Buying a 2004 Skoda Octavia 1.9 TDI 110 HP with 344K Mileage - Common Faults?
bbxb 15516 16
What should I check before buying a 2004 Skoda Octavia 1.9 TDI 110 HP with 344,000 km, and what are the common faults on this model?
Before buying, scan the car with a diagnostic computer and check the paint thickness, because a dealer car with this mileage and an engine wash carries a high risk of hidden faults [#16655625] Common weak points mentioned for this Octavia are rust at the tailgate, front sills and front fenders, steering rack wear, front wheel bearings, suspension arm bushes, window regulators, central electrics, and brake problems from a leaking servo or worn vacuum pump, plus poor pads [#16655666] Weak acceleration can come from the MAF sensor, turbo control, the turbo itself, or a leak in the intake system [#16655666] The rear window lift usually fails because the cables/sliders break, and the repair is typically cheap with repair kits, unless the motor mount or drive module is also damaged [#16656255][#16657451] Several replies advise avoiding this specific car altogether, saying that chasing the lack of power alone can easily cost 2–3 thousand zł and that dealer cars often hide or mask defects [#16658193][#16658257] If you still consider it, take an experienced person with you or inspect it at a service station first [#16655735][#16658558]
  • #1 16654788
    bbxb
    Help: 147
    Rate: 94
    I have an eye on the Skoda Octavia 1.9 TDI 110 HP from 2004 with mileage of 344,000. Car from 3 owner, Poland showroom. Book kept up to 123,000.
    What to look for when buying? What are the most common faults?
    I drove the car, worried about weak brakes and slow acceleration. On a cold idle engine, nothing shakes, works evenly.
    Car from the dealer, engine washed, etc. :-)
    Greetings!
    sadek1979
    Cars specialist
    Help: 237
    Rate: 1423
    Connect the computer, check the varnish tester and minimize the risk of fusing. If you do not have equipment, go to the diagnostics and check.
    robokop
    Help: 1763
    Rate: 6371
    So what are you still thinking about?
    This plus mileage should disqualify this car from further consideration. Weak points - rotting tailgate, front sills plus front fenders. For this fast dying maglow, front wheel bearings and swingarm rubber, window lifters and central electrics. As for the brakes, it's probably a leaky servo / worn vacup pump, plus the cheapest "Tomex" or "male" blocks. Weak acceleration? Standard - flow meter, turbine control, turbine itself, hole somewhere in the inlet. In general, as with a trader, you can expect everything and everywhere.
    sadek1979
    Cars specialist
    Help: 237
    Rate: 1423
    robokop don't scare your friend because he will ride he bike. The truth is that not everything can always be seen and captured. As I wrote, if you have no experience or you don't know cars well, ask someone to come with you.
  • #5 16656192
    bbxb
    Help: 147
    Rate: 94
    Thanks Colleagues for the answers :)
    What he wrote robokop it can be very possible because after starting the car, I waited for a minute and turned the steering wheel right-left not even completely but there was already some gentle hissing from the support - it could be this maglownica. The trader said it was because of 16tki tires.
    As for the weak brakes, the trader said that the pads must reach because the car was left unused for several weeks. I drove this car from 5 km and overall, somehow, braking has not improved so well.
    As for acceleration, I drove a few years Vectra C polift 1.9 CDTI 150 KM Z19DTH. I know that it is different technology and different engines, but in Vectra after pressing the gas pedal it pressed into the seat like in Boeing at the start. It also felt a light turbo-hole and generally knew exactly when the turbo was working and when it wasn't (and the turbo was working).
    Here in Octavia it is so that after pressing the gas there is no violent reaction, there is uniform acceleration, zero turbo tube, it's hard to feel whether the turbo is working or not. I assume that Octavi is a motor of an older generation than it was in Vectra, so the turbo tube should be more noticeable than in Vectra. Octavia makes a lot of noise when accelerating, the engine runs evenly, it feels that the meter is already from 100 km / ha on the meter we have about 60 km / h. There is no transmission ratio to the wheels. For 110 hp I have a feeling that it should go a little better.
    On cold sterile works evenly, the clutch works well, no knocks, no errors on the board. Cepik, UFG insurance base, autoDNA are all tested and true. Of course, the car is sealed, the engine is washed, like a dealer :)
    What are the possible costs of parts and labor of what he wrote robokop ? I omit topics like the swingarm rubber, because it will probably be for pennies.
    Greetings!
    Edit: ah, and of course the electrical control of one rear window does not work :) so as he wrote robokop something with this electrics glass may be wrong. The trader said that the engine works only a plastic "latch" has fallen.
    tzok
    Help: 3175
    Rate: 6546
    The window lifts on the links break, the repair is not too complicated (in Fabia and Octavia II you need to drill and then rivet), there are repair kits. Unless you broke the engine mount, it will be more expensive. But this is "pikuś" for other faults.
