work rather than change every few months.
  • #7 16645565
    HD-VIDEO
    Help: 1265
    Rate: 1884
    Temperature stabilization is by means of a thermocouple, which is placed on the body of the soldering iron, on which the tip is attached, and the power of the heater is regulated by the method of turning the heater on / off. This is the best method for stabilizing temperature.
    Electronics are repairable
  • #8 16645613
    Kubcioo
    Rate: 10
    And the WEP 936 station is also good?
  • #9 16645907
    kassans
    Level 32  
    Help: 130
    Rate: 412
    Colleagues probably don't know what they are writing about. In these stations, the flask is at 24V and the temperature itself is stabilized by a thermocouple. All whether Yihua or WEP are one and the same. Approximately approx. For Sunday soldering
  • #10 16645922
    398216 Usunięty
    Help: 3925
    Rate: 9447
    We know. The author changed the first post.
    In the original he asked about the ZD-99 station.
  • #11 16645933
    Kubcioo
    Rate: 10
    I changed the topic name. :)
    So buy this station Wep 936? Is it worth for its price?
  • WEP 936 uses thermocouple feedback and 24V heater
    #12 16645936
    398216 Usunięty
    Help: 3925
    Rate: 9447
    You have the description on the page from the link I gave. The flask is powered by 24V, inside it has a thermocouple, which informs the electronics in the station about the temperature. If for some reason (e.g. soldering a large mass surface or bleaching the ends of large diameter cables), it turns on the power supply and heats the tip to the set temperature - this in turn is set on the potentiometer scaled in * C.
    If you solder with tin with lead - you set the temperature in the order of 320-330 * C, like unleaded - slightly higher - 350-380 * C (you have to check it yourself - the scale is not very accurate, but once set the temperature is good), and how do you have to soldering something really big and the regulator fails; you can always set it to 450 * C - before the tip cools down, you can even solder a piece of sheet metal.
  • Thermocouple feedback and practical soldering temperatures
    #13 16645978
    Kubcioo
    Rate: 10
    And ok, thanks for everything. I will try to buy stations as soon as possible.
The discussion revolves around the Yihua 936 50W soldering station, focusing on its temperature control capabilities. Users express concerns about the durability of the 230V heater and the effectiveness of its temperature regulation, which relies on a voltage regulator without feedback. Several participants suggest that the station may not be suitable for frequent use, as it struggles to maintain temperature under varying load conditions. Alternatives like the WEP 936 station are mentioned, which reportedly have better temperature stabilization through a thermocouple. Overall, the consensus leans towards caution regarding the Yihua 936, with recommendations for more reliable options for regular soldering tasks.
TL;DR: Yihua/WEP 936-class stations use a 24V iron and on/off control via a thermocouple—“Temperature stabilization is by means of a thermocouple.” Set 320–330°C for leaded, 350–380°C for lead‑free. Good for occasional “Sunday” work. [Elektroda, HD-VIDEO, post #16645565]
Why it matters: This FAQ helps hobbyists choose and set up a budget 936-style station for reliable, safe soldering without guesswork.
Is the Yihua 936 a good choice for occasional hobby soldering?
Yes. Users report Yihua and WEP 936-class stations are “one and the same,” stabilized, and OK for “Sunday soldering.” They suit occasional electronics work where cost matters more than pro-level throughput or accuracy. Expect basic, usable performance for boards, jumpers, and small connectors. [Elektroda, kassans, post #16645907]
How does temperature control work on a 936-style station?
A thermocouple on the heater barrel senses temperature. The controller switches the heater on or off to hold the setpoint. As one user put it, “Temperature stabilization is by means of a thermocouple,” and the electronics are serviceable if needed. This simple control maintains workable temperatures for most hobby joints. [Elektroda, HD-VIDEO, post #16645565]
Does it hold temperature on big ground planes or thick wires?
It recovers by applying power when the tip cools against large thermal masses. For demanding joints, temporarily set higher, even 450°C, to push heat into the work, then return to normal. Expect some droop during heavy loads; brief boosts help. [Elektroda, 398216 Usunięty, post #16645936]
What temperatures should I use for leaded vs lead‑free solder?
Start at 320–330°C for leaded alloys and 350–380°C for lead‑free. Adjust a little for tip size, joint mass, and your solder brand. The dial scale is not very accurate, so tune by wetting behavior and joint speed. [Elektroda, 398216 Usunięty, post #16645936]
Are Yihua 936 and WEP 936 basically the same platform?
Yes. Contributors note these 936-class units share a 24V handpiece and thermocouple-based stabilization. Performance and design are very similar across Yihua and WEP in this tier. Choose on price, availability, and accessories. [Elektroda, kassans, post #16645907]
Is there a version to avoid, like 230V heater models?
Avoid regulator-only irons with a 230V heater and no feedback. One user reports poor durability and triac control without temperature feedback, which leads to unstable tip temperatures and short heater life. [Elektroda, grzeskk, post #16645323]
What’s the safety risk if a mains‑powered heater fails?
With 230V heaters, an insulation breakdown could put dangerous voltage on the tip and damage your circuit—or injure you. “In general, Chinese in all its glory,” cautioned one poster, recommending feedback-controlled 24V designs instead. [Elektroda, 398216 Usunięty, post #16645508]
Can I repair a 936 station if the controller fails?
Yes. Users report the electronics are repairable. The design is simple, using a sensor input and a switching controller for the heater. Spare parts and schematic-style clones are common, easing troubleshooting. “Electronics are repairable.” [Elektroda, HD-VIDEO, post #16645565]
Should I consider a transformer iron like Lutol or ZDZ instead?
For quick heavy joints, a transformer iron can outperform a small station. A poster suggests Lutol/ZZDZ for robust power delivery, or a quality 936-style unit if you want stabilization and finer tips. Mix tools to match tasks. [Elektroda, 2974068, post #16645529]
How do I quickly dial in a working temperature on a 936?
  1. Set 320–330°C for leaded or 350–380°C for lead‑free and test on scrap.
  2. Observe wetting; add 10–20°C if joints take >2–3 seconds.
  3. For large planes, briefly raise toward 450°C, complete the joint, then return to normal. [Elektroda, 398216 Usunięty, post #16645936]
Is the handpiece actually isolated from mains?
Yes for 936-class units discussed. The handle runs at 24V, improving safety and reducing noise coupling into sensitive circuits versus direct-mains irons. This design pairs with a thermocouple for stabilization. [Elektroda, 398216 Usunięty, post #16645936]
Is the WEP 936 worth it at its price?
For budget buyers, yes. The thread consensus marks WEP/Yihua 936 as functionally similar and suitable for occasional work. If you solder weekly, factor tip quality and calibration drift into your expectations. [Elektroda, kassans, post #16645907]
