Best Petrol Lawn Mowers under PLN 1400 with Drive & Engine Speed Control: Top Picks
ustijuf 141948 140
Which petrol lawn mower with a drive, and preferably engine speed control, can I buy for up to PLN 1400?
At PLN 1,400, don’t expect a really sensible petrol mower with both drive and engine speed control; several users say you need to raise the budget to about PLN 1,800 to get that feature set [#17911266][#17945862] If you can stretch the budget, look at AL-KO models such as the Classic 518 VS or similar Highline/Premium versions, or at World mowers with Loncin engines, which were repeatedly praised for durability and parts availability [#17911266][#17945862] Avoid NAC and other random Allegro/no-name builds, because users warned about poor quality and lack of spare parts [#17897754][#17946169] For the engine choice, Loncin was generally preferred over current Briggs & Stratton, which several posters described as weaker than older B&S units [#17900200][#18769146] As for the speed-control lever, it usually adjusts the governor spring/sensitivity rather than directly setting throttle, so the engine still self-stabilizes under load [#17935862]
  • #1 17897736
    ustijuf
    Rate: 94
    Hello. I'm going to buy a petrol lawn mower. Price up to PLN 1400. The mower must have a drive. And it would be best if it also had an engine speed control. I am asking for help in choosing.
  • #2 17897754
    wacek.wacek
    Help: 98
    Rate: 281
    You definitely don't buy NAC. Total crap.
  • #5 17899925
    ustijuf
    Rate: 94
    And which engine is better Loncin or Briggs & Stratton?
  • #6 17899944
    wacek.wacek
    Help: 98
    Rate: 281
    I guess brigs
  • #7 17900200
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1118
    wacek.wacek wrote:
    I guess brigs
    On many "mower" forums the Loncin engines are highly praised, the EMAK engines in Oleo-Mac mowers are also the Loncin version, only "branded" (housing, inscriptions) for the Oleo-Mac company.
    Briggs & Stratton in the present "productions" are apparently not the same Briggs & Stratton as before.
  • #9 17902245
    wacek.wacek
    Help: 98
    Rate: 281
    Cool . Only as it will be with the durability of the starting system and with the drive.
  • #10 17911266
    plk_babel
    Rate: 34
    Hi! The big question is: how many meters are you mowing? If up to 15 ares, 46 cm is enough, if more, a 51 cm mower would be useful.
    As for the engine brand, the current engine class looks like this: Honda = Kawasaki> Vanguard = Rato> Briggs = Loncin> Zongshen >>>> everything else.
    Lonciny is hidden under brands such as Emak or AL-KO Pro. Let go of all Allegro inventions on strange engines for your peace of mind. If something in such a mower falls, you will not find a stupid drive belt, or even a throttle cable of the right length.
    More than half of the mower's value is the cart, i.e. the chassis, and what it hides. Here, too, are the biggest savings in cheap mowers, but then and the user's despair.
    Proven equipment:
    51 cm:
    https://multimaszyny.eu/kosiarka-z-napedem/51...-grass-g-force-xsz51a-loncin-224-ccm-4w1.html - how do you like power and buy everything "in stock" :) The most powerful engine in this price range 14 Nm - real, the kind measured with a graph that you can download from the manufacturer's website. No fake Super Power 9.5 KM, but only in the description of the auction. In G-Force you have a housing made of hammered, thick sheet metal. The edge of the housing is folded out, so less muck collects under the mower and is easier to clean.
    https://multimaszyny.eu/kosiarka-z-napedem/12...a-spalinowa-world-grl-530s-hw-4w1-loncin.html - red if you prefer. A very solid mower. Thick sheet metal, varnished twice. I don't know complaining about her.
    on Briggs at this price and in this size it is difficult to find anything worth recommending.
    46 cm:
    or Loncin: https://multimaszyny.eu/kosiarka-z-napedem/42...a-spalinowa-world-grl-460s-hw-4w1-loncin.html
    https://multimaszyny.eu/kosiarka-z-napedem/49...spalinowa-grass-g-force-xsz46-4w1-loncin.html
    or Briggs for the stubborn :) but this Briggs has 125 ccm and 6.1 NM and the Loncin 159 ccm and 8.3 Nm - you will feel the difference on higher wet grass. But if you have a small plot of land, it works fine.
    https://multimaszyny.eu/kosiarka-z-napedem/466-kosiarka-spalinowa-al-ko-classic-465-sp-b.html
  • #11 17913263
    ustijuf
    Rate: 94
    I like this thing with an electric starter. Is it useful or is it a waste to spend money on it? Does it break?
