Peugeot 1.6 HDI 90KM 2006 - Peugeot 1.6 HDI 90HP crankshaft position error
Kocmouch 28818 6
  • #1 16260908
    Kocmouch
    Rate: 11
    Where are the crankshaft sensors in peugeot?
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    On the left side of the shaft pulley.
  • #3 16260928
    Kocmouch
    Rate: 11
    So, from the side of the gearbox, somewhere around the reverse gear sensor?
    So somewhere around the reverse gear sensor?
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    So the shaft pulley is the wheel that drives the accessories belt (alternator, power pump, etc.)
  • #5 16260943
    Kocmouch
    Rate: 11
    Thanks, now I'm overwhelmed.
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    Photo found on the web.
  • #7 16262312
    Kocmouch
    Rate: 11
    Sory, I'm so poisonous ... but now you need a camshaft sensor.
    I'm going to pee this peugeot ... First and last time I touch any peugeot ... ;-D
The discussion centers around the location of the crankshaft sensor in a 2006 Peugeot 1.6 HDI 90KM. It is identified that the sensor is located on the left side of the shaft pulley, which is responsible for driving the accessories belt. There is some confusion regarding its proximity to the reverse gear sensor, and a follow-up mentions the need for a camshaft sensor as well. A photo link is provided for visual reference.
