No Dipped Beam in 2007 Chevrolet Lacetti: Checked Fuses, Relays, Steering Wheel Light Switch
Mahoni23 6084 4
  • #1 16646690
    Mahoni23
    Hello, I have a problem with the low beam in lecetti. Everything has been checked. Fuses. Relays. They're good. Even the steering wheel light switch is new and still nothing. Even the cube behind the counter. What I read on other forums that it is on fire is ok. Does anyone know what else might be wrong? Please help
  • #2 16646751
    jerry1960
    Level 37  
    Help: 285
    Rate: 1561
    And you checked the bulbs, good mass.
  • #3 16646756
    Mahoni23
    So I put the new bulbs in the mass. I made such a trick
    That I put the wire from the plus on the battery to the fuse from the dipped beam and it turned out with the dipped beam.
    But the current goes to the fuses. Because the other little ones are long. Parking etc.
  • #4 16646830
    jerry1960
    Level 37  
    Help: 285
    Rate: 1561
    So you do not have power to the fuse from the dipped beam headlights, look in this direction.
  • #5 16903867
    remi2502
    the problem is behind the meter where there is a cube connecting several wires. solder and calm
