HUAWEI Y7 Phone: Guide & Tips to Remove Back Cover in the Latest Model (Photos Attached)
IDCZAK 33411 4
  • #1 16651028
    IDCZAK
    Rate: 17
    I have a new phone HUAWEI Y7 with broken screen phone is a new model and nowhere in the network I can not find a way to open the flip. Attempts to undermine ends in a fiasco, even for a millimeter I can not tilt it though, you can see, although you can see the edge of heating, I give nothing. Maybe someone has already opened this model. If necessary, I will attach a photo tomorrow.
  • #2 16729918
    andrzejj-ostrow
    Rate: 19
    Have you managed to take off the back hatch from Hawei Y7?
    If so, please help.
  • #3 16730018
    IDCZAK
    Rate: 17
    Yes, the back flap does not open the whole with the sides after removing the display was broken, press the hatch opener between the display frame and its cover (flap with sides) the display with the frame is pressed into the housing.
  • #4 16732429
    andrzejj-ostrow
    Rate: 19
    Thank you very much for your help! It went smoothly, only with the use of nails.
    This lid is a good cushion. Everyone is probably tired of how to open it ...
  • #5 16732487
    IDCZAK
    Rate: 17
    I am glad that I could be helpful.
    I think about the subject as closed.
