Renault Megane ii 1.6 16v: Starter Operates but Fails to Ignite, Steering Not Locked Issue
WeMan22 23463 9
  • #1 17138371
    WeMan22
    Hello, I can not cope with my Frenchman ... I put the car under the store, and after leaving it no longer started. The starter turns but does not start. After the interrupted attempt, the computer displays steering not locked. I will add that the lock works normally when turning on this so-called hard ignition. The immo indicator goes out. Same on two cards. Until now, I replaced the shaft and shaft position sensor and it did not work.
    During this last ride, the pillow light flashed for a moment but went out. I don't know if it has anything to do with it, but the reel tape turned out to be completely broken. Do you have dear nice ideas?
  • #2 17138798
    kamiloskop
    Help: 42
    Rate: 278
    After 1 match do good diagnostics and then look. For now, you can see the ankle in your ear, i.e. the black box next to the battery if there is no water.
    łjanek
    Help: 13
    Rate: 61
    Yes, without diagnostics, you could still check if the fuel pump is running.
  • #4 17138836
    kamiloskop
    Help: 42
    Rate: 278
    The fuel pump does not cause an error with the steering lock rather ;-)
  • #5 17138878
    WeMan22
    Thanks for showing interest. Initially I looked there at these fuses and everything dry and functional but I will have to undress it more and see how it looks underneath.
  • #6 17138947
    kamiloskop
    Help: 42
    Rate: 278
    Here, too, the blockade may fall down. Fits to do diagnosis buddy.
  • #7 17138965
    WeMan22
    The lock is working. Because when you turn on the ignition at which the power is turned on, the lock works without any problems. And normally, during firing, the support was already on and now not. Well, it is difficult to speak and in fact without the clip you can not do it.
  • #8 17138975
    kamiloskop
    Help: 42
    Rate: 278
    Do not insist that it is definitely good because here you have a choice of ears, cables, plugs 2 from ear to ear, same ears and bsi because it controls the lock.
  • #9 17139077
    teodor76
    Help: 6
    Rate: 54
    Hello, read the errors in the air bag or any, unplug the plug from the pillow sensor and clear the errors in the engine controller even if it does not show any errors.
  • #10 17155187
    WeMan22
    Hello, my friend's friends were right. The problem was in the fuel pump also as you can see meganka even then it can dump a steering lock error. There was a hot ankle. greetings
✨ The discussion revolves around a Renault Megane II 1.6 16v that fails to start despite the starter operating. The user reports a "steering not locked" error, although the steering lock functions correctly when the ignition is turned on. Previous attempts to resolve the issue included replacing the shaft and shaft position sensor, but the problem persists. Suggestions from other users include performing diagnostics, checking the fuel pump, and inspecting electrical connections, particularly around the airbag and fuel system. Ultimately, it was determined that the fuel pump was the source of the issue, which can also trigger the steering lock error.
