Ford Mondeo mk4 2.0 TDCi - Siemens CR 3 Pump Generation: Valve Function and Resistance Values
Frost160 19998 4
  • #1 16825371
    Frost160
    Help: 9
    Rate: 183
    car as in topic 2.0 tdci has gone out and does not ignite. No pressure on the rail siemens injection system generation 3.
    I wanted to ask what is the valve / valve (1 on the photo) on the pipe where the pump draws fuel to be vented?
    The valves on the regulating pump and the flow (2-3) have any resistances? If so, what?
    The pump can be seen that it was once replaced with another used. Car like on the counter around 300,000 but on the "eye" it looks like it had over 0.5 million behind it.
    Thanks for the help in advance.
  • #2 16825561
  • Questioning how to properly bleed the Siemens CR pump
    #3 20531517
    marek-jaroszewicz
    Hello, I'm reviving the topic. I have such a pump, I bled it by unscrewing the fuel valve.
    The symptom was the engine throttling - the revolutions fell from 2000 to 1000. It was possible to drive while maintaining low revolutions. The glitch disappeared and reappeared.
    I decided to check the valve: I turned it out, fuel flowed into the tank. After blowing with a compressor and checking on the battery (coil ticking) I installed it and unfortunately it failed to set the fuel. I'm afraid to keep spinning dry, and it's already raining.
    At the outlet of the fuel filter, I inhale the purchased pear, but it drains quickly before I connect the cable to the pump. Kuga MK1 2.0 TDCI does not have a pump as standard.
    I'm thinking about disassembling the pump to check deeper - do you need to block the timing? The pump is supposed to be synchronized with the injection phase.
    How to properly vent this Siemens?
    I wish you a tasty egg and a wet Monday in sunny weather!
  • #4 20531578
    piotrekwoj1
    Help: 947
    Rate: 3433
    Just because it "ticks" doesn't mean the valve is working. I do not believe that after properly assembling everything, the pump does not want to draw fuel. Either you put something together wrong or the valve is to be thrown away. Loosen the nut at the injection and crank, fuel should appear.
  • Asking valve states and fuel return behavior
    #5 20531841
    marek-jaroszewicz
    The valve is back in place. Loose injector output and nothing. I am asking about this bleeding because the pump does not draw fuel.
    The symptom was that the engine was choking at times. Therefore, I unscrewed the valve accessible from the top of the pump.
    Can anyone tell me what the status is when it is not powered? I guess it should allow the fuel to return from the pump to the tank.
    There are two valves - what are the states when there is no power - closed or open?
