[Solved] Samsung UE32J4100AW TV: Choosing Between FAN6755U and FAN6755W for BN44-00696A Module
dariuszj 16725 9
Can the SEM3330 controller in a Samsung BN44-00696A power supply be replaced with FAN6755, and if so, should I use the 65 kHz or 130 kHz variant?
Use the 65 kHz version: the thread says the original SEM3330 in the BN44-00696A works at about 65 kHz, and a FAN6755 replacement works without modifications [#16662307][#16655717] The variant discussion in the thread maps FAN6755W to 65 kHz and FAN6755U to 130 kHz, so the 65 kHz part is the safer match to the original [#16656224] It is also noted that FAN6755/FAN6755W and FAN6755U/FAN6755UW are different variants because the operating frequency is programmed differently, so they should not be treated as automatically interchangeable [#16656712][#16655717]
  • #1 16654427
    dariuszj
    Help: 33
    Rate: 68
    Hello. The S3330 system in the BN44-00696A power supply module. It is probably FAN6755, only with the letter U (operating frequency 65kHz) or with the letter W - 130kHz? Although both versions are available, I don't want to do more damage if I miss.
    A small but significant amendment. Conversely, the system with the letter U works with f-130kHz, and with the letter W- 65kHz.
    Piotr2608
    Help: 851
    Rate: 4487
    I would suggest buying a new system at Impelshop - SEM3330.
    ZimTech Piotr Zimny
    Renso
    Help: 11
    Rate: 77
    The author of the information from the page http://www.kenotrontv.ru/forum/gallery/image/2306-%D0%B1%D0%BF/ states that in the BN44-00696A power supply the S3330 system without modifications can be replaced by the FAN6755 system. However, it should be remembered that the FAN6755, FAN6755W and FAN6755UW are different systems.
  • #4 16655873
    lisek
    Service technician RTV
    Help: 6344
    Rate: 6872
    And e.g. from this forum link
    * 203d6 (NCP1203D6)
    Work system org. S3330
  • #5 16656224
    mirex
    Help: 1950
    Rate: 1990
    Come on, since the original is available. ;)
    foxes, recommending some alteration, although you would write that it was made to ... ;)
    I know that it can be on hand, if not, it is several times cheaper.
    But the spec should add that disconnecting pin 1 is a mistake. Use a conversion compatible with the application.
    As for the author's question
    External elements and the transformer used (generally its inductance) indicate that it is rather above 100kHz.
    When you start it, you'll have the opportunity to personally check how often the system works to provide nominal output voltages.
    And by the way a question for those willing - is it safer to insert the system with a higher or lower nominal operating frequency in such a situation?
  • #6 16656712
    dariuszj
    Help: 33
    Rate: 68
    That was it. By the way, I learned that it is about SEM3330. I was looking for S3330 but none of that. Thanks for the help.
    Somewhere here on the forum described conversion to NCP1207A with PIN1 disconnection. I don't know how it worked for someone. Unfortunately, the system did not work for me. Anyway, comparing a typical NCP1207A application with a real system, there are big differences.
    Added after 29 [minutes]:
    Unfortunately you are wrong. FAN6755 and FAN6755W are identical systems (note the method of printing on the casing of the system. In the case of the system with the letter W, the 6755 print is in line with the WTPM print. However, in the case of FAN6755U the 6755U string is the same as in the first case of WTPM). it is a layout in two variants 6755 and 6755U or 6755W and 6755UW if you prefer. Architecturally both versions are the same except for the "programmed" operating frequency.
    Of course, this does not mean that they are interchangeable.
  • #7 16656843
    mirex
    Help: 1950
    Rate: 1990
    Well, the fox gave you the link. ;)
    And I also wrote something on this topic.
    However, since you say that there are big differences between the typical NCP1207 application and the SEM3330 solution in THIS power supply, then be so nice and just describe them? Because in my opinion they are not so big at all.
    So a properly made prosthesis on NCP1207A should work.
    So it may turn out that you put in a new SEM, and it will still be bowel. ;)
  • #8 16657369
    lisek
    Help: 6344
    Rate: 6872
    a correctly made prosthesis on NCP1207A should work.
    It will not work.
    The author probably got it wrong in the description of the system !?
    Will work with NCP1203D6 (60kHz, and 100 / i 40) on condition
    - disconnection of pin 1 NCP (air)
    * resistor ladder desoldered from the SEM application
    - compare both systems. work: connection pin.5 NCP ... to the field gate
    _____________________________
    In some solutions pin.1 NCP is connected via R = 39k / or 47k to ground
  • #9 16657473
    mirex
    Help: 1950
    Rate: 1990
    I will also give two pictures.
    Please show significant differences that cannot be exchanged.
    Maybe a friend @Ibuprom will speak to you. ;)
    Samsung UE32J4100AW TV: Choosing Between FAN6755U and FAN6755W for BN44-00696A Module Samsung UE32J4100AW TV: Choosing Between FAN6755U and FAN6755W for BN44-00696A Module
  • #10 16662307
    dariuszj
    Help: 33
    Rate: 68
    Finally, some information. The original system works at a frequency of about 65kHz. The conversion with FAN6755 works without any problem. However, the conversion with NCP1207 for me probably did not work because of the damaged MOSFET key. Damage to the transistor is unusual because it did not have to pass or short circuit. After repairing the power supply, the conversion on the NCP1207 was not checked. Ultimately, I put the original SEM3330. For information about the original layout, points for @ Piotr2608 . For all thanks for help.
✨ The discussion revolves around the compatibility of the FAN6755U and FAN6755W systems with the BN44-00696A power supply module in the Samsung UE32J4100AW TV. The original S3330 system operates at approximately 65kHz, while the FAN6755U and FAN6755W are noted to have different operating frequencies (U at 130kHz and W at 65kHz, contrary to initial assumptions). Users suggest that the FAN6755 can replace the S3330 without modifications, but caution that the FAN6755 and its variants (W and UW) are not interchangeable due to differences in operating frequency. The conversation also touches on alternative systems like the SEM3330 and NCP1207A, with users sharing experiences regarding their functionality and installation challenges. Ultimately, the original SEM3330 was confirmed to work effectively after troubleshooting issues with the NCP1207A conversion.
