Dewalt DCF899 - Cordless impact wrench burns the control system
ozman 9453 4
  • #1 16657436
    ozman
    Help: 19
    Rate: 36
    The key started to smoke after connecting the battery. Only F20 is written on the cube. Please tell me what this layout could be. The motor is brushless. 18V power supply. Unfortunately, you can not get the electronics alone, because it is a spare part only with the entire engine, so the price is like a new key.
  • #2 16777556
    pslosarz
    Help: 17
    Rate: 176
    Unfortunately, the entire electronics controlling the engine is damaged, most likely because the engine is also damaged. Cannot be repaired (flooded with resin). Total gross cost 500.
  • #3 16798391
    draggs
    Rate: 11
    Hello. The fact that the resin is flooded does not mean that the part cannot be replaced
  • #4 16841398
    ozman
    Help: 19
    Rate: 36
    I picked up the resins and it fired some chip with part of the plate. Buddy psolarz, where can I buy this module for PLN 500 gross?
  • #5 17011184
    partyzancik
    Help: 14
    Rate: 178
    sorry that I will reheat, they have some ratio between the rotor of the engine and the percussion mechanism of the key?
