VW T4 1.9D '94 - A clutch pedal, clutch or slave cylinder came up?
Luckey13 13416 7
  • #1 16657795
    Luckey13
    Rate: 91
    Hello, as in the subject, I came up with the clutch pedal, the clutch slave walks quite loosely, is it possible to determine whether it is a clutch or clutch without dropping the box?
    With the clutch I had no problems so far, the fault was rather unexpected, so far in the cars I drove there were some warning signs that the clutch sits, and here nothing, just the pedal came up and that's it.
    Mechanical slave cylinder.
    I would be grateful for a quick reply, because I don't know if I can do it on the spot, if I have to tow the car, I have 20km to go home, if I could do it without breaking the crate using basic tools, I would do it tomorrow on the spot, the crate where the car is unfortunately not dropped.
  • #2 16657817
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    Replace the cable :)
  • #3 16657830
    Luckey13
    Rate: 91
    The cable is good, recently replaced, the slave is pressed by hand, there is a slight jump and goes in without resistance ...
  • #4 16657837
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    What clutch? Clutch paw?
  • #6 16657880
    Luckey13
    Rate: 91
    I meant the lever to which the cable is attached, I saw that there is such a bolt that pushes the paw and I was wondering if it could not be damaged.
    So probably the range went?
    How is it fixed in t4, it can be replaced after moving the box, do you have to completely drop it?
  • #7 16657897
    ociz
    Help: 1379
    Rate: 3486
    If you want to move the crate straight to the bench, you can have only 2cm. All to remove and that's it. With this engine is a simple job. Do it in some 2.5TDI with AC, ABS, parking heater, etc., there you can bend a little bit for work, but here in workshop conditions it is in 2 hours the box removed and inserted.
  • #8 16657925
    Luckey13
    Rate: 91
    I do not frown at the work, I just do not have the workshop conditions on site, I will have to drop on the jack, but if you need to.
    Thank you for your help and best regards.
The discussion revolves around a 1994 VW T4 1.9D experiencing an issue with the clutch pedal, which has come up unexpectedly. The user suspects a problem with the clutch or the clutch slave cylinder, as the slave cylinder operates loosely. Responses suggest checking the clutch cable and the lever mechanism connected to the cable. It is noted that the clutch system in this model may require dropping the gearbox for inspection or replacement, although some users mention it can be done relatively easily in a workshop setting. The user expresses concern about the feasibility of performing repairs on-site without proper tools or conditions.
