SENCOR SLE3210M4 Black TV: Firmware Issues, LED Blinking, and Reset - Possible USB Update?
Passivepl 18294 15
Can I upload firmware to a SENCOR SLE3210M4 TV that freezes on the logo, blinks red/green, and resets, and how do I do it from USB at home?
Yes — the thread says this can be done from USB if you use a FAT32-formatted pendrive with the correct firmware for the TP.SIS231.P93 board. Format the USB stick as FAT32, copy the firmware file to it, unplug the TV from mains, insert the USB stick, then turn the TV on and do nothing else [#16656133][#16661119] The TV should start blinking slowly red/green first; after about a minute it should blink faster, which is described as the firmware being installed [#16669116] Then disconnect power, remove the USB stick, and power the TV on normally again [#16661119][#16669116] One user later confirmed that this procedure worked on an SLE3210M4 with the TP.SIS231.P93 board [#16954628]
  • USB firmware update may not be supported on this board
    #1 16653604
    Passivepl
    I have such a problem that I bought the Sencor SLE 3210 M4 Black TV set for free from my family. After switching on the television hangs on the company logo, then the red - green LED starts blinking and after a few seconds the TV resets. From what I have read on the forum it is possible that the fault lies with the software. I also downloaded the charge for the TP.SIS231.P93 disc that is in my model, I put it on USB and numerous attempts (holding the power button, input, menu etc.) I could not boot this file. I am completely green and I do not know if it is even possible to upload it via usb, but somehow I read from among the lines that it is possible.
    Hence my question whether I am doing something wrong and it is possible to upload to this new batch via USB. Or maybe I am not able to easily do it myself at home and it is better to outsource it to some unsightly.
    Thank you in advance for any help and advice
  • #2 16655929
    borg77
    Help: 199
    Rate: 452
    Which USB stick and which file system is formatted. How much does the loaded firmware weigh?
  • #3 16656025
    Passivepl
    Pendrive is the most ordinary one that I found in a 512 MB cabinet, probably formatted under NTFS. I found the post on the forum, two versions, on average, weigh 8-10 mb
  • #4 16656133
    kassans
    Level 32  
    Help: 130
    Rate: 413
    Format the flash drive to fat32 and then try.
  • #5 16656138
    Passivepl
    Try to boot it while holding the power button all the time while displaying the brand logo?
  • #6 16660559
    Passivepl
    After changing to FAT32 the matter looks the same, is there any possibility of trying on or not?
  • #7 16660697
    borg77
    Help: 199
    Rate: 452
    Does the TV after switching on the network turns itself on, do you need to turn on the remote control and does it react to the remote control after switching on (switching off the TV).
  • #8 16660988
    Passivepl
    It does not turn on by itself, the red stand-by LED is on, I can turn it on with the remote control or the button on the TV panel. The TV after switching on falls into a loop which consists in the fact that the diode lights alternately red and green, after which the TV resets. The only way I can turn it off is by pressing the power off button or by unplugging it
    borg77
    Help: 199
    Rate: 452
    Upload the file in the attachment on a pendrive. Turn off the TV from the network. Insert the pen into the usb socket. Turn on the TV with the remote control and press nothing more. Note how the LED on the pendrive and on the TV behaves. Czech described it as follows:
    The attached file should be discarded empty USB device
    Insert into USB port and connect the TV to the network.
    Wait a few minutes flashing green and red slowly.
    until the LED starts blinking alternately - red - green
    then you can turn off the TV, select USB from the socket and turn on the TV OK.
    I did not have the opportunity to check this file. I fell through the search and resuscitation of SLE3209.
    • SISEU23X8M.bin (6.52 MB) You must be logged in to download this attachment.
  • #10 16661369
    Passivepl
    Everything is speeding, it's nice; D at the beginning I was curious whether it was done because neither image nor anything. But everything was going as it was in what you wrote so I was good thoughts and I was not disappointed; D Thanks so much for your help, I hope that it will work without problems :) However, if I have problems, I know where to look for help!
  • #11 16661542
    borg77
    Help: 199
    Rate: 452
    As if you had an unscheduled TV, enter the data of the motherboard, power supply and above all the matrix in the forum.
  • #12 16668144
    piotrmessi1984
    I have the same model and number on the matrix and if I insert the pen it's not blinking, the rittt still shines red. What to do, help, I don't have a new TV right now
  • #13 16668154
    borg77
    Help: 199
    Rate: 452
    Have you read all the posts in this topic carefully or did you immediately start downloading the software?
    Rather, the latter, because not a word was about the type of matrix.
  • USB firmware update procedure for SENCOR TV
    #14 16669116
    Passivepl
    Unscrew the back of the housing and check if the numbers on the motherboard match, if so follow the same as what Borg77 wrote a few posts above.
    -format a pendrive to fat32 and upload a file to it
    - you connect usb to the TV disconnected from the current
    - you turn it on and from what I remember you don't even need to start anything, the TV itself will start to flash the LED slowly in red and green, without any image on the screen
    - after about a minute it will start flashing quickly, i.e. the software has been installed
    - you pull out from the electricity
    - you pull usb
    - plug it back in and turn it on normally with the remote control or the button.
    It should work, at least from what I remember, this is how I looked at this process and everything is still flashing.
  • #15 16954628
    z0diaC
    thank you for your help, the tutorial helped with my SLE3210M4 with the TP.SIS231.P93 board ... I tried several * .BINs but it worked up to the attachment ... I played 25Q64
    • SISEU23X8M.bin (6.53 MB) You must be logged in to download this attachment.