  • #12 17914268
    plk_babel
    Rate: 34
    Apparently, new versions from 2019 have already improved inStart, versions produced before 2018 had a problem and landed on the central website to improve the electrics. They were all made under warranty and AL-KO recognized the warranty without any problem and after the repair the problem did not come back.
    Also, in my opinion, you can take it, if you hit the version with a problem, they will do it for free under warranty.
    In addition, the equipment is flawless. Worth every penny.
  • #14 17915209
    plk_babel
    Rate: 34
    Lucas81 wrote:
    I personally would look for something with a decent engine (the most important!), I.e. Honda, unless you prefer to run around the sites and after some time buy another one: /
    now, for example, in the promotion you have the cheapest version of Honda, i.e. SKEP -> https://www.honda-sklep-lopeno.pl/product-pol-436-HRG-466-SKEP.html
    But you know that a friend is looking for a mower for PLN 1,400, and this Honda costs PLN 1,995. Of course, Honda is Lodzio miodzio and there is nothing to be fussy about, but find me a Honda for PLN 1,400 :)
    In addition, the mower's engine is max. 50% of costs and problems.
    Engines are repaired relatively quickly and, in the worst case, replaced with another unit.
    The real annoyances are in and under the body.
    1. Body made of shit or varnished anyhow it will rot or crack, not from the outside, but from the bottom, where it is bombarded with stones and caked with damp grass.
    2. Power transmission: weak drive wheels, where the rim is extremely plastic (Viking !!!) or shit, it crumbles very quickly, and the parts are missing.
    3. Drive belts, weird, non-metric, unusual - when matched, they feel the "mm" difference, the pulley, which was also non-standard and you won't buy it,
    4. Lack of covers for the drive belt - a constant problem of customers.
    5. Knives and knife handles - more and more strange shapes, dimensions and spacing of fixings. Metric, non-metric with pins, with screws you can go crazy. In addition, not cast, but welded haphazardly, as long as they stick. Choose it and buy it? 10% chance.
    6. Drive gears - often have plastic parts ... how much could that come from? How does the acreage mow?
    7. "no name" engines - timing gears are falling apart, mainly cylinder head valves,
    8. The jerks fly after a year of use,
    9. Cables for engaging the drive - we cut off here every season. Until you want to cry. Because the mower seems to be in working order, but you will not buy the original, matched cord. And patching again. And again, instead of mowing, you wait in the service for repair.
    Also, what I recommend, I repair myself and I know that I have parts for it. :D
  • #15 17930529
    zagorski-tomasz
    Help: 8
    Rate: 138
    wojtek1234321 wrote:
    wacek.wacek wrote:
    I guess brigs
    Only most of them are paid marketing, they are not bad engines but they also have their advantages and disadvantages and it does not look so rosy in practice, they are definitely cheaper and here is a plus
    plk_babel wrote:
    Lucas81 wrote:
    SKEP.html
    Honda is not so nice, the parts are expensive and the service, at the price of PLN 2,000, there is a large selection of machines that are cooler and more functional, the engine housing and four wheels are a bit too little, what Honda offers
  • #16 17930544
  • #17 17930652
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1118
    Erbit wrote:
    plk_babel wrote:
    ... In G-Force you have a housing with hammered , thick sheet ...
    What does it mean?
    It does not mean anything, "hammered", it only means that it is painted with a paint with such a texture, the so-called hammer texture, and nothing else, that is just a "marketing chit" to make some wonder what "improved" there. Because in fact, the brand of G-Force mowers is an ordinary, maybe a little "better Chinese". After a few years of use (2 - 4), the tow truck, chassis will start to "crumble" and you will not buy original parts, wheels, etc.
    Such a simple example of the "hammer texture color" of sheet metal.
  • #18 17930660
  • #20 17930676
  • #21 17930755
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1118
    Erbit wrote:
    About what ? About nonsense linguistic ideas of marketers thoughtlessly repeated by others?
    Then maybe let's start filming, treating, combing, screwing ...?
    EOT.
    These examples you gave have nothing to do with my post.
    Hammer effect, hammer texture, paint and perhaps other terms may be used interchangeably. The fact that the paint has some "texture" of the surface after painting means that its surface is heterogeneous, that it has its own non-uniform surface structure, just like "hammer" and many others.
    https://www.google.pl/search?source=hp&ei=YGr...0.0i22i30.7288.17685..19387...2.0..0.169.1172. .... 0 .... 1..gws-wiz ..... 6..35i39j0i131j0j0i131i67j0i67j0i10j0i203j0i22i10i30.I6WQo3VxJyI
    best regards
    Request to the moderator:
    As it is not possible to add entries with a specific duration on the electrode, I ask the moderator to appoint, delete the entry after 3 (three) days, as it is practically not "on the subject", but it was added to clarify a small dispute.
