Cleaning & Painting Petrol Lawnmower: Safely Turn 180 Degrees or Use Channel for Thorough Care
Spedytor1982 9534 4
  • #1 16656107
    Spedytor1982
    Maybe my question will seem silly to some, but if cleaning / painting the petrol lawnmower (its bottom, i.e. around the knife) can it be turned 180 degrees and put on the engine, or better not to do it and drive it into a channel to thoroughly clean and paint it?
  • #2 16656115
  • #3 16656183
  • #4 16656277
    Tommy82
    Help: 455
    Rate: 1074
    @ banda.amatorów
    Unless they are baked. If you don't want to go, it's good that you unscrew it because it means you have a wedge cut and you need to fix it anyway.
    For painting, it is better to remove the engine completely for washing, I tilt it to the side and I will not use the mower until the next season.
  • #5 16656435
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    Tommy82 wrote:
    I tilt it entirely to the side
    So basically motor mowers tilt sideways nobody recommends.
    http://jakienarzedzia.pl/prawidlowe-uzytkowanie-i-czyszczenie-kosiarki-spalinowej/
    The only correct option for "tilting" the mower with the engine is that the engine when tilting is the piston / cylinder up.
    In this way:
    Not so:
    And not like this:
