[Solved] MSI Radeon RX 480 GAMING X 8GB - Blue Screen Video TDR Failure in Ultra Graphics Fifa 17
grol112 6804 2
  • #1 16658981
    grol112
    To start with, my computer:
    SilentiumPC Vero L1 500W power supply
    Toshiba P300 Performance 1TB drive
    MSI H110M PRO-VD motherboard
    GoodRam PLAY DDR4 memory, 8GB, 2400MHz
    Intel Core i5-7500 processor, 3.4GHz, 6MB
    MSI Radeon RX 480 GAMING X 8GB graphics card
    The problem is that when playing on ultra graphics, especially at matches in Fifteen, I get a "screened" screen in strange colors, then a blue screen with the message "the computer encountered a problem ... blah blah.
    Stop code: VIDEO TDR FAILURE
    Problem source: atikmpag.sys
    The computer restarts - such a blue screen, as I say, only occurs in games especially fifa17, because it can even 2-3x a day and usually before that you can hear the sound such as something disconnected, for example, a pendrive, and before the bluescreen the sound as if I connected something.
    I have the latest drivers for everything, probably there may be a problem with the graphics card.
    (disk 100% functional)
  • #2 16659015
    badboy84
    Help: 1198
    Rate: 1488
    Install and run HWinfo -> sensor only. Then start the game, then post the screenshots, or check if the card or other components overheat. Download newer drivers if available. You can also check with Furmark whether the same error occurs at the maximum load of the graphics card. I think it won't hurt to routinely check the power supply and measure its voltage with a meter.
  • #3 17207118
    grol112
    I updated the drivers to the latest ones, installed graphics programs.
