Peugeot 1.6 HDI Engine: Timing Belt & Magnetic Disc Pulley Setup - Seeking Advice, Photos
majki891 25782 5
  • #1 16653768
    majki891
    Rate: 10
    Hello colleagues,
    I'm having trouble with the 1.6 hdi engine, namely:
    I bought an engine that did not have a timing belt and the pulley with magnetic disk was removed.
    Set the fuel pump and camshaft I just asked how to set the shaft and magnetic disc, I bought a new set. Is there any way to do this?
    I am asking for advice or photos.
    I will be grateful for your help
  • #2 16653775
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    There should be a wedge there so there is no option to put the wheel on the shaft differently.
    The wheel has only one round hole. The hole is to be at 12 o'clock and through it you put a 5mm lock in which it comes in the oil pump housing. The wedge on the shaft is probably at 3 o'clock.
    Look here
    https://www.youtube.com/watch?v=iuOECxVYlAU
  • #3 16654250
    majki891
    Rate: 10
    Well, that's the problem because the magnetic ring was probably presented because more than 40 turns of the railway shaft and inability to tune with the camshaft centering hole.
    Then I checked if this ring is downloadable and I honestly say that it fell alone under the pressure of my fingers.
  • #4 16654394
    grala1
    Help: 1495
    Rate: 5052
    I would risk saying that your wheel is damaged. How is he supposed to stick since the screw only tightens the wheel?
    Give a picture after it has fallen apart.
  • #5 16654454
    majki891
    Rate: 10
    Ok, I suppose it should be hot pressed but it is not known who did what with it before.
  • #6 18898835
    orzech_swin
    Rate: 9
    As you handled I have the same problem, the wheel is on a wedge and I will only turn 3/4 turn after setting it to locks
