Yihua 852D+ Soldering Station for Transistors, IC, Resistors - Worth it or Alternative Options?
DJBociek_ 4164 1
  • #1 16806204
    DJBociek_
    Rate: 42
    Hello everyone, :) I found a Yihua 852D + soldering station with a power of 700W on the Allegro. I was looking for topics on the forum whether it is worth buying this equipment, but nowhere have I found a clear answer.
    This equipment looks like this:
    The station will be mainly used for soldering small elements such as transistors, IC, resistors, etc., but it should also be able to desolder the heat sink from the board if necessary :) Is it good equipment for such purposes? Alternatively, can you recommend something else for a similar amount? I already had a few transformers, but with a minimum time of 1 hour, the robots were cooking and not many of them were able to do it ;)
    Thanks for the answer and best regards.
    Kamil :)
  • #2 16806316
    do_tyk
    Rate: 82
    I have one myself at home and I am very happy with it, it heats up quickly and maintains the temperature and easily desolders each element.