    • GD25Q64.bin (8 MB) You must be logged in to download this attachment.
  • #16 17312571
    arson18
    Help: 28
    Rate: 65
    I bought a new motherboard TP.SIS231.P93 for TV Sencor SLE 2909M4. After changing the whole disc, the TV turned on, everything worked with the backlight and the picture, but unfortunately everything was turned 180 degrees. SISEU23X8M software helped. If someone has such a defect, 100% helps. Thanks
The discussion revolves around firmware issues with the SENCOR SLE3210M4 Black TV, where users report the TV hanging on the logo and LED blinking red and green before resetting. The primary troubleshooting method involves attempting to upload firmware via USB. Users suggest formatting the USB drive to FAT32 and using specific firmware files. Successful attempts include turning off the TV, inserting the USB, and powering it on without pressing any buttons, allowing the TV to automatically initiate the firmware update process. Some users also mention checking motherboard compatibility and using the correct firmware version for successful recovery.
TL;DR: USB recovery works for many SENCOR SLE3210M4 sets. Expect the LED to blink and, as one user noted, "after about a minute it will start flashing quickly." Use that cue to power-cycle and remove the USB. [Elektroda, Passivepl, post #16669116]
Why it matters: This FAQ helps owners fix boot loops (logo hang, red/green LED) and complete a safe USB firmware restore at home.
How do I fix a SENCOR SLE3210M4 that hangs on the logo and blinks red/green?
Use the USB recovery. 1) Format a USB to FAT32 and copy the recovery file. 2) With TV unplugged, insert USB, then power on via remote. 3) Wait for slow red/green blinking to turn fast, then power off, remove USB, and start normally. "Wait a few minutes" for the blink change. [Elektroda, borg77, post #16661119]
What USB format and size should I use for the firmware update?
Format the stick as FAT32. Small drives work fine; one successful case used a 512 MB USB stick. Avoid NTFS. "Format the flash drive to fat32 and then try." [Elektroda, kassans, post #16656133]
How long does the update take and what LEDs should I see?
Expect slow red/green blinking during loading. After about one minute, the LED blinks faster. That indicates flashing completed. Then power off, remove the USB, and boot normally. "After about a minute it will start flashing quickly." [Elektroda, Passivepl, post #16669116]
Do I need to hold any buttons during startup for USB flashing?
No. Insert the USB while the TV is unplugged. Plug in, then turn on with the remote and press nothing else. The TV reads the USB automatically and shows the LED sequence. [Elektroda, borg77, post #16661119]
My TV stays on a solid red LED with the USB inserted. What should I check?
Verify panel (matrix) compatibility and board details. Mismatched matrix types can block updates and cause no USB activity. Open the back and confirm exact identifiers before retrying with the correct file. "Not a word was about the type of matrix." [Elektroda, borg77, post #16668154]
What’s the typical firmware file size for this model?
Community-shared firmware packages for this board are about 8–10 MB. A small USB is sufficient. This helps spot bad downloads that deviate wildly from that size. [Elektroda, Passivepl, post #16656025]
The TV keeps rebooting in a loop even after the update. What next?
Document full hardware details before further action. Note the mainboard (TP.SIS231.P93), power supply, and especially the matrix model. Share these when seeking help, as mismatches can cause persistent loops. [Elektroda, borg77, post #16661542]
Can I recover the TV by programming the 25Q64 chip directly?
Yes. Users restored operation by flashing the 25Q64 memory with the working image when USB attempts failed. This approach requires a programmer and steady hands but can revive a bricked set. [Elektroda, z0diaC, post #16954628]
What is the TP.SIS231.P93 board in my SENCOR?
It is the mainboard code used in SLE3210M4 and related models. Match this code before applying any firmware or board swaps. Owners reported boot issues and successful fixes referencing this exact code. [Elektroda, Passivepl, post #16653604]
What is the 25Q64 component?
It is the onboard serial flash memory that stores the TV’s firmware. Some users reprogrammed this chip to restore boot when USB updates did not take. Treat it as the last-resort path. [Elektroda, z0diaC, post #16954628]
Do I need to power-cycle at a specific moment during the update?
Yes. Wait until the LED changes from slow to fast blinking, indicating the write completed. Then power off, remove the USB, and start the TV normally. Powering off too early risks corruption. [Elektroda, Passivepl, post #16669116]
Will replacing the mainboard cause the image to flip upside down?
Yes, after swapping boards, some sets showed a 180° rotated image. Applying SISEU23X8M software corrected orientation and restored normal viewing. This is a known post-replacement quirk. [Elektroda, arson18, post #17312571]
What steps confirm the USB file actually loaded?
Watch the LED behavior. Slow alternating red/green means reading. Fast blinking signals completion. No on-screen image appears during the process, which is normal. Then perform the final power cycle. [Elektroda, borg77, post #16661119]
Can the TV start the update without me pressing any buttons?
Yes. With the USB inserted and power applied, it begins reading automatically. Turn on with the remote, then leave it. Do not press other keys. [Elektroda, borg77, post #16661119]
Is it normal to see no picture during the USB update?
Yes. Users reported no image while the LED indicated progress. Rely on the blink pattern, then complete the power cycle when fast blinking begins. This avoids interrupting the write. [Elektroda, Passivepl, post #16661369]
What if my USB was formatted NTFS earlier and the update failed?
Reformat the same stick to FAT32 and retry the procedure. Community feedback shows FAT32 as the accepted format for the loader on this board. This change alone resolved failed attempts. [Elektroda, kassans, post #16656133]
