Huawei Y6 II Compact - USB OTG does not work after connecting the device :-(
Voodoo4 5460 3
  • Asking whether USB OTG needs extra settings
    #1 16659701
    Voodoo4
    Help: 6
    Rate: 42
    I bought a phone like the one in the description, I wanted USB OTG, I installed a program that supposedly shows that this phone supports USB OTG, however, after connecting whether it was a pen drive (exFAT) or a mouse, I checked various devices, to no avail. Does anyone need any additional settings to run the USB OTG application?
    I will add that the description of the phone and GSMchoice is that the phone supports USB-OTG V2.0.
    Thank you in advance for your help and best regards.
  • #2 16659737
    E8600
    Help: 529
    Rate: 2520
    It should work without an application. Check the adapter, because when I bought 5 pieces occasionally, one was damaged, maybe you were unlucky.
  • #3 16659745
    Voodoo4
    Help: 6
    Rate: 42
    Hmmm I'll do it because I have one adapter from the Mikrotik router was included and maybe he has some other pin connections.
  • #4 16809810
    Voodoo4
    Help: 6
    Rate: 42
    This device does not support USB OTG despite the descriptions on various pages that do.
    The manufacturer's website clearly states that this model has no USB OTG.
    Regards topic to close.