  • #22 17930789
  • #23 17935105
    ustijuf
    Rate: 94
    I have one more question, if the mower has a lever to set the engine speed, does this engine also automatically stabilize the speed under load (intelligent throttle)?
  • #24 17935417
    Lucas81
    Rate: 16
    [quote = "zagorski-tomasz"]
    Honda is not so nice, the parts are expensive and the service, at the price of PLN 2,000, there is a large selection of machines that are cooler and more functional, the engine housing and four wheels are a bit too little, what Honda offers [/ quote]
    Sorry, but the prices of the website are the same as others - I don't know where you get the knowledge from, but it's worth supplementing it - the prices of the website also depend on where the website is located.
    Out of curiosity, what are these mowers more functional? :)
    You can read on other forums how guests are Honda 15 years old and run without failure, for example on pilarz.org. :D
    Besides, find me a second manufacturer who, after the recall of the model, offers access to parts for the next 25 years. :)
    And which manufacturer has a 5-year warranty?
  • #25 17935862
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1118
    I do not know what it is like in "present" engines (but probably the same as in the old ones), there is a speed regulator next to each "mower" engine. Although the engine has a speed control lever, this lever probably does not act directly on the throttle, but on the speed control spring, tensioning it more or reducing its tension (this was the case in older engines) and thus the engine runs slower at times, sometimes faster, depending on how you tighten it regulator spring. The speed range is limited by the regulator and we use the lever to only change this range of the regulator's capabilities, we do not directly control the engine's revolutions, but we change the regulator's "sensitivity" settings, which allows us to change the engine's revolutions to a certain extent. As I remember, this was always the case with mowers (almost).
  • #26 17936503
    zagorski-tomasz
    Help: 8
    Rate: 138
    [quote = "Lucas81"] [quote = "Zagorski-Tomasz"]
    [/ quote]
    Sorry, but the prices of the website are the same as others - I don't know where you get the knowledge from, but it's worth supplementing it. - the prices of the website also depend on the location of the website.
    Out of curiosity what these mowers are so more functional :)
    you can read on other forums like guests May Honde 15 years and it goes without fail, for example on pilkarz.org :D
    besides, find me a second manufacturer who, after the recall of the model, offers access to parts for the next 25 years :)
    and which manufacturer gives another 5-year warranty? [/ quote]
    Is it enough for oil, filter, candle replacement, knife sharpening PLN 240? The spare parts themselves are expensive and not only consumables, here the guarantee is to milk the customer out of money and if it breaks, unfortunately it will be the customer's fault, I have already seen rusted Honda after 8 years and as we know it is not the same quality as it used to be because they make them unknown where. When it comes to functionality, AL-KO is unbeatable in this respect and the website you mentioned I would rather be afraid to mention because of the positive feedback for money and I also heard about removing uncomfortable posts.
  • #28 17938476
    ustijuf
    Rate: 94
    You guys don't understand something. I am looking for a mower up to max. PLN 1400. Why do you write to me about some mowers much more expensive than I am looking for.
  • #29 17945862
    plk_babel
    Rate: 34
    Well, in fact, the discussion flowed ... Keeping to the topic, there is nothing sensible with the speed control up to PLN 1,400. You have to think about the budget of min. 1,800 PLN From this price you have a nice AL-KO https://multimaszyny.eu/kosiarka-z-napedem/15...ka-spalinowa-al-ko-classic-518-vs-b-plus.html
    or size 45 cm: https://cedrus.com.pl/kosiarka-spalinowa-weibang-wb454sb-3w1
    Both worth recommending. In Weibang, a smaller engine, but also a smaller mower. It does it.
✨ The discussion revolves around selecting the best petrol lawn mowers under PLN 1400, emphasizing the need for a drive and engine speed control. Participants express strong opinions on various brands and models, highlighting the reliability of engines such as Loncin and Briggs & Stratton. Recommendations include models from Oleo-Mac, AL-KO, and World, with specific models like the World GRL 460P HW and AL-KO 470 SP-A being frequently mentioned. Users caution against brands like NAC and Handy due to poor quality and lack of spare parts. The importance of engine durability, ease of maintenance, and the mower's build quality are also discussed, with a consensus that investing in a reliable engine is crucial for long-term satisfaction.
