2004 Renault Megane II 1.5 DCI: Error DF112 Troubleshooting, Shaft Sensor, Timing & Solutions
SanchosX 18222 5
  • #1 16649093
    SanchosX
    Rate: 75
    Toy car from 2004 1.5dci
    If the "shaft" sensor is connected, the car does not start - no errors
    If we disconnect it, it fires in the 2nd time error df112 break
    If I connect it on a fired car, the error changes to df112 signal incompatibility
    2 sensors replaced and the same
    timing set on locks (shaft and pin shaft, pump wheel set according to the instructions with a sign on the bolt)
    The marks on the belt also match, i.e. between the roller and the pump.
    The installation to the computer has been checked
  • #2 16649433
    damdam
    Help: 274
    Rate: 950
    there are no miracles - a wedge on the shaft?
    ACME Damian Michalski
    Boczna 3a, Żory, 44-240 | Tel.: +48XXXXXXXXX (Show)
  • #3 16649856
    milejow
    Help: 1563
    Rate: 5149
    SanchosX wrote:
    pump wheel positioned according to the instructions with a mark on the bolt
    There is no mark on the bolt, the marks are on the belt and pulleys of the shaft and pump. 27 teeth of the belt between the pump pulley and the timing pulley.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #4 16654535
    SanchosX
    Rate: 75
    Buddy, damdam, there is no wedge on the shaft - that's why there is a shaft lock
    Buddy milejow, autodata or tolerance shows the pump wheel on the bolt, but I will check these 27 teeth and let me know (although from what I remember, the signs on the belt were matched with the marks on the wheels
  • #5 16654906
    kortyleski
    Help: 957
    Rate: 3860
    Check the shaft wheel key. They liked to cut
  • #6 16656372
    SanchosX
    Rate: 75
    27 cloves are the same
    But there is no sensor on the roller wheel
