The Stihl RE 128 plus turns on, but does not build up pressure
nightwalker245 15375 2
  • #1 16659201
    nightwalker245
    Rate: 20
    As in the topic, I have a pressure washer stihl RE 128 plus, the engine is running, but unfortunately it does not generate pressure, the water just flies, or if someone of you has had such a problem or knows what it can be, please give a hint.
  • #2 16659416
    ArtXs
    Help: 93
    Rate: 112
    You need to check the valves in the pump head.
    Here is a diagram of what it looks like Link
  • #3 16659464
    nightwalker245
    Rate: 20
    there are probably 6 of them