  • #7 16656807
    robokop
    Help: 1763
    Rate: 6371
    You got something mixed up. As a rule, in octavia if the glass does not work, it either grinded the lines, or some plastic slide broke - then they also grinded the lines, or the fault is in the cables - broken bundle. Repair parts in the first two cases from PLN 80 and up.
    bbxb wrote:
    I waited for a minute and turned the steering wheel right-left not even quite but there was already a slight hissing sound from the assist - it could be this maglownica.
    It may hiss, this is not a malfunction. Unless you confuse it with a pump howl.
    Nonsense. 16 tires are a failure for other reasons.
    Don't assume anything because you are wrong.
    bbxb wrote:
    shows no errors on the board.
    You know what? With your knowledge you are on your way to blend some zlotys.
  • #8 16657340
    tzok
    Help: 3175
    Rate: 6546
    I did not mix anything, if the cable gets into the engine it can damage it - it grinds the transmission or breaks the mount. I wrote that this is the last resort, but in the car from the dealer you can often find various strange and partially fixed / masked defects. Usually, the sliders (slides) break, but this is a small matter in combination with potential faults of the drive system. Recently, a colleague at Fabia did a repair kit (links + slides, without guides) ~ PLN 30, to Octavia And I see that they are at a similar price.
  • #9 16657402
    robokop
    Help: 1763
    Rate: 6371
    tzok wrote:
    I did not mix anything, if the cable gets into the engine it can damage it - it grinds the gearbox or breaks the mount
    I assure you that I will not. They will not grind the transmission, only the replaceable roller is destroyed. If the engine is too heavy, it just stops. I made dozens of these lifts. The engine link as such will never get - it is a separate component.
    tzok
    Help: 3175
    Rate: 6546
    Let it be you, which does not mean that the engine cannot be damaged (e.g. water may get into it). I know the construction of this lift, because as I wrote a week ago I repaired it. There it broke the whole drum / roller (the cable got under it and already had a socket in the engine module that this drum falls into) and one engine mount was pulled out, but it could be assembled without replacing the drive module ... only what does it matter ? Either way, it's a penny to repair, compared to replacing a clutch or turbine.
  • #11 16658121
    bbxb
    Help: 147
    Rate: 94
    What can be the approximate cost of repairing these defects described by me (brakes, acceleration, window, maglow) ??
    andrzej20001
    Help: 1578
    Rate: 6669
    This mate does not even know the diviner Maciej. :) Look for another car. To start packing 2-3 thousand without sense.
    Woziowsky
    Just like Andrzej writes. Packing in such an Octavia makes no sense. The struggle with finding the cause of the lack of acceleration is a pile of nerves and money. Give up cars from dealers, they do not know the past of cars, nothing can be learned from them. They also often fail to mask faults that return with redoubled power.
    Kantylena
    Help: 18
    Rate: 222
    And I would start from how we know that the car is troubled by such defects? Is it not better to drive to the control stations and check on the health path?
    This car is 14 years old, it will be hard to find others in perfect condition.
    Lack of power - preferably dynamic logs but the trader may not allow or measure on the dynamometer
    what would i do ride and watch other octaves, golf, a3 or forests, toledo with these units and see how they drive.
    And here I will also confirm that cars from dealers are often uncertain, they have to earn so they don't buy perfect copies, but rather the worst ones.
  • #16 16660480
    bbxb
    Help: 147
    Rate: 94
    Or maybe it's better to go and look for something at http://www.autohus.de/?
    was someone buying a car there?
    I got this link from a friend, there are probably only flotation cars there ... is it worth looking for?
    Kantylena
    Help: 18
    Rate: 222
    According to me, looking for such a populus abroad is probably not profitable ... but it depends
    However, instead of looking for tdi with a huge mileage and toys that can break down, e.g. turbo, can't go into gasoline? 1.8 L or 2.0 - lower real mileage and in my opinion cheaper potential repairs
The discussion revolves around the potential purchase of a 2004 Skoda Octavia 1.9 TDI with high mileage (344,000 km) and concerns regarding common faults. Key issues highlighted include weak brakes, slow acceleration, and potential problems with the steering system (maglownica). Participants recommend conducting a thorough diagnostic check, including using a varnish tester, and being wary of common faults such as rotting tailgates, worn front sills, and issues with window lifters. The consensus suggests that the car's high mileage and the dealer's lack of transparency about its history may indicate hidden defects, making it advisable to consider other options or vehicles with lower mileage. Repair costs for identified issues could be significant, and the general advice leans towards avoiding this particular vehicle.
TL;DR: Considering a 2004 Octavia 1.9 TDI with 344,000 km? Expert warns: "Weak points—rotting tailgate, sills, fenders." Expect brake, turbo-control, and electrics checks before buying. [Elektroda, robokop, post #16655666]
Why it matters: This FAQ helps used‑car shoppers spot costly faults fast on high‑mileage Octavia 1.9 TDI models.
Is a 2004 Octavia 1.9 TDI with 344k km worth buying?
Only if condition and diagnostics are solid. An experienced member notes high mileage plus trader prep can be a deal‑breaker. He adds, “This plus mileage should disqualify this car from further consideration.” Inspect corrosion zones and running gear before deciding. [Elektroda, robokop, post #16655666]
What rust and wear spots should I check first?
Inspect the tailgate edge, front sills, and front fenders for corrosion. Check front wheel bearings, control‑arm bushings, and the steering rack for play or noise. These areas are repeatedly flagged as weak points on this generation. [Elektroda, robokop, post #16655666]
Why do the brakes feel weak on a test drive?
Poor braking can come from a leaking brake servo or a worn vacuum pump. Budget pad brands also reduce bite. If the car sat for weeks, surface rust can add noise, but persistent weak bite points back to vacuum or pad quality issues. [Elektroda, robokop, post #16655666]
Slow acceleration and no clear turbo kick—what should I test?
Check the MAF (air‑flow meter), turbo control system, and the turbocharger itself. Inspect the intake tract for leaks. Uniform but dull acceleration often traces to control issues or leaks rather than the driver’s "feel" for boost. Scan and log live data before buying. [Elektroda, robokop, post #16655666]
I hear a light hissing when turning the wheel—normal or not?
A slight hiss from the steering assist can be normal. Distinguish it from a pump howl, which suggests trouble. If the noise grows with steering effort or temperature, plan a closer rack and pump inspection after a proper road test. [Elektroda, robokop, post #16656807]
How should I check this Octavia before handing over cash?
Use a scan tool for fault codes and live data. Measure paint thickness to spot body repairs. If you lack tools, visit a diagnostics shop to minimize risk.
  1. Connect OBD scanner and read data.
  2. Check panels with a paint meter.
  3. Road‑test and verify braking/boost. [Elektroda, sadek1979, post #16655625]
One window doesn’t work—what usually fails and what’s the fix?
On these cars, regulator cables or plastic slides often fail. A broken harness in the door jamb is another cause. Repair parts are available, and many fixes start with replacing the cable/slide set and re‑greasing guides. Expect parts pricing from budget levels upward. [Elektroda, robokop, post #16656807]
Can a failed window regulator damage the motor?
Yes, in edge cases. If the cable winds badly, the drum can break and even pull an engine mount point, allowing water to enter and harm the motor. A colleague repaired such damage without replacing the module, but treat it as a warning sign. [Elektroda, tzok, post #16657451]
What might the total repair bill be to sort brakes, power loss, and a window?
Costs vary too much to quote precisely without diagnostics. One seasoned member’s rule of thumb was to expect an initial outlay of PLN 2–3k on a rough example. Consider walking away if the seller resists pre‑purchase checks. [Elektroda, andrzej20001, post #16658193]
Are dealer cars safer bets for history and condition?
Not necessarily. Contributors warn that dealers may not know past faults and sometimes mask issues that return later. If transparency is weak, assume higher risk and insist on independent diagnostics before purchase. [Elektroda, Woziowsky, post #16658257]
How can I objectively verify the lack of power?
Do dynamic logs during a road test to track boost and airflow values. If that’s impossible, use a chassis dynamometer to measure output. Either method beats seat‑of‑the‑pants impressions and can reveal control or leak faults quickly. [Elektroda, Kantylena, post #16658558]
What does “maglownica” mean, and should it worry me?
Maglownica is the steering rack. Light hissing from the assist can be normal, but a howling pump or free play isn’t. During inspection, check for leaks and consistent assist across the wheel range at idle and after a drive. [Elektroda, robokop, post #16656807]
The engine bay was washed—red flag?
Treat it as a caution. On a high‑mileage dealer car, a freshly washed engine can hide leaks. One expert adds that with traders “you can expect everything and everywhere,” so verify seals and hoses with a cold‑start inspection. [Elektroda, robokop, post #16655666]
Does an error‑free dashboard mean the car is fine?
No. Many issues don’t trigger a dash light. Plug in a diagnostic computer, assess live data, and run a full systems scan. Pair that with a paint‑thickness check and professional inspection to reduce risk before purchase. [Elektroda, sadek1979, post #16655625]
Should I consider petrol instead of an old high‑mileage diesel?
Yes. A member suggests 1.8 or 2.0 petrol options for lower real mileage and cheaper potential repairs. If you drive short trips, petrol can reduce diesel‑specific risks like boost control and injection wear. [Elektroda, Kantylena, post #16661099]
Is shopping abroad for such a common model worthwhile?
Often not for a popular, lower‑value car. The advice shared was that hunting one abroad may not be profitable after time and logistics. Focus on local condition and documentation instead. [Elektroda, Kantylena, post #16661099]
